Question about Behringer FBQ800 Mini Equaliser
Can you show me how to connect the mini FBQ800 to hifi system is it impossble
    Brigadier General:
  • 8,546 Answers
Of course. It has both RCA and TRS interfaces.
Register and download the manual for free at retrevo.com
http://www.retrevo.com/support/Behringer-FBQ800-manual/id/23281bh442/t/2/
Posted on May 20, 2011
Can I connect my peavey 600b amp to aux or to my existing hifi
If you connect the Main 1/4" out on the front to you HiFi aux input it should work. You will need to play with the volume controls to set the proper level so as not to overload the aux buss. The XR-600B manual is here-
Peavey XR 600B Operating Manual Page 4
Mar 01, 2015 | Peavey Music
How to connect UB1202 to an Amplifier
Hi ha07. Have you fixed your Problem? If not, If you are using a HiFi amp you can connect it to any AUX input or tape in.
But better to use Aux, so you can keep Tape-In free, but it all depends how you want to use your system for recording
From the Mains "OUT" of your Mixer, 1/4 inch to RCA lead/s or adaptors will be needed, (Depending on your AMP) into the aux input of your stereo. But their is many scenarios for inputs and outs.
then you can run a lead to your computer from your Mixer or amp from Tape out, but again lots of possibilities.
Hope this helps if you haven't fixed your problem
Dont use (Phono input)
RustyRecords
Good luck and Vinyl Rocks RustyRecords Mail
Jun 29, 2012 | Behringer UB1202 Eurorack UB1202 Mixer (12...
When i plug in my mbox mini 3 the blue light come on, but when i try to lauch pro tools it says that hardware is not recognize. When look at the mbox mini control panel, it says that it is not connected...
Assuming you are on a Windows system, go to Control panel/Sounds and devices/ and check that the Mbox2 appears as the default in the Audio and also Voice tabs/panes while unit is connected. If it is not, select it in each... if it is not in the list offered, then the drivers have not been installed for the Mbox.
Aug 24, 2011 | Digidesign Mbox 2 Mini Workstation
My ps60 has a high freq noise with a regular pulse pattern it does this thru mymixer and also when i plug it direct into amp cheers Brian Garbutt
Hello Brian, It could be a ground loop problem, I usually get something similar when connecting a laptop to an amplifier. You can purchase ground loop isolators from car hifi places which are used to take ground loop problems out of car audio systems. They are very cheap so maybe worth trying this first. I got one for £12. They have stereo RCA input/outputs and require no power.
Hopefully this is of help to you.
Aug 08, 2011 | Korg PS60 61 Portable Performance...
I have a 1984 AKAI stack hifi system. Has been stored in garage for years. Brought it out yesterday and all appears to be working well except when playing records on the turntable the sound from one...
Just had a search and found this
http://www.epinions.com/inst/submitted_form_~ultrafinder/ultrafinder_submitted_~%20Go%20/search_vertical_~all/search_string_~Akai%2520Stylus%2520Needle%2520Apx1c%2520M313w%2520M452%2520cd%2520M50%2520M502%2520M512
Hope it is useful for you
www.epinions.com
Aug 04, 2011 | Akai Stylus Needle Apx1c M313w M452 (cd)...
How do I attach power amp to 1832 mixer
There are a number of configurations for a mixer like the 1832, the most common are PA system and Recording system. There are Main output jacks which carry the mix as summed in the main faders. These in a PA system would feed the pa amplifiers which drive the house speaker system for the audience. These connectors are XLR 3 pin type on the rear, intended for professional pa amplifiers which use balanced +4dbv line input level. Amplifier which have 3 pin XLR connectors for input signals can accept that high level signal. For home style HiFi amplifiers, the signal level is nominally -10DBv and balanced or unbalanced signal lines with 1/4in diameter phone plugs which are connected to the mixer by way of a second set of Main output connectors which are 1/4in phone jacks. Use whichever amplifier input level your amp has.
If you are not using it as a main PA house mixer, but using it for recording, the main output connectors go to a 2 channel recorder or computer sound card recorder. The power amp and your monitor speakers are connected to the connectors labeled "Control Room" (CTRL Rm). These output are useful for recording because the signal through the mixer can be monitored from several buses, Solo, main mix, selected by buttons provided. The buttons only affect the signal heard through the control room monitors, and not the main output which only sees the main mix so selecting "solo" does not interrupt the signal going to the recorder while the engineer in the control can be checking other signal paths through the board.
Jan 21, 2011 | Behringer Xenyx 1832fx Mixer 18 Input 32...
I can't get any sound out of my Korg Mini Kaoss pad when running it into an amplifier. It works fine if I run it into my old cassette 4-track recorder, but I get nothing other wise. I've tried bunches of...
The Mini KP generates Stereo output and you would run it to either a stereo channel on your mixer before the amp or into two channels of your mixer board and PAN them to opposite sides.
If you try to connect this to a monaural amp, like a guitar amp) your cable will ground out the output of this box. The minimum would be to builld a special resistive mixer to combine the channels before they go to your amp HOWEVER you will lose much of the effects without having a stereo system.
Jan 19, 2011 | Korg Mini Kp Kaoss Pad
I just got a kaoss pad and having need help connecting to a cdmp 6000 help please
You haven't got a send and return on your cdmp 6000. What I advice you to do is the following: connect the master out, the red/white cinch, to the input of the kaoss pad. Than connect the output of the kaoss pad to your speaker system or reciever. You can now control effects on the master single.
Feb 20, 2010 | Korg Mini Kp Kaoss Pad
How to change speaker yamaha keybord
Simply put, the speakers can't be changed on Yamaha keyboards. If you have blown the speakers then put the sound through an amplifier or HIFI speaker system - but you must be able to have an AUX cable and AUX on the HIFI for this to work. Sometimes it can also work by use of composite cabling too, depends really on what audio equipment you have.
Apr 02, 2009 | Yamaha YPT400 61 Key Portable Keyboard...
Behringer FBQ800 Mini Equaliser Logo
64 people viewed this question
Top Behringer Music Experts
Michial Gueffroy
Vito Vacirca Jr.
Ben Armstrong
Are you a Behringer Music Expert? Answer questions, earn points and help others
