Question about Microwave Ovens
I have a microwave mounted over my stove. It is wall mounted under a cabinet. How do I remove it from the wall? Please advise
  • luciano gonzalez May 21, 2011
    Thank you I will do this, if I find something different I will contact again. For now this should do. Thanks.
  • 4,323 Answers
Hi
First make sure the microwave is unplugged, and then locate the two bolts connecting the top of the unit to the top of cabinet. After this use your wrench to remove the bolts and then remove two more bolts located at the back connecting the microwave to the wall mount. After this remove the front access panel of microwave. Then find the two bolts directly behind this access panel, after these are unscrewed the microwave can be removed from the wall, at this point make sure to take help from someone so that he/she can support the weight of microwave as you remove the bolt. Hope this helps...please post back for further assistance.
Daniel
Posted on May 20, 2011
How do i remove a over the stove microwave?
On a 1-10 scale- this is a 2.
place a cardboard box on the stove to support the microwave once it is free.
Remove power cord from the outlet in the cabinet over the microwave.
In the cabinet over the microwave, locate the 2 mounting screws.
Loosen each one about 6 turns- the microwave should drop down in the front by about 1/2 inch.
Once loose, you can remove both screws completely and allow the front of the oven to rest on the cardboard box.
While supporting the front of the microwave,have a helper remove the cardboard box.
Tricky part...while supporting the front - angled slightly down, lift hard under the rear of the microwave and pull toward you.
Have a helper feed the power cord through the upper cabinet bas as you bring the microwave toward you and slightly down.
Place the microwave on the counter- with a towel in place to prevent scratching the counter.
remove the rear-wall mounted support bracket.
Done
Apr 27, 2014 | Maytag MMV4205 Microwave Oven
Instalation Instructions for Frigidaire Over the Range Microwave 850 Watt Model #FMT118EPB
HI,
Frigidaire makes several over-the-range microwave models that are all installed in the same manner. To install correctly, you must have at least 45 1/2 inches from the bottom of the top cabinet to the cooking surface of the stove to provide enough clearance for the microwave. The top cabinet must also be at least 30 inches wide and 12 inches deep. Find someone to help you, then follow the steps below to install your Frigidaire microwave.
Things You'll Need:
  • Stud finder or hammer
  • Screwdriver
  • Drill
Instructions
Pull your range away from the wall so you can work comfortably. If this is not possible, cover it with a drop cloth. Find and mark the locations of the studs in the wall behind the range. They will be either 16 or 24 inches apart.
Follow the instructions on the wall template to mark the location of the mounting bracket and the four anchor holes on the wall and the bottom of the cabinet. Drill the anchor holes. Follow the instructions on the top cabinet template to mark and drill the two holes in the bottom of the cabinet.
Attach the mounting bracket to the wall studs using the six wood screws included with your microwave. Screw the toggle nuts onto the toggle bolts and push one through each of the four drilled holes. Screw each toggle bolt until the nut is snug against the inside of the wall.
Pick up the oven with your helper. Plug the oven into the outlet and slide the oven onto the mounting bracket arms. Push the oven back against the wall. Tighten the two screws on the microwave faceplate to fasten the microwave to the mounting bracket arms.
Attach the louver to the top of the microwave with the three provided screws. Insert the two top cabinet screws and washers from the top cabinet into the microwave and fasten tightly.
Take care.
Jun 16, 2010 | Frigidaire Microwave Ovens
Who makes a microwave oven that mounts in an
Why can't you use the wall plate? Even if you had to use construction adhesive it would be better than nothing. If you are installing in an island setting then you will have to reinforce the cabinets as they would have to support the weight of the micro.
Eric
Oct 01, 2009 | Microwave Ovens
Remove a whirlpool over the range microwave oven
Jim here. In cabinet above microwave, locate 2 mounting bolts.
Place a box on the stove top to support the microwave once the mounting bolts are removed (you may wish to cover the box with a thick towel or small throw rug).
