Question about Video Game Consoles & Games
While trying to do a system update 8002F2E4 (data is corrupted) already reformatted the usb it is an 8 gb format fat32.
albert_price
  • 190 Answers
SOURCE: i get error code 8002F2E4 on my demo ps3 when
http://www.breakingnewsandsport.com/ps3-error-code-8001050f/619825/
I cannot help you with this error code, Because there is no known fix as yet. but this link will tell you about it.
Hope this helps.
Good luck.
Posted on Nov 21, 2010
  • 5 Answers
SOURCE: ps3 system update data corrupted
Hook up the external to your USB port and copy everything over. I had to do that when I installed a larger hard drive in my PS3
Posted on Jun 21, 2008
SOURCE: update 3.30 error 8002F994 data is corrupt
Actually, Reseting the console is your best bet. All you have to do is put your finger on he power button, HOLD IT DOWN for 10 seconds, and it should restart. If it doesnt reset the first time then do it a couple times.
Be Safe, kiddies. >:)
Posted on Apr 24, 2010
stif_NEC
  • 441 Answers
SOURCE: PS3's only read FAT32 USB's however movies over
If you have files that are over 4GB they are not supported on the PS3, this may include 1080p HD quality video that you want to play on your Playstation 3 and cannot because the current FAT file structure does not support files more than 4GB. The answer would be a PS3 firmware update to support the NTFS file system, then you could play 4GB plus video files on your PS3.
Posted on May 14, 2010
Testimonial: "Many thanks will look into firmware options"
diodeic
  • 1622 Answers
SOURCE: 40 gb model Data is corrupt
Hi, when Updating play stations,You are expected to use the right version for update. Most times people use lower versions,while some other people use higher version that is higher than the play station they have..
So make sure the version you are trying to install or use for the update is not higher than the version your using at the moment.
You can use the link below to know more about firmware.
blog.us.playstation.com/2010/03/28/ps3-firmware-v3-21-update/
Thanks ......
Posted on Mar 13, 2011
My Kingston DataTraveler G3 8GB USB 2.0 USB Flash Drive (White/Yellow)'s data all got corrupted, and i a cannot do anything [copying, pasting, renaming, moving, etc.] with the corrupted files/data
Get data back is a file recovery program for flash drives, it may work for this, but if the files are corrupt you would then be recovering corrupt files.
Apr 20, 2013 | Computers & Internet
Can't download a 10 gb movie into 32gb lexar s73 jumpdrive. it says it's full
You must be formatted to fat32, reformat the disk to ntfs (this should fix your problem). You are not allowed to back up 4GB or more of data to a FAT32 File System.
Jan 28, 2013 | Lexar JumpDrive S73 - USB flash drive - 16...
How do i remove parameters from a kanguru 4 g usb flash drive?
Which format fat32 or ntfs make sure its fat32 Indeed, FAT32 only supports files up to 4 GB. I ran into the same problem when copying an ~4.5 GB file to an 8 GB flash drive. There is a quicker solution that doesn't require you to reformat or lose data on the drive, using the command-line "convert" command. Suppose the flash drive is mounted to g:\. Open up a command window (start menu -> run -> cmd), and type: convert G: /FS:NTFS. Personally, I don't need the "security descriptors" on the flash drive file system, so I use the variant: convert G: /FS:NTFS /NoSecurity. The conversion should be very quick, and of course it has the benefit of not needing to move any files off the flash drive (since you don't need to reformat it). Hope this helps.
Dec 18, 2012 | Kanguru 4GB FlashBlu II USB 2.0 Flash...
Kingston Data Traveler 2.0 64 GB USB - file system corrupted - need to work on windows XP- Upon formatting the pen drive It shows that it has become a raw drive - wat is the file format for the USB to work...
Theoretically, you can't format a more than 32 GB drive with FAT/FAT32 file system. In your case you have to choose the NTFS file system to format your 64 GB USB flash drive. However, if you really need to format it with FAT32, you got to use the command line or a third party tool. Hope this is going to help you.
