Question about Polaris 280 In - Ground Pool Cleaner with Booster Pump
The Sweep tail on my Polaris 280 isn't sweeping. It just trails straight behind. The foam scrubber has worn away, and I plan to pick up a replacement. Will replacing the scrubber make it sweep? I've tried adjusting the screw, but no change.
    Top Expert:
  • Polaris Master
  • 6,498 Answers
The scrubber is for painted pools to get it to move loosen allen screw by tail turn to right
Posted on Apr 23, 2016
SOURCE: Older Polaris doesn't sweep
pantera ll by wicor sand filter distributes the sand back into the pool, what could the problem be?
Posted on Jun 02, 2009
john224
  • 1378 Answers
SOURCE: Installed a new 3/4 hp Polaris pool sweep pump.
Those pumps are dual voltage...Are you certain you connected it correctly for the voltage present? If the motor is set up for 230V (as it usually is when purchased new) and you only feed it 115 volts it will heat up and then act as you are describing. The side of the motor will have a diagram for how to reconnect the motor if necessary.
If connected correctly you would have a voltage issue in the line to the pump (unlikely). Check the voltage present at the motor terminals under load and look for a drop of more than 10%. If this is the case you will likely need an electrician.
Like I said though, it is usually because of wrong voltage setup for the problem you describe.
Posted on Dec 19, 2009
  • 106 Answers
SOURCE: 280 sweep hose does not sweep-drags behind unit
Where hose plugs into unit, there is a large stainless screw. Turn counterclockwise to allow more water thru hose and get more sweeping action.
Posted on Apr 28, 2010
jharwell668
  • 640 Answers
Make sure that the opening at the end of your pool cleaners sweep hose is not blocked by the sweep hose scrubber. If this does not work, you will need to adjust the sweep hose screw as mentioned above. The only thing that I would add about that is to make sure that you turn your booster pump off before you make adjustments. Hope this helps! I have a copy of the users manual for this model. Let me know if you need it and I can give it to you.
Posted on May 20, 2010
thepatioman
  • 52 Answers
SOURCE: My Polaris 3900 sweep hose simply drags behind the
The hose connected on the interior of the polaris could be disconnected. seperate the housing and you will see the hose. Or you need more pressure at the wall. Try closing are reducing the amount of flow to the skimmers to up the flow at the wall connection. Your back up valve should pull the polaris off the steps. Set the rotating jet propulsion on rear to 11: 00 position.
The Pool Tech
Posted on Jul 14, 2010
How to fix the polaris pool sweep tail problems
there is a plastic clip you can use a zip tie if you cannot find it in the pool
Aug 16, 2014 | Polaris 280 In - Ground Pool Cleaner with...
How to fix a polaris pool sweep tail from coming off
there should be a clip that holds it on probably in bottom of pool or in the bag
Aug 16, 2014 | Polaris VacSweep 280 Pool Cleaner with...
Wht do my arneson pool sweep lines tangle
make sure the swivels arent worn out just turn them to see
Jul 05, 2014 | Polaris 280 Black Max Pool Cleaner with...
Polaris tail not sweeping. I believe the impeller on the booster is clogged restricting water flow
If unit is operating satisfactorily otherwise, the check end of sweep tail for missing orifice tip. Without it tail won/t sweep. Also check adjusting screw. Out - more tail flow In - less.
Dec 01, 2012 | Polaris Pb4 - 60 Booster Pump
Pentair legend platinum sweep hose doesn't sweep
open up the screw on the bottom that will let water to the tail
Apr 28, 2012 | Pentair White/Gray Legend Platinum...
The sweep tail doesnt sweep
Make sure the opening at the end of the sweep hose is not blocked by the sweep hose scrubber. You might also need to adjust the screw that holds the sweep hose in place. If it is too tight it will not have the slack to move. If it is too loose, it will not have enough tension to move. Try adjusting it and it should have the pool cleaners sweep hose motion.
Mar 14, 2011 | Pentair White/Gray Legend Platinum...
Polaris 380 sweep hose isn't moving -- i have checked the sweep hose adjustment screw and it does't make a difference. the polaris unit is moving and vacuuming and there is water going through the sweep...
There are a few things to check with these pool cleaners. Make sure the opening at the end of the sweep hose is not blocked by the sweep hose scrubber. If you have any sweep hose weights, you might need to remove or adjust them.
Jan 10, 2011 | Polaris 380 In Ground Pool Cleaner
Pool sweep wheels are not turning
Problems with the sweep hose on these pools cleaners usually just means that you need to do some fine tuning. Start by trying to adjust the sweep hose adjustment screw. To adjust, turn off the booster pump and turn the screw clockwise to decrease motion and counterclockwise to increase. You might also need to replace one or both of your swivel ball bearings (part #D20).
May 19, 2010 | Polaris 280 In - Ground Pool Cleaner with...
280 sweep hose does not sweep-drags behind unit-unit works fine-cleans pool
Apr 27, 2010 | Polaris 280 In - Ground Pool Cleaner with...
Polaris 280 In - Ground Pool Cleaner with Booster Pump Logo
2,449 people viewed this question
Top Polaris Pool & Spa Experts
Jay Finke
Jay Finke
David Spradling
David Spradling
Michael Vincent Cruz
Are you a Polaris Pool and Spa Expert? Answer questions, earn points and help others
