Question about Bosch Dishwasher Timer Control Unit 092190
I have the bosch SMU7056UC/14 dishwasher - it is about 14 years old so it does not have an electronic touch pad - it has control buttons that you have to push - the on/off - first button on the left - will not hold so it will not start. I assume the control panel is bad - how hard to replace yourself?
    Scholar:
  • 122 Answers
Easy to replace - IF you can find spares !
Most manufacturers declare their products obsolete after 10 years (some even earlier).
However, you may be able to fit a standard chassis mount ON/OFF toggle switch and solve the problem (assuming that only the ON/OFF switch is faulty).
Use a switch that has a plastic body and mounting shaft, to avoid safety problems.
Select a switch with a current rating equal to the stated rating on the machine's spec label (usually at the rear of the machine). If the rating is only stated in Watts, then simply divide Watts by the rated mains voltage to get the current.
If no lable can be found, then select a switch that can handle at least 10 amps if the rated mains voltage is 110 - 120Vac, or 5 amps if the rated mains voltage is 220 - 240 Vac.
Posted on Jun 07, 2011
  • ilshak01 Sep 09, 2011
    Does the little light come on above the button? If not...it may not be the switch/button...it maybe a broken wire from the switch to the terminal block. You can check the switch itself for continuity with a multimeter...then (WITH THE POWER SHUT OFF AT THE BREAKER PANEL OF COURSE) check for continuity between the switch (Black wire) and the terminal block. These units are notorious for a broken wire where the door opens and closes.
Lights are blinking when trying to start frigidaire dishwasher
First, confirm that the display is working. If the display is still working, try pressing some of the touch-pad buttons. If some of the buttons respond correctly but others don't, it is likely that the touch-pad is at fault. (Some manufacturers sell the touch-pad separately from the control panel. Other manufacturers require that you purchase the touch-pad and control panel together. If you cannot replace the touch-pad individually, replace the touch-pad and control panel.) Frigidaire Dishwasher Lights Flashing or Blinking
Oct 28, 2017 | Frigidaire Dishwashers
My Kitchen Aid Dishwasher is 8 years old, The light that I push to start it, does not light up, and I cannot turn it on. All other lights are on
Looks like an electronic problem. Most likely the touch pad. But sometime you may be end up changing the both touch pad and main control board. Also sometime harness between the touch pad and main control board can be the culprit. If there is dirt build up harness then user rubber eraser to clean it out. It will help.
Sep 25, 2014 | Dishwashers
Does someone know where i can get the manual for an old bosch dishwasher? The model number is smu7056uc/14.
http://www.bosch-home.co.uk/quick-links/customer-service/download-product-manuals.html
Feb 27, 2013 | Bosch Dishwashers
My Bosch is only a few months old and it won't drain the water.The filter is fine. It's a shea43p16uc60.
Your bosch washer should still be under warranty:
  • Limited warranty, entire appliance, parts and labor (1 year)
  • Limited warranty for non-electronic components; parts only (1st to 2nd year)
  • Limited warranty for control board (microprocessor); parts only (1st to 2nd year)
  • Limited warranty for motor or any component of the motor (1st year to 10th year)
May 19, 2011 | Bosch SHE43P16UC Builtin Dishwasher
I have a Bosch dishwasher Model No: SMU7056UC/14. The top rack does not seems to be cleaning good. I took out the filters under the lower wash arm and cleaned out the pump area. Any ideas would be very...
Hi, I have an older dishwasher also and recently mywife also complained about it not cleaning right... so me being the man I amtried in vain to clean the things... Bought new spray arms online and installedthem in minutes...now the thing works like new... However I have also foundthat if the heating element goes bad then that also can mess things up bad...So I would buy new spray arms, and also check out the heating element to makesure it is working... Here is a tip that will help you with the onlinebuying...
Dishwasher SprayArms not Spinning
How to Buy ApplianceParts Online
A bad heating element causes many problems in dishwashers...
Dishwasher Problems The HeatingElement not Working
DishwasherMaintenance DishwasherResidue and Film on Dishes
heatman101
Asker's Testimonial "explanation very clear. will give it a go and see howsimple it was. thanks Ronnie " - ronnieshomes
May 14, 2011 | Bosch 24 in. SMU70 Built-in Dishwasher
Touch pad/control board not working?
PART NUMER 8193762 IS WHAT YOU WANT TO CHECK. YOU CAN SEE THE PICTURE OF THE PART AT REPAIRCLINIC.COM
Apr 24, 2010 | KitchenAid 24 in. KUDP01IL - Multiple...
Touchpad--No Response
The "2H" is an error code indicating the control panel needs to be replaced.
May 08, 2009 | Bosch 24 in. SHU53 Built-in Dishwasher
Dishwasher stopped working. Suspect electronics issue.
An expert from another site says it's a faulty control panel and may need new actuators.
Jan 31, 2009 | Dishwashers
Soap dispencer won' t dispence soap
My Bosch intergreted dishwasher is only 3 years old. For the past year, the dishwasher dispenser refuses to open on the second cycle. We have had the repair man here 3 times, and each time he says it's fixed,but it clearly is not. Does anyone know what to do about this??
Barbara Berger
Sep 30, 2008 | Bosch 24 in. SHY56A05 Stainless Steel...
Dishwasher lights are all flashing
If you do have the Touch Control Electronic Pad, then you do have a problem, moisture related. You need to open the panel, use a Hairdryer to dry the panel properly and replace. This sorts many of these Touch Control Electronic Pad.
Nov 23, 2007 | KitchenAid 24 in. KUDI02IR Built-in...
Bosch Dishwasher Timer Control Unit  092190 Logo
390 people viewed this question
Top Bosch Kitchen Appliances - Others Experts
Martin Olney
Martin Olney
Level 1 Expert
Oloyede Monsuru
ray gallant
Are you a Bosch Kitchen Appliances - Other Expert? Answer questions, earn points and help others
