Question about Sewing Machines
Manual for seammaster model sm1100 - Sewing Machines
I requested service manual and parts manual for pfaff creative 7530 sewing machine but you sent me a link for user manual
Service manuals are difficult to find as they were not intended for the general user. You can search for: Make Model service manual or Make Model repair manual
A manual for a similar model will probably be helpful if unable to locate the one for your model.
Jan 24, 2018 | PfaFF Sewing Machines
Does my seammaster model 6950 do straight stiching or only zig zag?
Looking For Seammaster 6950 Users Manual Can You Help
If it looks like these photos, then it is capable of zig-zag and some other decorative stitches:
Vintage Seam Master Sewing Machine Model 6950 149 99
You also may want to talk to these guys about using the Simplicity manual for your machine:
http://www.sewingpartsonline.com/instruction-manual-simplicity-sl6950.aspx
Sep 18, 2017 | Sewing Machines
I have a Seammaster machine Model # 6950. I bought it with now book. How do I adjust the tension on the bobbin?
Here are some instructions regarding tension adjustment. However, before you try changing the bobbin tension, I suspect that it is the top thread creating the mess of thread. REMOVE the top thread from the machine, ALWAYS RAISE the presser foot, and rethread from the beginning.
Understanding Thread Tension Threads
There are some manuals available for purchase for your machine. Search for Simplicity Seammaster 6950.
Aug 04, 2017 | Sewing Machines
Hi I am having problem with my sewing machine. Thread gets all tangled up on the bottom of the fabric... My husband is very smart about machine and needs just suggestions from you.
That is called bird nesting or thread nesting and usually results from: mis-threading, thread not seated fully in the upper tension disk, or upper tension too loose. (Mis-threading may not be a user error--sometimes the thread will "jump" out of thread guide or the take-up lever.)
Remove the thread from the machine. ALWAYS RAISE the presser foot and rethread from the beginning. Verify the thread path is correct. Set the upper tension at the midway point between high & low number and retest your machine. The upper tension will probably need some tweaking for your particular machine, but the mid-point is a good place to start.
Birds nest under the fabric big loops of thread top side looks good...
What causes Bird Nests Superior Threads
Tutorials Urban Threads Unique and Awesome Embroidery Designs
Jan 12, 2017 | Sewing Machines
Need a manual for seammaster sewing machine model sm1100
Search the internet for:
Manufacturer + Model + the word "Manual"
Jan 15, 2016 | Sewing Machines
Need the manual for model 534?
SINGER 534 MANUAL Pdf Download. - ManualsLib
www.manualslib.com > Brands > Singer Manuals > Sewing Machine > 534
View and Download Singer 534 manual online. Stylist Sewing Machine. 534 Sewing Machine pdf manual download.
[PDF]White Sewing Manual Model 534
www.masepmadit.com/white-sewing-manual-model-534.pdf
vw instruction manual, white 534 serger: sewing parts online understandable ... techmanual white superlock serger model 534 repair manual compiled pdf.
Jan 07, 2016 | Sewing Machines
Seammaster #6950. Where can I get a manual?
Dec 14, 2015 | Simplicity Sewing Machines
Need manual for seammaster sewing machine
Seammaster Sewing Machine manual - ManualsOnline.com
www.manualsonline.com/.../sewing.../seammaster-sewing-machine-manu...
Question About Simplicity Sewing Machine N71488649. Seammaster Sewing Machinemanual... Asked by Cassia Curtis on 10/26/2011 0 Answer.
Oct 07, 2012 | Sewing Machines
I need manual for singer machine model #50t8 e99670
Singer Sewing Machine labels are printed in a confusing manner. E99670 50T8 is not the actual Model Number. The actual Model Number is the first 4 digits on the line with the Serial Number. In my case, the Model Number is1525, even though E99670 50T8 appears on the label at "Model Number". This machine was also labeled with other 4 digit model numbers too, depending on when it was manufactured. Using the Singer link for either free downloadable manuals, or paid paper manuals, search for the correct 4 digit model number and the resulting correct manual is there. Link below for manuals :
http://www.singerco.com/accessories/manuals.html
Sep 04, 2012 | Singer Sewing Machines
I have a necchi - singer - dressmaker ero-pro-seammaster serial #5854 model 6800 how do I find a book for this ?
I called my local library researcher and they found what I needed.
thanks so much
carla
Jan 29, 2010 | Necchi Sewing Machines
Sewing Machines Logo
473 people viewed this question
Top Sewing Machines Experts
Tally Girl
Tally Girl
Are you a Sewing Machine Expert? Answer questions, earn points and help others
