Question about Garden
Need to adjust valves on 21hp briggs&stratton,set at tdc or?
  • 252 Answers
Hi edmeyers70
run engine to tdc compression stroke with plug out, and then set the piston 1/4 " past tdc on power stroke , then set the valve clearance at this piston position to ( off the top of my head about 0.003" inlet and 0.005" ex )
think these engines are briggs ohv single vertical
if you get model and type codes from your engine plate eg 351777-0112-e1
write yours down
here is web site
www.briggsandstratton.com
also www.partstree,com
go to briggs engine brand , select your engine series and then type code
parts diagrams will open up
cheers pauly46
Posted on May 21, 2011
Valve clearance Briggs model# 331877 1371b1
Danny, I set lash at .004" / intake and exhaust clearance. Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
http://www4.briggsandstratton.com/miscpdfs/RNT/Engine%20Specifications%20Chart_ms3992.pdf
briggs and stratton 21HP backfires like cannon
YTS3000 Craftsman model 917 289213 valve gap setting 331877 1371 B1 Briggs...
Lawn Mower Repair Valve Adjustment
Jul 08, 2016 | Garden
Engine rpms is constantly going up and down.
Is the air filter clean?
Governor Ajustment Briggs V-twin - YouTube
? 3:12
www.youtube.com/watch?v=tOoArROpM_oJun 26, 2010 - Uploaded by IFIXIT4U The Briggs manual does not do a very good job. You have to adjust the tension on the two springs to set the RPMs that the engine runs at the low and high position. ... I really really need help guys my race motor has a 21hp vtwin brigs, .... Briggs & Stratton opposed twin carburetor series 1 of 3 disassemble ...
Sep 17, 2015 | Briggs & Stratton Briggs Stratton Intek V...
Briggs & Stratton 33M777/21HP
Check your valve adjustment first as these uses a decompressor that on the camshaft itself.
Now while checking the valve clearances as you go past TDC of the compression stroke there should a little bump on the intake valve when the decompressor is working. If this bump is not there and the valves are set correctly then the decompressor has failed and requires the cam to be replaced.
10 276781SingleCylinderOHV pdf
May 02, 2015 | Briggs & Stratton Garden
I have a 21 hp Briggs and Stratton model #331877, what are the valve settings?
Intake 003 - .005
Exhaust .005 - .007
Adjusted with the piston 1/4" past TDC of compression stroke for each cylinder.
Apr 10, 2015 | Craftsman Garden
Need valve clearance on Briggs eng. Mod. 407777
Set No. 1 cylinder at 1/4" past TDC (Top Dead Center) on compression stroke. Gap both valves at .005". Gap is set with the engine being cold. Do the same for the other cylinder. Be sure to lock the adjusters back in place.
2. .S
Aug 07, 2013 | Briggs & Stratton Garden
I need to know the over head vave setting for the intake and exhaust on a 17.5hp Briggs & Stratton vertical shaft, single stroke lawn mower.
hi pauly46 here
set piston to tdc compression stroke then run it down the bore a 1/4 inch
set the tappetts to inlet the bottom valve ( alloy push rod ) to a tightish 0.004" and set the
ex valve the top one ( steel push rod ) to 0.005"
setting at 1/4 pst tdc eliminates decompressor from upsetting valve clearance seting
cheers pauly46
Mar 26, 2011 | Briggs & Stratton Garden
Engine wont start
go to youtube and type in valve adjustment on briggs,very simple procedure to do.
Apr 23, 2010 | Briggs & Stratton 66set Panzer Tractor...
Hard to start 18 hp briggs &stratton
cold engine
loose .002 exhaust
loose .004 intake
be sure both valves are closed and you are on top dead center TDC of the compression stroke when setting
Jun 21, 2009 | Briggs & Stratton Garden
Briggs and Stratton OHV V-Twin 24hp repetitive valve adjustment
Try pulling out the choke a little, if it stops backfiring the mixture is too lean, check the intake
pipes at the cyl head and also the plastic runners to the carb for leaks.
Dennis in Chicago
May 07, 2009 | Briggs & Stratton Briggs Stratton Intek V...
Garden Logo
492 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
