Question about Dryers
I HAVE A YUHCHANG 3 WIRE CAPACITOR THAT I NEED TO REPLACE AND I DO NOT KNOW HOW TO WIRE IT
3 Suggested Answers
carldc3
  • 82 Answers
SOURCE: I NED TO CONECT 3-1 RELAY OVERLOAD CAPACITOR IN MI FRIDGE
first take all the relays and capacitor off of compressor , then attach black wire with terminal on "C" terminal post usually top terminal, white wire with terminal goes on "S" terminal post on compressor, red wire with terminal goes on "R" terminal post on compressor. then take the two black wires one connects to white neutral wire and the other connects to the black power wire if tis fridge has a condensor fan then you will also need to connect it two the two black wires also thanks hope this helps
Posted on Jan 23, 2009
  • 92 Answers
SOURCE: just replaced a rheem oem 1/6 hp motor 3 wires
green wire cut off if motor is held on with metal bracket.white/yellow to contactor,black to other side contactor. brown/wht to fan on capacitor,brown to common on contactor NOT HERM.
Posted on Jul 10, 2009
I need the wiring diagram for a Nordyne GS3BA-024KA condenser
3 wires for compressor, 3 for fan. 2 comp. wires go to the top of the contactor, the remaining goes to herm terminal on capacitor. 1 fan wire goes to the top LEFT of contactor, remaining 2 go to com and fan on capacitor. You will then have 1 wire left that goes to the com on the capacitor and should go back to the top RIGHT of the contactor. NOTE: IF YOUR FAN MOTOR IS RUNNING BACKWARDS (MEANING AIR IS NOT BLOWING OUT OR UP) swap the to fan motor wires on the capacitor (fan and com) this should reverse rotation. ALWAYS REMEMBER TO TURN POWER OFF AND DISCHARGE CAPACITOR BEFORE TOUCHING WITH INSULATED SCREWDRIVER. Good Luck!
Apr 22, 2017 | Heating & Cooling
NEED TO REPLACE THE 3-SPEED PULL SWITCH. IT IS STUCK ON HIGH. CAN U PROVIDE ME WITH A REPLACEMENT SWITCH. PLEASE ADVISE. THANX RANDY DUERR
I would need to know how many wires on your capacitor & what color wire goes into which slot on pull chain.
Sep 29, 2015 | Dryers
Will replacement motor 266520 fit SGS53E72EU/71 Bosch dishwasher
The motor for that model is 489652, I think you'll find that the two middle tags on the original motor are linked and one of the original wires has a smaller spade connector so can only go on a specific connection. As for the cap can you use the coupling from the old one?? What are the symptoms to need to replace motor?
Mar 13, 2013 | Bosch Dishwashers
Unsure of capacitor terminations for ao smith condensing fan moto
Does the motor data plate say anything about the motor. You can hook up a motor like yours with 3 wires. First use an ohmmeter and check the resistance between the brown/white wire to the black then the yellow wire. The resistance between brown/white and one of the others should be pretty much 0 ohms. If not check between the brown wire and the black and the yellow. Which ever wire has 0 ohms with the brown/white wire is the common leg. You can put a wire nut on the brown/white, it will not be used. Next the brown should be for the start winding and the other wire left over will be the run winding. Then connect the common to L2. L1 will go to the run winding and one side of the capacitor and brown will go to the other side of the capacitor. I hope this isn't too confusing. Let me know if I need to explain it better.
Jun 09, 2010 | Heating & Cooling
Replacing a motor run capacitor for my heat pump
First turn the power off. Next look at the capacitor on the unit already and make sure that they have the same rating. Next, how many terminals does the capacitor on the unit have. 2 or 3? If it has 2 then you only have to worry about keeping wires that go to the same side together. If it has 3 they will be labeled Com, Fan, Herm. Take note of which wires go where as they must go back on the correct terminals. Let me know if this helps or if you need more information.
Jun 08, 2010 | Heating & Cooling
Diamond wire diagrams for capacitors 3 0 farad
i think you mean you want to know how to wire 2x 3.0 farad 12V capacitors into a 24V truck??????? let me know i can help with this,ben
Aug 13, 2009 | Car Audio & Video
Schematic missing - need to know which cond unit
Black wire goes to contactor. On your capacitor the brown wire goes on one side the blue and the other wire from your contactor goes on the other sideof the capacitor. Russ
Aug 07, 2009 | Heating & Cooling
Just replaced a rheem oem 1/6 hp motor 3 wires with a 1/3 hp 5 wire. Need help with wiring diagram. A.O. Smith 1/3 hp to capacitor
Jul 07, 2009 | AO Smith 2 HP 115/230V 56C Replacement...
Must Wire replacement Capacitors
First, main power off and use an insulated screwdriver to touch each terminal on the capacitor to the casing (they can hold a charge) The capacitor has 3 terminal marked C, F, H - 2 The wire from the fan goes to F, the wire from the compressor goes to H and a wire coming from the contactor goes to C. For the start capacitor, if it has 2 wires, it goes to the H and C terminals on the main capacitor. If it has more wires, let me know. Ron
May 06, 2009 | Heating & Cooling
Jan 23, 2009 | Kenmore 50522 / 50524 Side by Side...
Dryers Logo
114 people viewed this question
Top Dryers Experts
