Question about LG LSC121PMA Split System Air Conditioner
My Lg split AC shows "Lo" in place of temperature. The fan symbol and compressor symbol is blinking. In LG web site the problem described as 'system is in testing mode' and no problem with the Machine. But machine is not working. Kindly let me know how to fix it.
  • 400 Answers
SOURCE: WATER LEAKING FROM MY SPLIT TYPE LG AIRCON
1. Do not set the aircon too low temperature in overcast weather, this will cause ice ups and water dripping. Optimal comfort zone temperature is 24c.
2. You need to open the grill cover on the front of the aircon which unclips either end left and right with a finger pressure. You will find two filters which can slide out and should be cleaned. First tap them together to remove dust, then you can wash them with mild soap and cold water.
3. There is the third possibility that an insect has made a nest in the drainpipe. You should look on the outside of the building and locate a plastic drainpipe. You can either blow into this pipe with your mouth or get a blower. This will unblock any restriction in the drainpipe.
Goodluck and ratemeplease.
Posted on Mar 19, 2009
SOURCE: error ch 5
check all wiring and connections - ch 5 is a communication error between the indoor unit and the outdoor unit......
Posted on Dec 16, 2007
bobotfel
  • 236 Answers
SOURCE: air conditioner remote
here are some icon meaning, this may help.
Posted on Apr 28, 2008
  • 30 Answers
SOURCE: lg split system ch 05
Solution # 1, Check Condensor Fan Motor Capacitor 4uf or MFD
# 2, Check Motor Windings
# 3, Check Relay OR Defination Contactor
# 4, Check Connection Terminals
hope will help u 2 solve this
GOOD LUCK
Posted on Feb 16, 2009
  • 400 Answers
SOURCE: Thermastat on LG Split system
The star with a face is sleep mode, each time you press it you will see a 1 then 2 then 3 up to 7 appear in the lower right corner of the screen. This means that the unit will operate for 1 or 2 or 3 hours then switch off. The house with key if pressed will give you the actual room temperature assuming the remote control is in the same room. It will return to setpoint temperature in a couple of seconds. The triangle with face is termed "Chaos mode" The unit will stay on a preset temperature probably 18c but the airflow will vary and the louver will go up and down irratically or randomly, as it tries to immitate a natural breeze. The fan only button will put the unit into fan mode (no compressor driven cooling), the fan icon with circle around is for fan speed which goes up each time it is pressed. Hope this helps.
Posted on Mar 05, 2009
How may capacitors are there in LG split ac 1.5 ton unit
At least 3. 1 on the inside unit fan, 1 on the outside unit fan and 1 on the compressor. The outside unit may have both in a single chassis.
Aug 15, 2016 | LG Electronic Window Air Conditioner
Hi my lg inverter v is blinking lights when I switched on and not heating. when inspected out side, found the unit was buried in snow. so, I tried to switch on after clearing all snow and the fan too...
PDF]DEFINING COMMON ERROR CODES
www.lg-dfs.com/.../DFS-TP-AG-001-US_012H29_LGTechPaper_Error...
Aug 29, 2012 - Art Coolâ„¢ Mirror High-Efficiency Single Zone Systems ... Refer to Service Manuals posted on www.lg-dfs.com to troubleshoot ... Location of light-emitting... No. of Times Indoor Unit LEDs Blink ... Inverter compressor DC voltage is too high.... unit inverter compressor PCB heat sink temperature is too high.
[PDF]"Universal" Split Systems - LG Comfort Cooling
Jan 23, 2016 | LG Heating & Cooling
How do I get my LG 12000 BTU ac/dehumidifier to dehumidify
This is a quote from the manufacturer.
Dry mode is used to remove humidity from the room
without additional cooling. Once the set temperature
is reached, the compressor and circulation fan turns
off and only the exhaust fan will run. Fan speed is
pre-set and cannot be adjusted.
Apr 24, 2011 | LG LP1200DXR Portable Air Conditioner
Hi. I recently installed 1.5 T, 3 * Split AC, LG. Whole day the AC works fine and no problem in cooling too. But once in 2 day outdoor unit start making thudding noise continously and does not stop for 4...
Hello
Sounds like the compressor is shuting down on high heat.There could be a couple reasons for this.
1 Check that proper voltage is being supplied to compressor.
2 Freon level may be low.This would be a service call.
3 Bad or intermitent connection at thermostat.
4 Main contacts to compressor sticking,usually burnt or pitted.
Apr 08, 2011 | LG Heating & Cooling
I have a "cl"or "c1"
C 1 means indoor thermostat sensor defective.
Dec 11, 2010 | LG LA185HV Split System Air Conditioner
Jan 21, 2009 | LG LSC121PMA Split System Air Conditioner
Thank you. there are some other signs i don't know about.
The black triangle means AUTO, means the fan speed adjust by itself from high-mid-low speed depending in room temperature but the unit is cooling for this function the same COOL mode. Plasma is in the remote control but it never mention in the manual.
If the unit dont cool check your temperature setting and mode setting it should be in cool mode and temperature setting should be 18C. But if still don't cool check some error code like blinking light at the indoor panel check how many blink appears to get the correct error code.. If the light is blinking 3 times it means that the room air or coil sensor is defective.
abc4048.jpg.
Apr 28, 2008 | LG LSC121PMA Split System Air Conditioner
Heating & Cooling Logo
1,561 people viewed this question
Top LG Heating & Cooling Experts
Tim Whalen
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you a LG Heating and Cooling Expert? Answer questions, earn points and help others
