Question about Samsung LCD-TV LE40S81B 40 in. HD-Ready LCD TV
Black vertical line of approx 1 mm from top to bottom of the screen at 80mm to the right of Samsung LCD TV LA40C630K1MXXs
  • 760 Answers
I have hate to say it, but you need to replace your panel. Would be more cost effective to replace your set.
Posted on May 20, 2011
My 42 in phillips LCD flat seen has a black horizontal line toward the bottom how can I fix this.
Samsung LN46B650 Thin Black Horizontal Lines - Forums - CNET
www.cnet.com > Forums > Samsung
CNETI'm experiencing thin black lines from the top of the screen to the bottom. ... by babes808gpa / January 15, 2010 1:42 AM PST ... lines are about 1/4 inch apart from top to bottom of screen. starts on the right and about a 1/3 of the way toward the ...have the exact same problem, my lcd tv has multiple lines are horizontal it ...
Faulty HD- LCD - LED TV - Horizontal Lines STRIPS on the ...
? 3:05
https://www.youtube.com/watch?v=KiqJuMiEiak
Jun 8, 2013 - Uploaded by Sameh Moustafa
Faulty HD- LCD - LED TV - Horizontal Lines STRIPS on the picture SOLVED .... I just have one black line ...
TV Repair Help for Vertical & Horizontal Lines on Your TV ...
? 2:47
https://www.youtube.com/watch?v=b0sI7LB4cZE
Dec 20, 2015 | Televison & Video
2 days ago, a narrow black horizontal line appeared in the middle of the screen.
CNETJun 11, 2015 - I'm experiencing thin black lines from the top of the screen to the bottom. ... my lcd tv has multiple lines are horizontal it starts from the right and fades too the left, ... Samsung LN55a950 - Horizontal lines on right side - Forums - CNET
Jun 11, 2015
Samsung 52" LCD TV black lines - Forums - CNET - CNET.com
Jun 10, 2015
More results from www.cnet.com
Plasma TV Repair Horizontal Lines - How to Diagnose ...
? 2:49
https://www.youtube.com/watch?v=h4XWCxUsSVU
Sep 2, 2014 - Uploaded by ShopJimmy.com
I have thin horizontal black lines on the top and bottom areas of my TV. .... Hi, I have a 2011 64-inch 3D Samsung PN64D8000 Plasma TV.
how to fix horizontal or vertical lines on lcd tv - YouTube
? 4:52
https://www.youtube.com/watch?v=k2QpYJp6MU8
Apr 12, 2014 - Uploaded by cr4zyw3ld3r
Hi my LG 47ln5700 tv set has thin greyish black horizontal lineson one side of the .... I hope this works good with Samsung LCD as well....
Dec 19, 2015 | Samsung HP-R5072 50 in. Plasma HDTV
I have a Bravia KDL 40BX421 that suddenly has green vertical lines on the bottom 1/4 of the screen. These lines are in a background bar that is mostly a reddish shade.
Thin vertical lines cover screen on Samsung LCD - AVS Forum ' Home ...
www.avsforum.com/.../1127410-thin-vertical-lines-cover-screen-samsun...
Mar 7, 2009 - 30 posts - ‎25 authors
Hi guys, Ive had this TV for about a year now - all of a sudden thin vertical lines havecovered my screen (show in link below) No matter what ...Missing: 40bx421
? 2:47
Apr 25, 2014 - Uploaded by ShopJimmy.com
TV Repair help with troubleshooting lines on your TV Screen. ... hi i have a sony bravia mdel # KDL46EX523. i have horizontal multi colored lines ... My TV has the following symptoms: - Horizontal lines from top to bottom of .... thick(like 1-1/12 inch) and a couple of green vertical lines next to the black one.Missing: kdl ‎40bx421
Flat Screen TV Has Lines Going Through Screen - Possible ...
Dec 16, 2015 | Televison & Video
My led samsung tv has a horizontal line and the upper right corner shows a white vertical lines
Not good. You may have a tab failure. A repair shop may be able to diagnose and repair this, but most likely the lcd panel is broken. The panel is the most expensive part of flat tv's. A new panel will cost more than a used tv.
Feb 02, 2015 | Samsung Televison & Video
Black vertical line down Sony TV screen
that isa capacitor at vertical area mostiy 1000 uf to 22000 /35volts
Sep 03, 2014 | Televison & Video
42 inch samsung plasma tv black vertical lines
Hi, Depeending on the thickness of the lines matters. If the lines are Black and about 1-2 inches thick it may be a bad bottom buffer board or a bad panel (screen).
If the lines are thin 1/16 to 1/8 inch it is most likely a bad panel.
You can open up the set and depending on the model, see the thin board/boards running across the bottom with ribbon cables going to the panel. You may be able to attempt reseating the ribbon cables, but be careful as some retainer plugs break very easy.
If the lines are thick black and the reseating doesn't correct it you may be able to buy the coresponding buffer. Unfortunately some bottom buffers are actually part of the panel. If you are not comfortable taking it apart then call a professional but be aware labor charges start around $200 not counting parts, panels start at $600 up to over $1000
hope this helps
Thanks
Eric
Aug 19, 2009 | Samsung LE32R74BDX 32 in. HD-Ready LCD...
Red blue green lines down my lcd tv screen
HP-R4252 NOT LCD TV
IF LCD TV has vertical lines try cleaning T-con board to lcd panel cable or replaced t-con board
Aug 15, 2009 | Samsung HP-R4252 42 in. Plasma HDTV
Shadows on screen
Try moving a medium powered magnet (not one for picking up heavy objects and not a refrigerator holding one) over the distorted area. If that doesn't work, try a more powerful one. This worked for my Toshiba LCD. Good luck!
Jan 04, 2009 | Sylvania 6626LCT 26 in. LCD Television
Black Vertical line appeared on my Daewoo Plasma
Bad connection somewhere along the bottom or top of the panel, there are boards most likely along the bottom of the screen that control vertical drawing, a connection that breaks as it is heated up sounds about right. check the connectors along the bottom. Be very careful because if you wreck em the screen is junk. The connector that will be at fault will be in direct line with the black bar.
Oct 28, 2008 | RCA L26WD26D 26 in. LCD TV
Samsung LCD-TV LE40S81B 40 in. HD-Ready LCD TV Logo
110 people viewed this question
Henry  Thomas
Henry Thomas
