Question about Zadro LED Lighted Vanity Mirror (1X 10X) Model . LEDV410 ()
Lately my mirror turns on sometimes, but not others. I checked the bulb and it is fine. I thought the problem might be the switch and if I left the mirror on and just unplugged it, I could circumvent the problem but that doesn't work.
It might have something to do with the outlet you're putting the switch into. It could be too lose, or maybe there is some type of short.
Posted on Jun 02, 2011
  • Needfixya Jun 02, 2011
    Thanks, but it's not the outlet since it happens in various outlets. Also, if I bang on the sides just right, it will turn on. It usually takes several tries.
My left front blinker flashes quickly. - The left
Check for power at the socket. If there is no power I would suspect the flasher relay wich supplies power to each bulb individually after it gets the right or left signal from the switch.
Sep 08, 2013 | 2007 Toyota 4Runner
Right turn signal will not continue to tick.
Check your bulbs. Almost always your description means a bulb is burned out. Check for good grounds.
Jan 24, 2013 | 2003 Chevrolet Silverado 1500
My left brake light and brake light over the tailgate stopped working on my 2008 Aspen. I replaced the bulb on the light over the tailgate and it works fine now. However, I also replaced the bulb on the...
Sometimes the wiring will go bad in the light assembly check all fuses under dash and under hood. sometimes have individual fuses for each tail light. otherwise check wiring.
Jun 28, 2012 | 2008 Chrysler Aspen
Hey I own a 2005 sportster 883C. I have turn signal problem, thouhgt if anyone can help. When I turn the ignition on only the left side flashes, so I thought maybe its fuses. I checked...
although you can cancel the left turn signal there you could still have a faulty switch which is not turning on the right side signals
also have you checked to see if the bulbs are bad, as sometimes a short can blow both front and rear bulbs
Aug 04, 2011 | 1993 Harley Davidson XLH Sportster 883
When you switch the left turn signal it doesn"t
first check the bulb to make sure the filament isn't dangling and making contact every so often, if its fine, check the socket for the bulb to be sure that its grounded correctly and both connection points are seating in the socket good
May 31, 2011 | 2003 Chevrolet Silverado 1500
Where is the turn signal flasher located?
You more likely have a bulb that is no good. The next time your signals aren't working, pull over and check to see which bulb isn't working. Make sure the turn signal is on while checking. It should only be the left or right. Not both. Sometimes you can see the blown bulb with the hazards on depending on your model vehicle. Simply check the bulb thats not blinking for a tight fit. Then replace it if thats not the cure.
Apr 30, 2010 | 2006 Chrysler Town & Country
2003 Ford Explorer Sport rear turn signal acting up
if it's only the rear turn signal that does this, check the plug where the bulb snaps in. if loose or bad connection to bulb, it will sometimes work and sometimes not. if its both the front and rear turn signal bulbs, could be the combination switch. these were common failures on fords
Feb 18, 2010 | 2003 Ford Explorer Sport
My head lights wont turn on every other light works. cheak the fuses and the light bulbs and there good
Try replacing the fuse sometimes fuses look good but they really aren't try two to three other fuses seems to be a commen problem lately. just a thought
Aug 13, 2009 | Ford Taurus Cars & Trucks
Turn signal
check the bulbs closely sometimes it seems they are working correctly but the rear may have two bulbs and one is out
Nov 13, 2008 | 2006 Mercury Monterey
Zadro LED Lighted Vanity Mirror (1X 10X) Model . LEDV410 () Logo
182 people viewed this question
Top Zadro Health & Beauty Experts
Robin Hill
Robin Hill
wcdoc1953
wcdoc1953
Are you a Zadro Health and Beauty Expert? Answer questions, earn points and help others