Apr 06, 2011 | Kingston (DTIU3/2GB) 2 GB USB Hard Drive
The parameter is incorrect
which format fat32 or ntfs
make sure its fat32
hope this helps
Mar 03, 2011 | Seagate FreeAgent Go 320 GB USB 20 Hard...
I cannot play a video or cannot view photo after dragging in 32 gb pen drive as i m having xp2 service pack please solve my problem
try reformatting first the pen drive, maybe its file system is corrupted. format it with fat or fat32 file system.
Jun 02, 2010 | Kingston 4GB Secure Digital High Capacity...
I am having an issue with my WD5000h1u-00 500 GB external drive
Read this instructions my friend
It is possible to use a Western Digital external hard drive on botha PC and a Mac. However, there are some things to keep in mind if youwant to do this. Moreover, Western Digital does not recommend doing it.
  • For both PC and Mac to be able to read the drive, it must beformatted in the FAT32 file format. In order to format to FAT32 on aMac you may need to contact Apple for support. We do have a FAT32Formatting utility for Windows that reformats WD external hard drivesto their full size, but in only one partition. The FAT32 formattingutility can be downloaded from our Downloads Library. You will find it on your WD drive's Downloads page.
  • Critical: Do not attempt toconnect any external drive to multiple computers, simultaneously; letalone to both a Mac and PC. This could quickly damage the drive'spartition and corrupt the data on the drive.
  • Sometimes, PC's won't read Mac FAT32 formatted drives, andMac's won't read PC FAT32 formatted drives. You may have to re-formatthe drive trying both the PC and Mac until you get a format that works.
  • Most WD external hard drives come pre-formatted with one large FAT32 partition, which is accessible by Windows 2000, XP, and Vista, and Mac OS 10.4 and 10.5.
  • Windows 2000, XP and Vista can only create FAT32 partitions that are 32 GB's or smaller.
  • Mac 10.4 and 10.5 can create FAT32 partitions the full size of the drive.
  • There is a 4 GB file size limit on the FAT32 file format. Thisis a file system limitation that affects both Mac's and PC's, and thereis no way around it.
  • Finally, you need to understand that if you are using the samedrive back and forth between a Mac and PC, there is always the chanceof files being corrupted. Mac's and PC's are different platforms, andtheir file systems function differently. Please keep backups of allyour files before you start sharing between Mac and PC computers.
Note: Once the data iscorrupted, that drive may no longer be recognized by one or both of thecomputers. Or, the drive may be recognized, and the data may bevisible, but you won't be able to open any files. At that point, youwill need to re-partition and reformat the drive in order for it to berestored and usable by both computers again. In the process, you willlose all the data on the drive. For that reason, you need to keep abackup of the files you are transferring between computers.At the bottom of the page, you will find links for partitioning and formatting in Windows XP and Vista, and Mac 10.4 and 10.5.
Jan 12, 2010 | Western Digital My Book Premium ES...
5.84 GB will not fit on the 8GB Store N Go
Easy Fix.. You need to reformat your USB File System to NTFS rather than FAT32 (Default). FAT32 limits the size of all downloads to 4 GB. NTFS has no upper limit so you could download an 8GB file, if you wanted..... FAT32 is the default on the unit you have. Easy fix.... right click on your drive, click 'format', 'file system' change to NTFS and click 'start'. That's it ! ! ! !
Nov 19, 2009 | Verbatim Electronics - Others
221 GB Free on MyBook - Error states not enough space for backup
It may be due to the file system.  If formated as FAT32 files larger than 4gb may not transfer.  Try reformatting as NTFS to fix the problem.
Sep 21, 2008 | Western Digital 250GB MyBook External USB...
Video Game Consoles & Games Logo
1,019 people viewed this question
Top Video Game Consoles & Games Experts
James Wishart
Are you a Video Game Console and Game Expert? Answer questions, earn points and help others
