Question about Kenmore Top Freezer Refrigerator
My fridge will not turn off. I have to manualy turn the thermostat to '0' then turn it back to 2 or 3. It is freezing all of my food. Help please!!
    Sergeant:
    Champion:
  • 257 Answers
Make sure both the thermostats stay on Marked recommended setting, should be somewhere in the middle. check your freezer setting in the back of freezer wall, it should be open to allow the cold air in to the freezer and not forced down to the refrigerator. Make sure your freezer vent is not blocked by a bag of frozen vegetables or something similar. This will have the same effect as the vent being closed forcing the cold air down to the refrigerator.
Posted on May 20, 2011
Whirlpool 6wmv43ns/02 Fridge Too Cold & Freezing Food
I would first try replacing the control in the fridge. If that doesn't remedy the situation, I would try replacing the thermostat next.
May 14, 2012 | Whirlpool Refrigerators
Amana BB20VE - Food Freezing in Crisper
Have you checked it's not in fast freeze mode, and that the setting on the thermostat is about in the middle?
Apr 18, 2012 | Amana Refrigerators
Why does the fridge part of my zanussi freezone fridge/freezer, keep freezing the food?
Hi,the problem you are encountering is as a result of the fact that the thermostat which regulates the cooling temperature in the fridge/freezer is bad hence there is no regulation of the cooling temperature in the fridge/freezer section, hence the food in the fridge freezes up.
The solution is to replace the thermostat of the unit,here is how you go about it;
1.You have to disconnect the fridge from the power source.
2.Locate the thermostat at the bottom of the unit,at the top left corner above the condenser.
3.Now you need to locate the wire ends or wire harness and unplug them.
4.Replace the thermostat,reconnect it back,put the back cover back and you have completed the job.
Take care of yourself
Jun 24, 2010 | Hoover HCA390FFK Bottom Freezer...
Fridge freezing up
Check the fridge sensor. On my Hoover HNMF2805AL80 f/f, first I replaced control module - still freezing.
Have just replaced cheap fridge temperature sensor. Part No. 97061619. Trouble is you have to cut into insulation at back of fridge to replace. I just plugged in sensor & placed inside fridge at back at the bottom - so far so good, only lettuce freezing now, everything else v. cold but not frozen. :)
Jun 02, 2010 | Hotpoint RLA50 Refrigerator
Idesit BAAN134 PSUK fridge keeps freezing food . The fridge part of my tower f/f keeps freezing food even though I have turned the dial down to the minimum the temperature regularly drops to below...
If it is an electronic thermostat it could be that the engineer has changed the board but not the sensor which reads the temp. If it is a mechanical thermostat it may be hes fitted the wrong type.It could also be that the system is short of refrigerant and the actual refrigerant charge is not getting all the way to the thermoststs sensor to switch it off, the back wall of the fridge should be frosted at least 3/4 of the way down and not just forming in a small part of the fridge.
Jan 05, 2010 | Refrigerators
Fridge is freezing everything!
There is a flap that directs the air from freezer to fridge. Sometimes this flap can stick Or the actuator that controls the flap can go out. Same with autodefrost timer which seems to give a lot of people trouble. Thermostat is at the top, uncirculated cold air sinks, food in the bottom of the fridge freezes.
Sep 09, 2009 | Frigidaire FRS3R5EMB Side by Side...
Fridge problems
There is a damper between the Freezer section and the Refrigerator sections. If the damper is open to much the refrigerator will freeze up and it will freeze food. Find this damper and close to about 1/2 way.
The Thermostat is seperate make sure this is set around the middle setting. If the thermostat is bad it can cause the refrigerator to also freeze. Turn the dial down and listen for the compressor to click off. then wait a few minuites turn it up and see if the compressor come back on. If you turn the Thermostat all the way down it will shut off with the switch. not shut off by satisifying the temp. so just turn it down slowly and see if it is working.
May 20, 2008 | Hoover HCA390FFK Bottom Freezer...
Fridge is freezing food
YOU HAVE A BAD THERMOSTAT,REPLACE,MAKE SURE DRAIN IS CLEAR TO,THANKS-MIKE
May 07, 2008 | Candy CPCA240FFK Bottom Freezer...
Fridge of Fridge/Freezer keeps freezing contents.
all the food going to ice temperture at 2
Oct 24, 2007 | Refrigerators
no more than likely that your thermostat is faulty all f/freezers have 2 stats 1 to keep fridge cool and 1 to the freezer u will need to replace the 1 in the fridge m8
Aug 15, 2007 | Hotpoint FFA60 Bottom Freezer Refrigerator
Kenmore Top Freezer Refrigerator Logo
125 people viewed this question
Top Kenmore Refrigerators Experts
Sal De
Jim Goldsmith
Jim Goldsmith
oldblindman
Level 1 Expert
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
