I have bad 1200 microfarad caps on my power supply of my 52 inch LG tv. Voltage ratings are 35V. I have some 1500 microfarad by 50 v caps that would physically fit in their place. Would these work in place of the 1200? I know voltage rating is ok.
  • 760 Answers
Do not use the 1500. One thing to remember about electrolytic's is this. The microfarad must be to spec. But you can always up the voltage. ie use a 1200 by 50V instead of a 1200 by 35V
Posted on May 20, 2011
Power source does not work. Wont turn on or off
Blown fuse or bad capacitor on the power supply. the set and remove the back panel. Locate the power supply. There is usually a fuse in line with the hot supply wire. Check it for continuity with an ohmmeter. Look for bulging electrolytic capacitors on the power supply. Electrolytics are polarized (+-) and can fail if they go even slightly overvoltage. Replace bad capacitors with components with the same microfarad rating but a slightly higher voltage rating. I.E. replace a 16 volt cap with a 25 volt cap.
Jul 23, 2014 | Magnavox 32mf231d
I have a KDL-55HX925. suddenly it turned off and standby led (red) blinks 2 times. I know it has problem in power supply. I turned it off and unplug for more than 1 hour but nothinh happened. I have enough...
Hi Sir Saeid Manzari,
Right, that problem is cause of faulty power supply..
The first thing I suggest is to open the back cover of your TV then find the power supply board (it is usually found connected directly to the power cord)..After you find the power supply kindly inspect the condition of all capacitors,commonly then faulty capacitors look like leak/bulged on the top but sometimes not and looks fine..
see this picture.
If you found any bulged capacitors kindly replace it only with the same value (microfarad/voltage) example 2200uf/35v means 2200 microfarad/35 volts..
If you don't see any bulged caps let me know to proceed other test to determine if the true problem is on the power supply or other board inside..
If that so please ready your multimeter tester for voltage checking..
Hope we find the real problem and fix it..
Just keep on touch!!!!
Thanks for using fixya and choosing my service!!!!
Regards,
Chester Pendilton
Jan 28, 2012 | Sony BRAVIA KDL-V40XBR1 40 in. LCD HDTV
My lg w2043 won't power on
The issue you describe is consistent with a power supply board issue. This is the board where the AC goes to. This problem may have occurred as a result of irregular power supply, or excess power supply or power surge.
The TV is receiving current but cannot circulate or transfer the current to other necessary part of the TV because of the defective power supply board. You might be lucky it's just a blow fuse. Also a defective transformer can cause your TV not to power on.
All these can be checked on the power supply board.
But more often bad capacitors causes problem on the power supply board. I do not think the power board needs replacement, rather those defective capacitors is causing this issue. Open unit up and take a look at the power supply board.You will probably see one or more electrolytic filter capacitors that are bulged up in the top-not perfectly flat like the others.
The value of these capacitors will be different, most likely they will be somewhere around-820 to 2200uF/25 V( or /10V sometimes)
You can replace them with same values but I would recommend the voltage rating to be higher(like 35V for an original 25V) for reliability purposes.
What happens is,these bulged top capacitors will cause a low and unfiltered DC voltage=main board will malfunction(the relay will keep clicking until the caps are holding enough charge to bring the voltage up over a threshold point).
You can buy these capacitors at any Fry's or Radioshack store or you can order them online at vendors like "mcmelectronics.com"(look for electrolytic capacitors). After replacing these capacitor(capacitors) most likely the normal operation will be restored. Or you can by a refurbished complete power board to save you some stress.
Note: There may be also some other causes for this symptom ,like a defective T con board ,or main board,but the bulged top capacitors are the most common cause for this issue.
If you don't know about TV repairers, take the TV to the nearest repairman to fix the fault for you. Also, note that TV stores a lot of current, so wait a while before opening the TV back cover.
I hope this helps....
Regards.
Apr 23, 2011 | LG W2042TQ-BF 20 inch Monitor
I have a RCA 52 inch HDTV model D52W20B when you press the power button the green power light flash about 3 or 4 times and that's it no sound no video. Everytime it flashes you can hear I guess the power...
On Deflection board CK capacitors cp150 2200uf 16v if it is puffed up on top it is bad their is 2 more caps in same circuit replace them also cp114 cp120 220uf 35v also resolder all pins on FBT flyback Transfomer
Nov 10, 2009 | RCA D52W20 52" Rear Projection HDTV-Ready...
Xerox WorkCentre M15i will not turn on. We had the problem last week, let it rest for 2 hrs and it would work again. this time an overnight rest didn't work. It is like it isn't getting any power. We tried...
You have 4 bad capacitors on the Power Supply. Replace C24 and C25 (100 microfarad 35v) Replace C12 and C21 (33 microfarad 35 v). It would be a good idea to replace them with a better voltage rating, maybe 50 volt electrolytic capacitors.
Aug 11, 2009 | Xerox WorkCentre M15i Laser Printer
My magnavox 37MF321D/37 will not turn on. It
I had the same problem with the blinking green light. These are the parts one the power supply I replace to repair it. note: If the power supply is repaired you will get a solid green light and the backlight will light up almost immediately.
Aug 01, 2009 | Philips Magnavox 50ML8105D 50" HDTV DLP TV
Power ligt blinks twice no high voltage
CK capacitors cp150 cp114 cp120 if cp150 is puffed up on top it is bad so replace all 3 caps.2200uf 16v and two 220uf 35v
Jan 16, 2009 | RCA D52W23 52" HDTV CRT TV
52 inch RCA
No, check cp150 capacitor 2200uf 16v if bubbled up on top it is bad ,you have 2 more caps to replace in same circuit if cp150 is bad cp114/ 220uf 35v -cp120/ 22ouf 35v they green with gold writing on them
Dec 20, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
CYBERHOME DVD RECORDER DVR1600
I cannot say this with authority, since I own a 1200 model, but from what I've read of that model researching my own it's most likely the power supply. It is repairable if you or someone you know can solder. Here's what I found:
http://cms-system.cyberhome-dvd-help.com/modules.php?name=Forums&file=viewtopic&t=2699
I did pretty much the same to my 1200, replaced two 2200uF caps with 35V versions. Make sure the rated voltage of the new caps is at least 16V! Higher is better. There's also a firmware update for that model, you might want to look into that too. Of course, you can't use it until this is fixed.
May 19, 2008 | Cyberhome DVD Recorder - DVR1600
NO POWER
Hi,sounds like a 2200 35v cap on the high voltage power supply,this board is the left one facing the back of the unit,the cap is located behind the u shaped heat sink it is green in color,if it is bad the top will be pushed up,make sure to unplug set before serving,hope this helps
Oct 03, 2007 | RCA D52W19 52" Rear Projection Television
Televison & Video Logo
54 people viewed this question
Top Televison & Video Experts
Electro Med Services...
