Question about Homelite Garden
I have a Homelite Textron ut10654 chainsaw, but no manual. It has 3 screws on the left side. I need to know how to set these screws to make the saw run. I can't find the manual. Can you help?
slohry
  • 87 Answers
SOURCE: homelite cs3314 chainsaw
Here is a link to get you your parts list. Make sure you have your UT#
http://odref.com/homelite/chainsaw/index.html
Posted on Apr 09, 2009
SOURCE: HOMELITE Textron Chain Saw, wont stay running properly.
The preset is to turn them all the way in (Don't tighten them hard or you will damage the needle) and then back each out 1 1/2 turns. This will get you started. You can then run it at full throttle and turn the high speed jet in untill you hear a change in the RPM. Then turn it out untill you hear the same. Find the happy medium.
Posted on May 15, 2009
  • 508 Answers
SOURCE: Primer bulb is part of the fuel cap.
http://www.upstateoutdoorpowerequipment.com/?gclid=CJrT2dXno5sCFQk_agodVn7zAg
GoodLuck!!!!
Posted on Jun 24, 2009
  • 376 Answers
SOURCE: what is my lo hi carb adjustment for a homelite
Start with 1 turn out from bottom on both and adjust from there as needed. The screw closest the engine is low speed mixture adjustment and the outer is high speed mix. adj. Hope that helps. Dwain
Posted on Jul 01, 2009
  • 76 Answers
SOURCE: Homelite Chainsaw UT10901A Owners Manual
Hi
This is the closest I found on the net .
hope it helps .
http://www.partsmadeeasy.com/manuals/6164.pdf
All the best and good luck
Posted on Jul 19, 2009
How do I set idle on my homelite super2 chainsaw
Homelite XL 2 Automatic Chainsaw - YouTube
? 6:12
https://www.youtube.com/watch?v=qk6nk-JQ-zg
Apr 20, 2012 - Uploaded by Alec Ulm's Busted Knuckles
Homelite XL 2 Automatic Chainsaw ... free to shoot me a question or comment and I'll do my best to answer as accurately as I can . ... Homelite SUPER 2 Chainsaw OILER REPAIR & TEST RUN - Duration: ... HOW TO ADJUST A Homelite Carburetor - Duration: 5:01. by smallenginemaster1 177,482 views.
How to Adjust the Carburetor on a Homelite Super VI Chain ...
homeguides.sfgate.com > Construction & Remodeling > Siding
Homelite Super VI chain saws are equipped with a Walbro HDC diaphragm, and ...Adjust the idle mixture screw and idle speed screws clockwise one-quarter turn at a ...Homelite Super 2 Chain Saw Oil Type · How to Replace a Carburetor on a .... MyRidevisit'Cars-My Ride'navigation-www'4 · Sell Your Carvisit'Cars-Sell ...
Need carb settings for Homelite chainsaw - My Tracto
Jan 03, 2016 | Homelite Garden
What is the replacement chain and bar for a homelite textron Little Red UT-10748
Ok, what you need to do is go on Google type in that model number UT etc etc and parts right after it. You will see a bunch of sites that have parts drawings, click on one of them, find your part numbers THEN do the same thing again, bqck to google, type in part number then the description, again you will see sites that will either offer the OM part or an aftermarket.
Nov 23, 2015 | Homelite Garden
What type of gas/oil mix do I use for homelite textron chainsaw with model# ut10655? 50:1, 50:2 ???
40:1
If the cc on any saw is over 55cc....then use 50:1
(November such thing as 50:2)
Nov 03, 2015 | Homelite Garden
I have a Homelite-terry TEXTRON chain saw does it take a gas oil mixture?
I have a Homelite Terry Textron X76 T83-03010 Unit 50150.
how do you change the fuel line?
Sep 02, 2012 | Garden
Need a manual for homelight textron super ez automatic chainsaw serial # 292740092
You can download then print your Homelite manual by going to www.homelite.com/service/product owners manuals the best way to do it is to right click on the material, left click save, put in in your Documents folder, then retrieve it to print if you actually have to hold paper. Good luck
Sep 23, 2011 | Homelite ZR10926 16 Chain Saw
Can i get parts for homelite textron chainsaw 10045b
I saw no Textron listed. An inspection of your saw will probably reveal a "UT-", that seems to be the key.
Homelite/Ryobi.com (authorized parts supplier)
https://www.gardnerinc.com/recons/disclaimer-lg.php - Agree; Choose “Product Line”; “Select OEM” & “Select Catalog” both to “Homelite Consumer Products”. A drop down list appears; self explanatory from here.
The numbers Homelite & Ryobi use do not match the numbers everyone posts. A careful inspection of your saw should find something that matches. Good luck
Lou
Jan 20, 2010 | Homelite Consumer Products 9.0 Amp, 14 In....
Homelite ut No. 10748 textron New sitting long
Is there bar oil in the tank? Oil pump and/or pickup tube in oil tank are usual suspects.
Jun 29, 2009 | Homelite ZR10926 16 Chain Saw
The chain on my chain saw is slack.
The adjusting screw is usually found on the right side of the saw close to the bar, near the bottom. You will need to loosen the two nuts on the side that hold the bar tight. Loosen them until the bar lifts up and down (about 1/2") with your finger.
There should be a combination spark plug wrench and screwdriver that came with your saw. If not, use a slot screwdriverto tighten the chain while you hold the bar up with two fingers.
When adjusted properly, there should be no hanging slack in the chain when it is warm. It should rest just against the bar so that you can grasp it with gloves on and pull it toward you.
When it is tightened thusly, tighten the two side nuts while holding the bar up with two fingers. If you don't tighten the two nuts enough, it will loosen and the chain will have slack again shortly.
Remember that the hotter the chain gets, the looser it will be. Make sure your chains is getting plenty of bar oil. Never use regular motor oil.
Jun 08, 2009 | Homelite ZR10926 16 Chain Saw
May 09, 2009 | Garden
Garden Logo
43 people viewed this question
Top Homelite Garden Experts
roeb
Roland W VanLue
Roland W VanLue
Mike Squire
Are you a Homelite Garden Expert? Answer questions, earn points and help others
