Question about Moen 7310 Legend Single-Handle Kitchen Faucet with Side Spray Chrome...
Looking for an exploded view of entire moen 7310 assembly. How to disassemble, & were to get a complete rebuild kit. George R Garen, 32 Spring Garden Rd, Enfield, CT 06082 860-741-0400 aerialaba@cox.net
  • 710 Answers
Hi aerialaba,
Can I ask why you want to rebuild the entire faucet?
Usually, if you have a leak, you only need to replace the cartridge and the O-rings on it.
I'd be happy to help you with anything you need.
For starters, here is a webpage with the exploded parts diagram: >>>> http://www.moen.com/shared/pdf/7310pt.pdf Take a look at it and, if you decide you still want to rebuild the entire faucet, I'll locate the parts for you.
Thanks,
Handie Andie
Posted on May 20, 2011
How to remove moen bath faucet handle that has no set screws and is all 1 piece
1.) its not all one piece
2.) the tower threads onto the valve body, you may need to loosen the mounting nut under the sink top with a basin wrench to relieve the pressure on the handle tower
3.) this is the exploded parts view for your faucet: http://www.moen.com/shared/docs/exploded-parts-views/s498pt.pdf
4.) this is the instruction sheet for your faucet, including a technical support number you can call: http://www.moen.com/shared/docs/instruction-sheets/ins1207.pdf
Aug 26, 2014 | Moen Showhouse S498 Savvy Two Handle...
Moen banbury faucet repair
I had a look at the installation guide and exploded diagram, It seems that the whole assembly will be tightened when the mounting nut is put on.
The links to the installation guide and exploded diagram are:
http://www.moen.com/shared/docs/instruction-sheets/ins2224.pdf
http://www.moen.com/shared/docs/exploded-parts-views/87017pt.pdf
Jan 18, 2014 | Plumbing
Moen aberdeen #93980 manual
This is what Moen has to offer for the faucet itself:
http://www.moen.com/shared/docs/product-specifications/7592csp.pdf
The design guide is here:
http://www.moen.com/assets/moencom/images/design-planning/support/articles/kbplanningguide-revised8-26-09v2.pdf
The exploded view- for the 2 handle
http://www.moen.com/shared/docs/exploded-parts-views/7592cpt.pdf
The exploded view single handle. This is all that shows up for the Stainless model as well.
http://www.moen.com/shared/docs/exploded-parts-views/7590pt.pdf
The three other options/finishes have their own manuals
Chrome 2 handle
http://www.moen.com/shared/docs/instruction-sheets/ins802e.pdf
Chrome 1 handle
Bronze
http://www.moen.com/shared/docs/instruction-sheets/ins801k.pdf
Jan 07, 2012 | Plumbing
NEED TO REBUILD A CARBARATOR TO AN 85' BUICK SKYLARK
Carb kits come with instructions and an exploded view of the carb. You can get most kits at a local parts store. I recommend you buy a gallon of carb cleaner, disassemble the carb and let it soak for a couple of days. then blow it out with air pressure.
Sep 01, 2011 | Buick Skylark Cars & Trucks
We are trying to find a re build kit to rebuild the faucet and switch the cartridge to have hot and cold on the proper side. Also how to rebuild the faucet when its fixed
You get the rebuild kit FREE from Moen, they will ship it to your door.
The hot and cold is a hook up issue and not resolved in the cartridge. Just switch the input hoses. Sometimes the faucet is actually installed 180 degrees out and causes the same condition. I presume that it worked okay, except the reversal of the water... so switch the hoses.
Oct 11, 2010 | Moen 7310 Legend Single-Handle Kitchen...
I need an exploded view of the carburetor so I can attempt to rebuild it. My throttle sticks, my choke plate stays open, & there's something wrong with my air/gas mixture. It will start every now &...
You will need a rebuild kit,avail at the auto part store.
It will have the complete exploded views and all you will need to make the proper adjustments
You will need a vacuum gauge to set it up, when it is back on the car
Also, you will need to have a timing light to check that.
I would replace the float,which is separate from the rebuild kit
I would work on the choke issues first. You may be able to adjust it or just buy those pieces
May 05, 2010 | 1987 Chrysler Fifth Avenue
INSTRUCTIONS ON HOW TO DISASSEMBLE AND REPLACE MOEN 7310 CARTRIG
I would go into details on the removal but you will be better off following this link and downloading the PDF instructions yourself.LINK Thanks for using Fix Ya.
Mar 11, 2009 | Moen 7310 Legend Single-Handle Kitchen...
I have fuel leaking out fast behind the assembly for the fuel injectors. Where can i find an exploded view of this and what is the assembly called? Thanx for your time.
Get a rebuild kit for the throttle body. Be sure to get the rebuild kit for the fuel presure regulator. This is probably your leak. Most quality kits come with good instructions! Get new o-rings for fuel lines if they don't come with either kit.
Jan 17, 2009 | 1992 Chevrolet Suburban
Moen 7310 Legend Single-Handle Kitchen Faucet with Side Spray Chrome... Logo
184 people viewed this question
Top Moen Plumbing Experts
john h
Don Numinen
Don Numinen
Mike
Are you a Moen Plumbing Expert? Answer questions, earn points and help others
