Question about Sony Walkman NWZ-S618F
How long should I charge my sony walkman before using it for the first time?What is the proper procedure?
  • 1,272 Answers
Well, though there are no hard and fast rules for charging your MP3 player still I would recommend you to charge the player for atleast 2 hours before you start using it. Then ensure that you drain the batteries completely before charging them up again.
Hope you find this helpful.
Regards
Anand
Posted on May 20, 2011
Sony walkman Sony Walkman Bean NW-E305 (512 MB) MP3 Player won`t charge
Good morning, afternoon, evening or night; whatever time of day you are reading this solution post. Thank you for choosing FixYa to assist you with your problem. Your Sony Walkman Bean NW-E305 (512 MB) MP3 Player won't charge properly? Well Danish, we must use a method called troubeshooting to figure out and solve this situation. There are several reasons why this player may not be charging properly. The cause is either coming from the battery inside of your MP3 Player, a bad or faulty USB cable connection, or something (software) isn't installed correctly. Let's look at the first cause- The battery. The battery life may be gone. If it is, you will need to replace it if possible. Your device takes a
Sep 26, 2011 | Sony Walkman Bean NW-E305 MP3 Player
Sony walkman nwz-b135 when i connect it to my laptop it will add music etc, but will not charge thanx
I'm sorry to know that the Walkman player is not getting charged. I'll be glad to assist you with this. Please perform the following steps:
If the New Hardware Wizard appears and is prompting for a location of the driver, point to the following directory: C:/WINDOWS/INF .
To function properly, your Walkman player must be recognized by your computer as a Media Transfer Protocol (MTP) device. If the portable player was connected to the computer before the Windows Media Player version 10 or later was installed, it will be recognized as a Mass Storage Class (MSC) device and not function properly. In that case, a different procedure is available to correct this issue.
For some models, when you use the portable player for the first time, if you have not used it for a long time, or the battery is depleted, it may take up to 5 minutes for it to be recognized or start charging. On models with a display, the display will remain blank. If it the portable player is not recognized or does not begin to charge after waiting 5 minutes, reset the player by pressing the reset button.
If this is not the first time using your player and it was working properly at one time with no major changes performed (such as restoring the operating system or replacing a hard drive), follow the procedure below:
Connect the portable player to the computer using the supplied USB cable.
Disconnect the USB cable from the portable player and then reconnect.
Check the connection status again.
Disconnect the USB cable from the computer and then reconnect.
Check for available space on the player using Windows Media Player or My Computer .
Restart the computer.
Check that the USB cable is firmly connected to both the computer and the player.
If the player is connected to a USB hub, disconnect it and connect it directly to the computer with a dedicated USB cable.
If the player is still not recognized by the computer, disconnect all devices connected to the computer with a USB connection and restart the computer.
After the computer restarts, connect only the Walkman player and test the connection again.
If the player is still not recognized by the computer, try a different USB port.
Under the Common settings menu of the player, format the player using the built-in Format utility.
Verify the current Operating System. If it is an upgraded operating system, contact the computer manufacturer for updated drivers for their upgraded operating system.
If you are running the Windows XP operating system, be sure you are running Service Pack 2 (SP2) or later.
If you did not have the latest service pack, test the connection status again after it has been installed.
If you are still unable to transfer music to your player and have not yet uninstalled and reinstalled the driver follow the procedure to confirm that the player is recognized by the computer as an MTP device.
Thanks for contacting FixYa.
Aug 08, 2011 | Sony Walkman NWZ-B135 MP3 Player
Sony Walkman NWZ-B103F it wont open..
check the unit after completing each step:
Confirm that the portable player is connected to a working USB port and that it is charging. If necessary, connect it to a different port. When connected properly, the battery icon will be animated or it will indicate the charge status such as FULL when charging is completed. Make sure that you are pressing the POWER button to turn the player on. Previous Walkman® models that did not have a power button would turn on by pressing any button. This model must have the power button pressed to turn it on.
Ensure that the HOLD function is not activated.
NOTE: For some models, when you use the portable player for the first time, if you have not used it for a long time, or the battery is depleted, it may take up to 5 minutes for it to be recognized or start charging. On models with a display, the display will remain blank. If it the portable player is not recognized or does not begin to charge after waiting 5 minutes, continue with this procedure to reset the unit.
