Question about Honda Clutch Cable F200 F210 F260 Tiller
My honda f500 rototiller blew a belt. I replaced it with a 35 inch belt and now the clutch will not work. I can jam it into gear but I can not stop- the machine with the clutch
3 Suggested Answers
SOURCE: need specs.for Honda rototiller motor
The cam to crankshaft.... the plastic gear has a dot that you can see. mark the tooth with a sharpie so you can see it visible. its a cicle on the cam gear. on the crankshaft the cylinder needs to be at top dead center so when you put it back in all the way to the top. on the gear there is a notch that you line up the tooth on the cam to the two on the crankshaft. Its easier if you take the flywheel off to put it together. Hope I made sense
Posted on Aug 30, 2009
  • 48 Answers
SOURCE: white smoke honda mantis rototiller
You're okay the white smoke is the oil burning off the muffler. In time it will stop, just park it somewhere and let it run until it's done. If the problem persists check your air filter and make sure it's not stained with oil, if so you can wash the foam part with soap and water but the paper will need to be replaced. (DO not put foam back on unit until dry.) The oil level should be up to the bottom lip of the dipstick access when the engine is evenly horizontal.
Posted on Apr 15, 2010
I have a 1969 Cub Cadet 127 with a rototiller, and it loses power and stops spinning each time I lower the rototiller in the garden. I cleaned the rototiller and belts look good. Help!
You may have wear on the pressure plate and sometimes you can adjust the turnbuckle on the clutch rod and that will take care of the problem. If that doesn't help you may need to replace the pressure plate. Cub Cadet part # IH-473471-R1.... Hope this will help you.
May 23, 2017 | Cub Cadet Garden
I changed the belts on my MTD 42riding mower. When I depress the clutch pedal & put it in gear it takes off. The only way you can stop is to turn it off.
I an wondering if you have the wrong drive belt. I did this myself and the belt was too tight so when I started the tractor up it put me into a ditch full of water. I had to get the right belt. My replacement was only one quarter inch shorter but would not work.
Oct 31, 2015 | Mtd Drive Belt 42"
90 polaris trailboss. 2x4. with engine running and in gear, the bike will only move a couple inches, and the secondary clutch seizes up, and giving more gas only starts to burn the belt. With the engine...
Secondary clutch is your problem, depending on internal set up, you will find they are seized or worn/jammed, replace and check belt as it would be fairly worn, dont forget to sand the smooth surfaces on front and rear pulley (where belt sits) up and down motion (not circular)
Feb 13, 2011 | Polaris ATV
Timing belt run a 1/6 inch off the front of the Cam gear
is the belt tight on gears check see if gears are on right.
Jul 22, 2009 | 1996 Honda Accord
Can I get the specs for belt 727 A? I need to replace this weekend and ARDISAM won't give me a size. Can't afford to overnight. Earthquake Gear Drive 5 HP rototiller. would appreciate help=
DID THE BELT SHRED OR what happened if it is still decent mesure width on top is it a v-shape belt or flat & last thing is cut it & measure it if its still decent that will give you the specs or if theres other # on belt & who its made by
Jun 05, 2009 | Ardisam 5.5 Hp Rear Tine Rototiller
Clutch on Honda Accord
Could be something wrong with the engine oil. The gears won't flow smoothly unless they are well lubricated. When was the last time it was changed?
Jul 01, 2008 | 1997 Honda Accord
Honda Clutch Cable F200 F210 F260 Tiller Logo
179 people viewed this question
Top Honda Garden Experts
John Trevino
JOHN LAPIER
Are you a Honda Garden Expert? Answer questions, earn points and help others
