Question about Poulan "" Push Mower
My poulon lawn mower will start witht he choke fully on. Once it is running and the choke automatically starts to close, it get about 2/3 closed and the engine dies. I have cleaned the float bowl and checked the air cleaner for obstructions. Nothing significant was found. The first time this happened I changed the spark plug and it ran good long enough to mow two small yards. Now it is doing it again. Any ideas????
    Master:
  • Poulan Master
  • 645 Answers
Sounds like the main jet in the carb is clogged. It will operate on the choke circuit but not on the main circuit. The main jet needs to be cleaned.
Posted on Dec 05, 2017
5 Suggested Answers
  • 15 Answers
SOURCE: after 1 season it ran great ,slowly died now it wont start
So many possibilities, so little data... <grin>
When you say "clean gas", do you mean that you added "fresh" gas, or that you emptied the tank, and refilled it with "fresh" gas?
Try this:
a. remove the "float bowl" screw, and put a regular "bowl" or pan underneath to catch ALL of the gas as it comes out.
b. if the gas is totally "clear", then it (probably ain't the gas), but... if it's "yellow", it's old and/or contaminated; alternatively, if there's any water (which may appear as a grey-ish liquid) then it's contaminated; also, don't forget to check the gas from your "storage" can, the same way...
c. re-install the the screw, and put some *FRESH* gas in the tank.
d. pull the spark-plug, and clean (or replace) it.
e. prime it, and crank it, and it should start right up.
Posted on Sep 27, 2009
  • 8 Answers
SOURCE: lawn mower wont start. changed air filter, spark
Does it turn over? If it does, what happens? Does it sound normal when its cranking? I need more information to help. Is it a push mower or riding mower? Does it start by key or pull start?
Posted on May 01, 2010
  • 9 Answers
SOURCE: mine will not start without
If you are putting fuel on to th fillter and it fires it sounds like the choke is not working right. Take of the air fillter and look to see if the butterfly is fully shut when pulled on. If it is a primmer pump look in to see if there is any fuel comming up when pumped if they are both working then try putting fuel into the plug hole and see if it fires if it does then it is a fuel problemTake off the carb again know you said it is clean but remove the main jet valve in the centre of the carb and clean it every hole blew out and 100% spot less rebuild carb and refit to mower hopefully that should short you outl davidson lawn mower tech
Posted on Feb 08, 2011
Testimonial: "appreciate the feedback!! thanks!"
  • 6468 Answers
SOURCE: lawn mower will not start after running out of gas.
are you getting spark?was the gas you put in newer than 30 days old?
Posted on Jul 31, 2012
How do I set the choke on my Briggs Stratton 35 classic engine.
Allow the mower to cool overnight.
Check the choke to see it is closed.
If not adjust it just until it is closed.
Then start the mower and warm it up. Check the choke again, it should be fully open.
If not the parts are defective and need to be replaced.
Aug 27, 2015 | Garden
Where is the choke
Many Briggs engine have a primer rather than a choke, the 675 series has a choke that is worked by an air vain, the choke is always closed when the engine is stopped, once the engine starts air pressure from the flywheel pushes the air vain which in turn opens the choke to allow the engine to run normally, there is also a version with a bi thermal switch on the back of the muffler, as the muffler heats up the switch opens the choke.
Feb 12, 2013 | Craftsman 675 Series 190cc 22" Briggs ...
Hello folks; My Husqvarna yth 2348 rider is very hard to start on the initial start. After once getting to run, it restarts easily with little hesitation or need of choke usage. Help please on how to start...
Sounds like your choke cable needs adjustment. Follow the choke cable to where it mounts on the carb.
Move the choke lever at the same time watching where it mounts to the carb. there is usually a clamp holding the cable in place, you may need to loosen the clamp and slide the cable back to make the choke fully close
Aug 30, 2011 | Husqvarna Lawn Tractor 48" Deck, 23 Hp,...
Engine starts but won't continue to run. Choke doesn't stay closed after starting. will stay running only if I hold choke closed manually.
let it warm up with choke closed manually after it starts to stall with choke closed open it and dont let it stall u can learn to play with the choke a little to get it to run right GOOD LUCK!
Aug 14, 2011 | Toro Lawnmower 20099 Mower Mowers Lawn
My MTD Yard Machine Y2500 starts fine and works with the choke partly closed. It also idles fine with the choke fully closed but stalls when I press on the throttle when the choke is fully closed.
when the choke is fully closed your choking the fuel out,, thats why when you give i t gas it dies , its not supposed to run with the choke on and getting fuel , use the choke only until the motor warms up to operating temp,, then open it,, and you should be fine,
Jun 01, 2011 | Mtd Garden
Hard to start n cold wheather put new battery in it still having trouble
I suspect the choke isn't closing fully. Remove air cleaner down to where you can see the choke butterfly. With the controls in choke position that butterfly should be completely closed. If not you can adjust it. If this is cable operated, adjust it by loosening the screw that holds it on the bracket and slide it until choke closes. This is done usually on carb end. I am also assuming it runs fine after start. Hope this helps.
Dec 08, 2010 | Toro 42 In Deck 19 Hp Kohler Courage Twin...
Qualcast petrol 35s mower will only operate with choke fully open, closing the choke causes the engine to cut out. Mower has been operating fine until now following a full service. What is the likely...
The chole is only ment to be used to prime the engine on cold start up, the engine is supposed to be run with the choke in the normally open position.
Aug 10, 2010 | Garden
New honda hrr auto choke hard to start
sounds like it may need the carb clening out, but it could be the auto choke not closing when cold. there was an issue with some of the early auto chokes on the gcv135/160 engines so check to see if the choke flap is in the closed position when starting from cold, run the engine for approx 10-15 minutes and see if the choke flap has opened fully.leave it to go cold and see if the choke flap has returned to the closed position
Apr 12, 2010 | Husqvarna 160 CC Honda OHC Engine 21 in
Toro riding lawn mower. 12 h/p is hard to start
Hi there, It is most likely that the choke isn't closing fully. The throttle cable will need to be adjusted to cure this. The cable is clamped where it joins the engine. Simply slacken the bolt and move the outer cable out a bit. When you operate the throttle control you should see the choke start to operate near the start position. Make sure that the choke control rod operates to its fullest extent when the control is fully on the start position.
Sep 08, 2009 | Toro Lawn Mower With Toro Power Tools
Poulan "" Push Mower Logo
65 people viewed this question
Top Poulan Garden Experts
Roland W VanLue
Roland W VanLue
Phil Walker
Phil Walker
Are you a Poulan Garden Expert? Answer questions, earn points and help others