Procedure:
1. Unplug microwave.
2. Remove both mounting bolts from top of microwave (they secure it to the overhead cabinet).
3. With microwave front angled down onto box, pull some of power cord out of hole (to provide some moving space).
4. With microwave hand supported, remove box from stove top (a second set of hands would be helpful here).
5. HARD PART- detach top of microwave back from wall mounting plate by placing a hand under the bottom rear of the microwave and pushing up. (Wall mounting plate is screwed into the wall behind the microwave and provides both top and bottom support to the back of the microwave.)
6. Lower front of microwave until you can see about a 1-inch clearance between the top-rear of the microwave and the cabinet above it.
7. Firmly lift the microwave straight up and then bring forward. It should be free of the wall mounting plate.
Sep 30, 2009 | Maytag MMV4205 Microwave Oven
How do I install a replacement Frigidaire over the stovetop microwave - professional series, without removing the cabinet above it? I need to know how to best remove the existing microwave.
Remove everything from the inside of the microwave, (such as glass tray). Unplug the microwave, probably in the cabinet above. There are two screws in the cabinet above the microwave, near the front, that supports the front of the microwave. The back is hooked on a mounting plate attached to the wall behind it. An assistant is a good idea though this can be accomplished alone. It is best to move the stove out, if you are going to try alone. Please be carefl there is considerable weight to support here. Support the front of the microwave while the two screws are removed in the cabinet above. Slowly tilt the front of the unit down until you can pull the cord out of the bottom of the cabinet. With the front still tipped down, lift the back from it's support and remove it.
Jul 18, 2009 | Microwave Ovens
How do I remove Frigidaire FMV156DCC under cabinet microwave?
Underneath the microwave, on the right & left hand corner sides at the back, there are levers that you pull down & it releases the mounting bracket.
Jun 25, 2009 | Frigidaire FMV156DC Microwave Oven
How do I remove an old wall mounted Microwave.
I just removed mine this morning and was having the same problem, though mine did have the screws above going into the unit. You may have to pop the front vent cover off to locate the screws going to the wall bracket, if so remove those. Also,there are 2 tabs on the bottom of the wall bracket that the back bottom edge of the microwave slip into, keeping the microwave from being pulled forward. Tilt the microwave slightly forward and push the bottom back edge of the microwave up to clear the tabs. Hope this helps.
Mar 12, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
Wall mounting needed for a top mount microwave/hood combination Whirlpool Model MH2175SB1. The cabinet above the stove is too flimsy to support the heavy microwave (50-60 pounds). Called Whirlpool. Sent me...
Is there a wall behind where the microwave is to fit?
Most of these ship with a mounting plate and instructions for mounting to the wall. In fact, the wall bracket carries about 1/2 the weight, and the overhead cabinets carry the other half. The plates come with a good set of instructions for how to install.
Whirlpool is sending you to a distributor because they have to watch liability in this litigous world we live in..
Jan 29, 2009 | Whirlpool Microwave Ovens
HOW DO YOU REMOVE AN OVER THE STOVE GE MICROWAVE ?
open doors of your cabinet above the microwave, look carefully toward the front you will see two screws one on either side, remove theses screws while a helper holds bottom of microwave, after screws are removed lift up on rear of microwave it will slide up and out of a rear clip mounted on the back wall. remove wall bracket and job is complete. oh yeah unplug microwave, or turn off circuitbreaker first. easy as 1, 2, 3. hope this helps.
Nov 05, 2008 | Microwave Ovens
1985 GE Microwave Spacesaver Uninstall
A possible solution:
I was facing the same problem with my (1998?) GE JVM48006. In this models case, the microwave was housed in a support cabinet that was fastened to the wall behind. First, I removed the phillips head screws behind the louvered vent above the microwave. Then, I removed the screws of the slanted bottom panel that give access to servicing the stove top lights (underneath the unit) which were integrated into the support cabinet (separate from the microwave itself). On the right side was an electrical wire harness hidden behind a cover that had to be unplugged (similar to a car wiring harness). Then, I removed (4) 5.1/2 inch hex head bolts that secured the unit through the cabinet above. Now I was able to slide the microwave out towards the front (with some rocking back and forth). All that was left then was to remove the support housing (fastened to the back wall).
Aug 01, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
Microwave Ovens Logo
100 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Are you a Microwave Oven Expert? Answer questions, earn points and help others
