Question about Lego Digital Camera.
When we turn on the lego camera we get an exclamation point in a box and are unable to do anything. What's happening?
We had the same problem and we figured the memory was full. You need to delete the images. Connect your camera to the computer, it will show up on your desktop, double click on the icon, find the images, copy them to your computer (to save them) and then move them into the trash (we have a Mac, I'm not sure if it works the same way on a PC) and then don't forget to empty the trash. We forgot to empty it first and it's important. The camera works great ever since!
Posted on Dec 20, 2011
The camera is full-download pics on your computer & delete them. It will work fine after that:)
Posted on Sep 03, 2011
  • Mike Nov 26, 2011
    This is not the solution. We have the same issue and the camera has no pictures on it. Mac OSX Snow Leopard.
  • Darja Dec 20, 2011
    To the one below: This is the solution. You just need to empty the trash when you connect the camera to your computer!
There is a red exclamation point on the camera screen that won't go away. What is the problem?
Just got one of these cameras from a charity shop and after only a short use same problem.
Try connecting camera to PC as an external drive and delete (all) files..... This, too, may not work, in which case reformat the whole drive representing the camera - quick format will probably do.
Once you take a photo the directory path: DCIM/100IMAGE will be recreated.
I'd recommend reformatting quite regularly - after each time you download the photos off the camera.
Apr 04, 2013 | Lego Digital Camera.
I have to download lego universe
in me is error we are unable to download LEGO Universe.Please check your internet connection or go to www.lego.universe.com for trouble shoting. hhow to fix that problem?
Mar 05, 2013 | Lego Universe - Mac/Windows
Red exclamation point on verizon set top box
How to reset your Set Top Box to fix common problems FiOS TV Residential...
Resetting your Router and Set-Top Box can resolve a variety of issues such as:
  • Missing Interactive Media Guide (IMG) or On Demand menu
  • Unresponsive Set-Top Box
  • DVR recording problems
If you are having any of these issues, you may need to reset your Router and Set-Top Box. Will resetting my Set-Top Box erase the selections I have programmed into my remote?
No, all settings and selections you've entered such as device codes, favorite channels, and recent On Demand selections are saved and available after resetting your Set-Top Box.
Always reset your Router first and then check to see if that resolves the issue. Resetting your router may be all that is needed.
Important note about your router To avoid problems with your FiOS TV service, make sure your router is plugged in and turned on at all times. Even if you are not currently using the Internet, your router still needs be turned on so that FiOS TV can function properly.
To manually reset your router:
  1. Unplug the power cord to your Router for 15 seconds and then plug it back into the electrical outlet.
  2. Wait 30 seconds and then check to see if this resolves the trouble. If you still have the problem, follow the steps below to reset your Set-Top Box.
To manually reset your Set-Top Box:
  1. Unplug the power cord to your Set-Top Box from the electrical outlet for 15 seconds and then plug it back in.
    Note: Don't confuse the power cord that provides electricity to your Set-Top Box with the coaxial cable that is connected to the back of your Set-Top Box. Unplugging the coaxial cable will not reset your Set-Top Box. Since many issues can occur if your coaxial cable is not securely fastened, now would be a good time to check to ensure all connections are securely connected.
  2. Wait for the time to appear on the front of the Set-Top Box, then power it on.
  3. Wait several minutes while the Interactive Media Guide updates.
  4. Check to see if this resolves the trouble. If you still have the problem, your Set-Top Box may need to be re-initialized. Contact the Fiber Solutions Customer Support for further assistance.
I have to reset my Set-Top Box frequently, is this normal?
No, if you routinely have to reset your Set-Top Box more than three times a week, it is likely there is an issue with your Set-Top Box that needs to be resolved. Contact the Fiber Solutions Customer Support for further assistance.
also you can call for tech support at Dial 1-800-VERIZON (1-800-837-4966)
Oct 05, 2012 | Televison & Video
Tag will not update
try downloading it on another system and transfer it to yours.
Aug 11, 2012 | LeapFrog Tag Reading System
Rectangle in led screen green/ or yellow with exclamation
The camera doesn't have anything to focus on - especially if you're shooting the sky. The auto focus needs something with fairly defined edges to work. Try to focus on the edge of a well defined cloud, or focus on a tree or similar, half depress the shutter to lock the focus, then move re-frame your shot. Alternatively you can use manual focus. Hope that helps
Jul 24, 2010 | Canon PowerShot SX210 IS Digital Camera
Can't get Mindstorms USB connection to work.
try:
  1. changing cables
  2. switching usb ports
  3. using bluetooth
  4. changing the batteries
  5. if all above fails call lego custumer support at 1-800-838-9647
Dec 26, 2009 | Lego Media Lego Mindstorms
Sluggish picture taking, unknown symbols on screen
I just looked it up in my manual, and the exclamation mark with the waving hand means: 'There is a strong likelihood of camera shake because the shutter speed is slow.' The remedy to this is: 'Use flash photography. However, use a tripod for some scenes and modes.'
It sounds like you need to adjust your shutter speed. I'm no expert and I consult my manual often, so if you need any assistance doing this or anything else, feel free to ask.
Dec 21, 2008 | Fuji FinePix S5200 / S5600 Digital Camera
Lego Island
Older programs will sometimes not work with Vista. This is likely the reason that Lego Island 2 (a 2001 game) will work a opposed to Lego Island (a 1997 game). There are a few things that you can try, though:
  1. Right click the 'play game' icon and select 'Properties'
  2. Click the 'Compatibility' tab at the top of the window
  3. Click the 'Run this program in compatibility mode for:' box and select Windows XP or Windows 98/Window ME (you can try another later if one doesn't work)
  4. Make sure that the 'Run this program as an administrator' box is selected.
  5. Click 'OK' and close the window
Give the icon the good ol' double click and see if she works. There's no guarantees that this will work with Vista since it is an older program, but this is where I would start.
I hope this helps!
Mar 29, 2008 | Computers & Internet
Lego Digital Camera. Logo
498 people viewed this question
Top Lego Cameras Experts
Are you a Lego Camera Expert? Answer questions, earn points and help others
