Question about Whirlpool LER5636P Electric Dryer
Door is stuck closed.
Front door of dryer will not open.
  • fakestar May 11, 2010
    You really need a little more information. What were you doing before it happened? Is there anything sticking out that you can see? Did you dry anything that may have slid into a crack and jammed it shut?
  • 734 Answers
Try the following site for full information on unlocking Dryer -------
http://www.freepatentsonline.com/4908957.html
Posted on Dec 04, 2008
DRYER KEEPS RUNNING EVEN WHEN ITS OFF, OPEN THE DOOR IT SHUTS OFF, CLOSE THE DOOR IT STARTS UP AGAIN
Dryer is most likly need to be cleaned out motor is stuck in run mode
may have pile of lint on it check vent if you see exes lint in dryer when taking a part
Nov 30, 2013 | LG Dle5955g Front Load Dryer dle5955g
Opening the door after a wash
Turn program selector to "off". Turn selector to Drain or Spin. Press the start / pause. Wait until program ends. Open door.
OR
Press "start / pause" until the start / pause light flashes.
OR
First, unplug the machine and turn off the water supply. On the lower right of the front panel is a 6" / 15mm cover. Near the bottom of this cover is a small hole. Insert a piece of wire into this hole, and push in gently. While pushing, turn the cover clockwise, it will came off.
The door release is a narrow white plastic strip hanging down on the right; Pull down on this strip while pushing in on the door, the door lock will release.
Pl click if helped.
Mar 18, 2013 | Bosch Logixx WFT 2806 Front Load...
When The door is open continues to run on my Bosch Axxis Clithes Dryer WTA3510US
the door switch contacts are welded together,normally it switches when the door is opened to light the interior drumm light and to the dryer circuit when the door is closed,but these contacts cant due to being stuck
Nov 15, 2012 | Bosch Axxis WTA 3510 Electric Dryer
Dryer doesn't stop when the door is opened
it sounds like your door switch is stuck. you can replace it yourself. first, shut off the breaker. second, wrap a putty knife with masking tape to prevent scratching up the dryer. then, use it to pop open the plastic catch on each front corner. take your time and look inside the small gap with a flashlight to help figure it out. after you have the top of the dryer safely tilted back, look for 2 wires running to the door. they will plug into a switch that is flipped when you close the door completely. you know what i mean, it probably used to click when you shut the door. unplug these wires from either side of the switch. remove the switch and replace it. hook up your wires. close the top and you should be good to go. good luck
Nov 01, 2009 | Whirlpool GEQ9800P Electric Dryer
Whirlpool Front Loader Dryer Door will NOT stay closed
I have the same issue with the door popping open. If you push hard on the bottom of the door then it snaps in. I think the bottom latch is broken or misalligned.
Oct 17, 2009 | Whirlpool GEW9250 Electric Dryer
Dryer wont turn on acts like the door is not shut but it is
Check you r door safety switch.
Pop the top and remove the front. Check the switch unplug the power) for contunity first. Make sure it is saying the door is closed (contacts are closed) when the door is closed and saying the door is open (conacts open) when it is open.
Oct 12, 2009 | Dryers
Two things. 1. the dryer does not shut off when the door is opened. 2. I changed the light bulb, still does not work, and now the door will not fullly close and latch.
your door switch is stuck in the closed position
replace that and you should be ok
as far as closing it may be the switch stopping the door too
Oct 05, 2009 | Kenmore 74872 Gas Dryer
Washer Dryer - drum is filled with water even when switched off and door can still open!
Try the valves inside the back where the water hoses connect to the machine they should default to the closed position when water is not required
Oct 31, 2008 | De Dietrich LZ9619 Front Load Washer /...
Need help with OLD dryer
IF YOU MEAN THAT THE DRYER STARTS BACK UP WHEN YOU CLOSE THE DOOR, THE PUSH TO START SWITCH IS SHORTED. CHECK TO SEE IF THE PUSH TO START BUTTON IS STUCK PRESSED IN AND NOT SPRINGING BACK OUT.
IF IT IS STUCK, TRY WD-40 TO LOOSTEN IT. OTHERWISE, REPLACE THE SWITCH.
IF THE DRYER KEEPS RUNNING WHEN YOU "OPEN" THE DOOR, THE DOOR SWITCH IS SHORTED. REPLACE THE DOOR SWITCH.
Mar 31, 2008 | Kenmore Elite HE4 Electric Dryer
Whirlpool LER5636P Electric Dryer Logo
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal De
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
