Question about Sanyo Televison & Video
My 32inch sanyo is not working at all just blue light on front flashing rapidly model number is ce32lc81-b
2 Suggested Answers
get-it-goin
  • 85 Answers
SOURCE: model ld3270d Indicator light rapid flashing
hi there.you will need some capacitors replacing on the power supply board.they arent expensive at pennies each...yuor local repair shop may do the job if you take them the board along...
or easy to do yourself with a little knowledge of electronics and a reasonble soldering iron!!
regards,steve
Posted on Oct 22, 2010
I have sourced out all fuses and bulbs, yet continue to have a rapid right turn signal. I don't know where else to look. help?
replace the right rear bulb. the quick flashing indicates a bad bulb. it could be a wiring problem to the rear for the signal light that you will have to check out starting at the socket and working forward.
Mar 29, 2015 | 2005 Chevrolet Uplander
I have a sanyo 32inch tv an it wont tyrn on it has the blue light but when I turn it on it just keeps flashing but flashing like the light is loosing power?
These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices. Viewing it in "Mosaic" or "Magazine" will make surf easy.
Blinking codes details to many popular brand TVs are given. Surf the site with patience.
Jul 31, 2014 | Televison & Video
Logik wireless mouse
1. Make sure the mouse is fully charged. The underside should have a red flickering light if it is working properly. If not you need to change the batteries.
2. Plug the USB dongle into the computer. The blue light should light up and flash rapidly as you move the mouse around. If it still doesn't work you need to re-sync the mouse with the dongle.
Turn the mouse off and back on again. Hold it near the USB dongle.
Push the blue button on the dongle. It should flash steadily. Push the reset button on the bottom of the mouse. The blue light on the dongle should start flashing rapidly and your mouse should now work.
Jul 30, 2014 | Case Logic EW-609 3-Button Wireless...
Why wont my logitech boombox go into bluetooth search mode
I had the exact same problem. Boombox flashing blue, but not rapidly flashing blue. I did two things that seemed to fix it:
1: Reset the device by switching it on, then holding both volume up and volume down buttons at the same time for 10 seconds. The blue flashing light will briefly flash quicker to confirm.
2: Switch off the boom box
3: Switch on using the power button and (very important) immediately press and hold the Bluetooth button. The Bluetooth button needed pressing and holding almost instantaniously after the power button for it to work for me. I had to try several times to get it to work.
When you do this successfully, the Bluetooth light starts flashing rapidly and it enters search mode.
I nearly threw my speakers away, now it works and connects fine :)
Oct 10, 2012 | Logitech Radio Communications
My sanyo tv stand by light keeps flashing and it wont turn on can you tell me whats up with it
i have 32inch sanyo tv i have blue light on front whitch comes on when on stand by it wount come of standby eney idears on how mutch it will cost to get fixed x
Nov 13, 2010 | Sanyo PDP-42H2W 42 in. HD-Ready Plasma...
Blue light flashes on front of tv cannot get set to turn on
my sanyo 37 inch was workin fine put it on the wall now the blue light on the front is flashin like mad screen wont *** on got the clicky sound as if i was turnin it over by the side any ideas ??
Aug 21, 2010 | Sanyo 42 in. LCD TV
My 32inch audiovox flatscrren will not come on but
Now in the front of the tv panel power blue light on and it solid green?Take ur tv aparts.The T-con board, this board sit in the botom in the middle of the LCD screen.This board is defective replaced it.Tries websites like Shopjimmy.com,Ebay.com to buy a refurbish T-con board for the replacement.
May 11, 2010 | Audiovox FPE3205 32 in. HD-Ready LCD...
ON/OFF & Time saver Button keeps flashing
For mine, it started flashing the on/off light along with the "drying high heat" and the "reduce crease".
Unplugging the unit for 30 minutes appears to have reset the machine and it is now working.
Aug 18, 2008 | Hotpoint Aquarius WD640 Front Load...
Pairing h700 to sanyo s1
After your phone has found the H700 you have to tell your phone to pair with it. It will then ask for the code. Punch in 0000 and confirm. After a little bit the H700 will flash blue several times rapidly and then start blinking about every 5 or 6 seconds. It is then paired with your phone.
Apr 21, 2008 | Motorola Mobility H700 Wireless Headset
Televison & Video Logo
20 people viewed this question
Top Sanyo Televison & Video Experts
 Grubhead
Grubhead
Are you a Sanyo Televison and Video Expert? Answer questions, earn points and help others
