Question about Intermatic & Indoor/Outdoor Rain Tight Timer
I have an intermatic t104p3 timer and it quit keeping time do I have to change out the clock motor or can it be fixed
    Problem Solver:
  • 18 Answers
Other than testing to verify you have power at the line in terminals not much you can do as far as repair that I know of. If power checks ok probably need to replace.
Posted on May 20, 2011
What position is lever on intermatic pool timer t104p3 for timer to work?
Lever automatically moves back and forth as trippers pass.
Move lever to ON position, move to the right.
If timer dial is not rotating, then check wiring, or replace clock motor:
If timer worked before and stopped working, but dial still rotates, the trippers are worn down, replace trippers:
http://waterheatertimer.org/How-to-operate-and-set-T104-timer.pdf
http://waterheatertimer.org/Buy-T100-series-timers.html#pool
http://waterheatertimer.org/How-to-wire-T104-Intermatic-timer.html#T104
Gene
h
If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
May 20, 2014 | RTO Intermatic Inc Ej351c Timer Night...
Clock on T1905 timer switch has quit working. Fixable, or need a replacement?
120Volt T1905 Intermatic timer uses WG730 clock motor and 156T1950A tripper.
Timer will last many year by replacing parts, and keeping lubricated with touch of white grease, and not over-amping the 20 amp contacts
http://waterheatertimer.org/How-to-troubleshoot-Intermatic-timer.html
http://waterheatertimer.org/How-to-wire-T1906-Intermatic-timer.html
http://waterheatertimer.org/How-to-replace-Intermatic-clock-motor.html
This timer can be converted into 208-277Volt timer by installing WG733 clock motor instead of 120Volt WG730.
Nov 13, 2012 | Intermatic Timer T1905 24 Hour Dial 120V...
My Intermatic T104P3 timer will not turn the pump on. The manual switch works and it does turn off, as set.
1) Manual switch is working, and that says electricity, circuit breaker, wiring, and pump are good.
If timer dial is rotating and keeping good time, then order new 156T1978A trippers.
If dial is not rotating, then order 240Volt WG1573 clock motor.
2) Open following links for troubleshoot walk-thru and replacement parts list.
http://waterheatertimer.org/Intermatic-trippers-and-parts.html#T100
3) Take a moment and rate answer:
And take advantage of fixya expert assistance live.
For a price, expert works with you while you work on timer or any do-it-yourself project.
Fixya is always less expensive than a service call.
Sep 04, 2011 | Intermatic & Indoor/Outdoor Rain Tight...
My Intermatic T104P3 produces a very low whirring sound - constantly when power is on. Is this a problem? It is working quite well.
Sound is coming from 3 watt clock motor located on back of timer mechanism.
It is not a problem unless clock motor is running slow.
You can turn power off, remove mechanism from enclosure using thumb spring located top inside box. Spray WD-40 on clock gears and see if sound stops.
WD40 vapor is highly flammable accelerant so don't spray on hot surface or live electric connections.
WG1573 clock motor can be purchased separately.
Resources
Sep 02, 2011 | Intermatic & Indoor/Outdoor Rain Tight...
Intermatic t104p3 pool timer will turn pump ""ON" with Manual Switch but will not shut "OFF" using Manual Toggle. Pool store showed me how to remove and look at the contacts on...
Thank you for including model number so answer can be accurate as possible.
T104P3 timer works with manual override so timer is basically sound.
Clock dial rotates and keeps good time, so WG1573 240Volt clock motor is good.
Trippers do not click on-off lever, so trippers are suspect.
Trippers are made to wear down so that timer mechanism lasts years longer.
Order extra clock motor and trippers at Grainger
http://www.grainger.com/Grainger/timer-accessories/timers/electrical/ecatalog/N-8hi
See wiring diagram:
Add a comment for more free help.
Also take advantage of fixya expert assistance live.
For a price, expert works with you via e-mail while you work on timer or any do-it-yourself project.
Feb 18, 2011 | Intermatic & Indoor/Outdoor Rain Tight...
The clock does not move forward. If I manually turn it, then it will work and turn on the system where the pins are. I haven't tried anything to fix it because I don't know where to start. Intermactic...
Sprinkler and irrigation timers are 14 day.
Intermatic has a page with manuals:
Open page, click plus next to timers and scroll down to sprinkler and irrigation timers
http://www.intermatic.com/customer%20service/instruction%20manuals.aspx
It's good to have the manual on hand in case the product is discontinued
That being said, it sounds like the clock motor is bad.
Snap timer free from box and tip out to see clock motor located on back of timer.
Get the number off clock motor
Intermatic site shows pages of clock motors: They are priced high, but cheaper than new timer.
https://www.intermaticstore.com/ASPI700W.pgm?task=menucntrl&menuopt=TM
Aplus supply sells assortment of Intermatic clock motors.
http://www.aplussupply.com/intermatic/timermotors.htm
To search these pages quickly for your clock numbers, use browser Find (Click edit at top of bowser, click Find)
Nov 08, 2010 | Intermatic R8806P101C -...
How do i reset and restart my intermatic T104p3 after power outage? the gears don't turn and the timer is new.
You should be able to grab the timer dial and pull towards you, now spin either direction to the desired time. If you are at a time where the clock is about to turn on or off you may have to move it a little bit more or less
Sep 30, 2010 | Intermatic & Indoor/Outdoor Rain Tight...
Clock for pool pump intermatic timer Model T104P3 stopped ticking
TO INSTALL THIS MOTOR REMOVE SCREW ON LEFT AND JUST BACK SCREW ON RIGHT A FEW TURNS, TIMER WILL ROCK UP OUT OF BASE THIS WAY . UN-HOOK WIRES ONE AT A TIME AND INSTALL WIRES FROM NEW MOTOR ONE AT A TIME.. THESE TWO WHITE WIRES GO TO LINE 1 AND 2 THESE ARE THE WIRES THAT GO TO THE 220 VOLT BREAKER ... NEED MORE HELP JUST GIVE ME A BUZZ.. JAY ..LOOK EBAY FOR .. Intermatic Timer Motor WG1573 / WG1573-5 clock POOL FIX
May 15, 2010 | Intermatic & Indoor/Outdoor Rain Tight...
LOOK HERE ON EBAY .. Intermatic Timer Motor WG1573 / WG1573-5 clock POOL FIXTO INSTALL THIS MOTOR REMOVE SCREW ON LEFT AND JUST BACK SCREW ON RIGHT A FEW TURNS, TIMER WILL ROCK UP OUT OF BASE THIS WAY . UN-HOOK WIRES ONE AT A TIME AND INSTALL WIRES FROM NEW MOTOR ONE AT A TIME.. THESE TWO WHITE WIRES GO TO LINE 1 AND 2 THESE ARE THE WIRES THAT GO TO THE 220 VOLT BREAKER ... NEED MORE HELP JUST GIVE ME A BUZZ.. JAY
Mar 28, 2010 | Intermatic & Indoor/Outdoor Rain Tight...
Intermatic & Indoor/Outdoor Rain Tight Timer  Logo
269 people viewed this question
Top Intermatic Hardware & Accessories Experts
Craig Butler
Craig Butler
Gene Haynes
Jay Finke
Jay Finke
Are you an Intermatic Hardware and Accessory Expert? Answer questions, earn points and help others
