I have a Maytag PAVT244AWW .It has a burning smell during spin cycle
reg501
  • 413 Answers
SOURCE: Burning Smell when spinning
8 yrs old....The LATs were the best models for Maytag...Maybe it's time to replace the belt..Slipping belts smell bad.
Posted on Jun 10, 2008
docjohn174
  • 943 Answers
SOURCE: maytag washing machine mod # LA882 top loader
HI. thanks for the question. well, not good news for you. the transmission has failed. has broken a gear inside. very costly .suggest buying new. A roper washer. good price. good washer. thanks the appliance doc. please rate my answer thanks.
Posted on Oct 08, 2008
  • 16 Answers
SOURCE: Maytag SAV 3652 AWW Washer:
Bad water pump. Replace water pump.tip machine back,Look under machine, remove belt, turn pump by hand, if not spinning freely replace pump.
Posted on Mar 24, 2009
SOURCE: Spin cycle won't spin. Burning smell. How do I
Remove the back -- you'll see the screws to do this. Sounds like the belt or the clutch is slipping and overheating.
Charlie
Posted on Aug 25, 2009
  • 464 Answers
SOURCE: seized tub - Maytag pavt244aww washer
you may have a seized up pulley on your pump. this will burn the belt. also check the pulley on the end of the motor.
Posted on Oct 27, 2009
Maytag performa pavt244aww washer burnt rubebr and black pieces
Check with the belt off that the bowl will turn freely, if not check drum bearings or something caught between inner & outer bowl. Make sure when you fit new belt it is adjusted to the right tension or it will slip & burn.
Nov 24, 2013 | Maytag Performa PAV2200
Maytag washer (model PAVT244AWW). Won't spin. Don't know how old it is or its history, as it came with a home we purchased in October. Several times it's "walked" during the spin cycle. About 6 weeks...
Its the clutch ,And it sounds like it time for a new washer,the clutch is expensive and washer are cheap try a second hand store that sale scratched or almost new machines
Jul 05, 2010 | Maytag PAV2300 Top Load Washer
Seized tub - Maytag pavt244aww washer
Oct 27, 2009 | Washing Machines
1 yr machine. Won't spin but has burning smell
The reason to this problem can be due to the
brake rotor.It need's to be replaced.
Sep 01, 2009 | Maytag Centennial MVWC500V Washer
Maytag SAV 3652 AWW Washer: During spin cycle, burning smell occurred while making unusual noise. (For months, major squeaking during agitation).
Mar 23, 2009 | Maytag PAV2300 Top Load Washer
Maytag washer model PAVT244AWW will not agitate during wash cycl
When the machine drains etc the gearbox locks up and the whole unit drum box and all spins when washing the gearbox innerds move the otherway so to speak and this cuasees a washing action this sounds as if the input shaft may need replaceing but it is usually better to replace the gearbox depends on finances but to be sure get a technition in to check and quote you first this is not something you can do if you have not done it before
Jan 25, 2009 | Maytag PYE2300AY Electric Dryer
Very loud final spin cycle with burning rubber smell
Hi Mcbride2
It could be one of 2 things. 1 the belt. or 2 the main seal and bearing. i recomnd to get a tech just to make suer.
brent
Sep 06, 2008 | Maytag Neptune MAH5500B Front Load Washer
Maytag Atlantis shut down during rinse cycle.
Contacted a local repair shop. They told me that if I got it spinning again, the motor was most likely ok. It is protected by a thermal switch that turns it off when it begins to overheat. The smell was to be expected as it was overheating; the difficutly restarting was because it hadn't cooled off enough yet. We have now used it a few times for small loads. Still getting a smell, but the wash cycle is completing ok.
Jul 23, 2008 | Maytag Atlantis MAV6000 Top Load Washer
Jun 09, 2008 | Maytag Dependable Care LAT9416
Washing Machines Logo
43 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
