Question about Xerox Phaser 7400/DXF Laser Printer
No display on machine.. ... tried the on off switch but no result.. red light stays on.... printer still works .. test copies come out and still prints from computer
  • bobbydazler Aug 15, 2008
    display does light up but nothing.. text etc appears
I Found that by holding the top left cover when switching on the machine the display appears... i think i have a loose connection and i will dismantle the cover and find out.. i will let you know how i get on
thanks again
bobby
Posted on Aug 21, 2008
    President:
  • 2,072 Answers
Sounds like the display backlight has failed. Need to replace the display.
Posted on Aug 15, 2008
  • Rick Kasper Aug 15, 2008
    Ok thats different then what I understood you to mean by no display.
    Have you taken the display off and just disconnected and reconnected the cables to the display. All of them that run to or are part of the display. Those mostly are communication cables for the display. Also track them back if you can to the main board and reseat them at that location. I have seen those connectors just be loose frequently when you get no message on the display but machines operate.
    I am sorry , when I read your post, I assumed a simply dead display. Still possible that the display itself is bad, but since you see the display lighting the power supply is working to and on the board.
    Try the connections and see what happens. If it was software related you would see gibberish. Just letters and numbers that mean nothing. Even just astrisks and solid blocks. If it was relaved to the non volitle memory the display would just show solid black blocks about a quarter inch square in about 8-10 rows.
STAYS ON RED AND KEEPS SAYING PLEASE WAIT AND REVERT BUT NOTHING HAPPENS
What kind of machine? This type of error would suggest that the machine is not able to complete the self test on startup.
Dec 07, 2014 | Office Equipment & Supplies
Hi dear sir I have Ricoh 700 machine it was working fine but yesterday it's got some problem when I switch on its showing ready when i make the copy its scan the paper but not print stay on same place but...
You should try resetting the machine if you can. Taking out power cord will not reset machine. The micro chip has to be reset on the machine. If test / counter print works but copy doesn't work, then reset machine.
Nov 26, 2014 | Office Equipment & Supplies
I have a Canon MP830 & I can't print or send a fax Error message 300 - I can't turn off the printer - & it says I have 10% in memory. it is also making a clicking noise
Error No. 300 :
Cause 1: The machine is not ready.
Action : Ensure that the lamp on the Operation Panel lights.
If the lamp on the Operation Panel is off, turn the machine on.
While [COPY] is flashing, the machine is initializing. Wait until [COPY] stops flashing and stays lit.
When the Alarm Lamp lights orange, an error may occur in the machine.
Cause 2 : Machine is not proper connected.
Action : Ensure that the printer cable is securely connected to the computer/
* If using a switching hub or other devices, disconnect the machine and reconnect it directly to the computer and try printing again. If successful, the problem may have been with the device.
* There could also be a problem with the cable(s). Replace the cable and try printing again.
Cause 3 : The name of the machine being used is not selected in the [Printer] pull down menu of the [Print]dialog box.
Action : Select [MP830] from the [Printer] pop-up menu in the [Print] dialog box of the printer driver.
If the [MP830] is not displayed in the printer list, follow the procedure below to confirm the settings.
1) Select [ Print abd Fax Preferences] from the [Printer] pop-up menu.
2) Check that [MP830] is displayed in the screen that is displayed and select the [InMenu] checkbox.
3) If [MP830] is not displyed, click [+] to add a printer.
If [MP830] is not displayed, install the MP Drivers again referring to the Easy Setup Instructions for the operations.
Hope this helps. Please rate my response.
Thanks.
Have a good day.
Nov 23, 2009 | Canon PIXMA MP830 All-In-One InkJet...
Red light
if the oil light is staying on it could be one of many things ,it could be a very cheap oil presure switch or something very expensive if it is an oil pump failure.start with doing an oil presure test . presure should be 14 to 57psi(2.0to5.0bar)@3000rpm. oil at 60c
if all is ok check cable going to switch for breaks or touching frame and shorting out,if thats all ok next change oil presure switch . if the test do not produce the results to spec then the right hand side off engine will need be striped down to replace the oil pump and inspect the internal engine componants for oil starvation damege which could result in a complete engine overhaul. i would not be using the bike until repaired. engine seizer can result in an accident.
Sep 11, 2009 | 2003 Suzuki GSX-R 1000
Hp 2115 - clicking noise from carriage, can`t print test page
I have an HP 6110 is always has a grinding noise.No functions work. HP just want me to buy a new machine. They are bad quality 3 in one's. That is for sure.
Jun 28, 2009 | HP OfficeJet 6110 All-In-One InkJet...
Lexmark 6100 will not unlock after unlock procedure is done.
Thank you for contacting Fixya.
Please ensure that the scanner is unlocked. The scanner lock is situated under the scanner bed towards the left. To unlock the scanner, please lift the scanner bed and push the red switch towards the back of the machine. Please try scanning again and let us know the results.
If the issue still persist, please follow the steps given below:
1. Press "Copy" button.
2. Press "Options" till the display reads "Set Defaults."
3. Use the "Arrow (right/left)" buttons till the display reads "Use Factory."
4. Press "Select."
Please let us know the results.
Sincerely,
Jeeth
Apr 15, 2009 | Lexmark X6170 All-In-One InkJet Printer
Toshiba 2860 Plain paper copier
It maybe the waste toner container is full try emptying it
Feb 19, 2008 | Toshiba 2860 Copier
Solid red light after flashing firmware
These are the 3 things listed as being wrong for the status light being solid red:
1. Media is out. Reload a new supply. Press feed button to
continue.
2. Power-up failure. Switch power OFF then back ON.
3. Printer ready to receive flash programming during
firmware download.
There's a programming manual available for download on Zebra's website: https://www.zebra.com/id/zebra/na/en/index/resource_library/manuals.results.html
It might help.
Feb 15, 2008 | Zebra LP 2844 Thermal Printer
Xerox Phaser 7400/DXF Laser Printer Logo
248 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Whit
Whit
Level 1 Expert
iteminconline
CheckitRight
CheckitRight
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