If the portable player is still not responding, reset it by pressing the RESET button with a small pin or similar object.
NOTE: When the RESET button is pressed, although the unit will retain the music data and clock settings, all other stored data and settings may be deleted. If the unit starts up after the reset, access the Settings menu and initialize the unit using the Format (initialize) function.
If there was no change after the player was reset, connect it to the computer and reset it again, leaving it connected.
Check the Sony Support Web site to see if there are any available firmware updates for your model. Updates can be found on the Sony Support Web Site.
If possible, instead of connecting the USB cable to the computer, connect it to a USB AC adapter (if available) and try to charge it.
Mar 25, 2011 | Sony Walkman NWZ-B103F MP3 Player
Mp3 Player Froze
Follow this procedure if the portable player appears to be frozen with Every Moment Has its Music on the display.
  1. Confirm that the portable player is connected to a working USB port and that it is charging. If necessary, connect it to a different port. When connected properly, the battery icon will be animated or it will indicate the charge status such as FULLwhen charging is completed.
  2. Make sure that you are pressing the POWER button to turn the player on. Previous Walkman models that did not have a power button would turn on by pressing any button. This model must have the power button pressed to turn it on.
  3. Ensure that the HOLD function is not activated.NOTE: For some models, when you use the portable player for the first time, if you have not used it for a long time, or the battery is depleted, it may take up to 5 minutes for it to be recognized or start charging. On models with a display, the display will remain blank. If it the portable player is not recognized or does not begin to charge after waiting 5 minutes, continue with this procedure to reset the unit.
  4. If the portable player is still not responding, reset it by pressing the RESET button with a small pin or similar object.NOTE: When the RESET button is pressed, although the unit will retain the music data and clock settings, all other stored data and settings may be deleted. If the unit starts up after the reset, access the Settings menu and initialize the unit using the Format (initialize) function.
  5. If there was no change after the player was reset, connect it to the computer and reset it again, leaving it connected.
  6. Check the Sony Support Web site to see if there are any available firmware updates for your model. Updates can be found on the Sony Support Web Site in your country.
Jul 12, 2010 | Sony NWZ-E438F Digital Media Player
Sony ericsson walkman wont stay on
your mobile needed to be get serviced but not that much just from the cords where the bettery + - nodes are .. some times the carbon get attach to them and they wont work properly or work slow... if this does not work....try turning on your mobile without memory card some time if memory card is corrupted the cell phone does turn on properly...
Jun 23, 2009 | Sony Ericsson w580i Cellular Phone
Sony Walkman not connecting to computer
I had a similar problem (my computer uses Windows XP) - Sony Walkman beeps a couple times when I insert the USB Cable that connects it, like it is connecting, but it does not charge or is not found by Windows Media Player. In my case, the way I fixed it was to:
1, Go into Control Panel
2. Double Click 'System' ICON
3. Select Hardware Tab
4. Select Device Manager
5. Select 'View' at the Top
6. 'Devices by Type' AND 'Show Hidden Devices' should be selected
7. 'Scroll down to 'Portable Devices' and open it up.
8. My Sony Walkman was there with and Exclamtion point ( ! ) in a yellow circle,
9. Right Click on this yellow exclamation point.
10, Select 'UNINSTALL'
11. Once the computer says 'Device has been Uninstalled, Disconnect your Walkman's USB cable then reconnect.
12. At this point, my Walkman was recognized by my computer, started charging, and was recognized by Windows Media Player
Hope this helps
Feb 16, 2009 | Sony Network Walkman NW-E005 MP3 Player
Walkman doesn't recharge
hi i guess i can help but i need u to follow this steps okay??
1/ dissemble the unit
2/ locate the battery
3/remove the connections using the soldering tool
4/use direct 12V wires of AC/DC adapter to chok the battery.
5/get it on it place using the previous tool
6/turn it on and see
7/ rate this poste if u can!!
best regards.
jalal.
Sep 14, 2008 | Sony Network Walkman NW-A1200 MP3 Player
SONY NETWORK WALKMAN NW-E005F
i have a sony nw e305 , same problem no detection and no charging even after it shows tht the battery is charging.. and the walman shows charge error at times...
Mar 30, 2008 | Sony Network Walkman NW-A1200 MP3 Player
Sony Walkman NWZ-S618F Logo
269 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
