Question about GE FUF17SVRWW Upright Freezer
I want to know how long the warranty is for GE Model FUF 17DPHRWH, Serial Number DL177038. Thanks. My phone number is 806.335.3745
  • GE Master
  • 5,160 Answers
The warranty offered by GE on the FUF17DPHRWH is one year for parts and labor from the date of purchase if the unit fails due to a defect in materials or workmanship. If you pay for the GE Service Protection Plus, you will get longer coverage. (However, I've found that for most appliances, you would be better off putting the annual fee for the service in a savings account. Then when the appliance fails, use the money in the savings account to repair or replace the applaince.)
The manual is available here: http://products.geappliances.com/MarketingObjectRetrieval/Dispatcher?RequestType=PDF&Name=49-60441.pdf . If this direct link doesn't work, start at http://www.geappliances.com/service_and_support/literature/ and enter the model number. Then click Submit.
I hope this helps.
(I have no way of looking up GE Service Protection plans.)
Posted on May 20, 2011
Fuf 14
If the compressor is running yet the suction (larger pipe) on the compressor is not cold, or if it is frozen, you probably have a refrigerant leak and need refrigerant.
Jun 11, 2014 | GE Freezers
Fuf 14dmdrwh
Is the motor running. Check if it has enough refrigerant gas. If the freezer runs normally for a long time and switches off, then replace the thermostat.
Jan 31, 2014 | GE Freezers
I have a kenomore freezer model 19502
In a situation like yours, the freezer comes with a 1 year warranty covering all parts and labor from the manufacturer. On the machine where the model and serial nimber are located there is also a nunmber to call for service. If you can't find the number google the number to whirlpool, who makes kenmore.
Apr 23, 2012 | Kenmore Freezers
Power off for electrical repair. Plugged floor freezer back in and a loud buzzing noise is ongoing. Not sure if this is a temperature alert or if there is another problem. Thanks for your help.
This sounds as if its a start relay problem. They are attached to the compressor
You will need the model and serial number to get a new one at the appliance
parts store. They are usually under a plastic cover on the side of the compressor
and the cover is retained by a metal spring clip. Remember to unplug unit before
replacing this part. The model and serial number should be located near the compressor.
May 04, 2011 | GE Freezer  14.8 Cu. Ft. Manual...
I need to know if this Woods freezer I have is frost free. Serial # 00676013A5 Model number V12WUA
Your model number does not show up online for me. Not surprising to me at all. One way to find out is to remove the service panel in the freezer. If you find a heater and a terminator you would know for sure it is a defrost model4515c47.jpg
Jul 25, 2010 | Woods Freezers
I was just given a ge chest freezer model # cb10 dk serial number vv186793. i cleaned it up and plugged it in about 5 minutes later it started buzzing . i turned the control to the lowest setting (0). and...
switch on and leave it to freeze.approx 24hours.buzzing could be compressor working overtime to get cold.or in fact the freezer is not on a level surface.
Mar 02, 2010 | GE Freezer  14.8 Cu. Ft. Manual...
Stand up freezer builds up frost quickly
It sounds like you may be on the right track here. If the gasket is old, hard, and brittle, it will allow moisture to be administered into the freezer, causing frost buildup. Not to mention, that old door gasket is leaking out a lot of cold air. Your best bet is to provide the model number (as you've shown here) and the serial number to an appliance parts store or authorized GE appliance parts outlet. They should be able to provide you with a brand new gasket. Removal and re-installation of the new gasket is fairly simple and you'll notice a big difference, not only in the lack of frost buildup on the inside of the freezer (especially in the summer) but you may even see a noted improvement on your electric bill as well!
I hope this helps and let me know if you need any further assistance! :)
Sep 22, 2009 | GE 20.3 cu. ft. / 575 liter Upright...
The freezer fan is blowing cold air but everything is starting to melt.
Check for complete model number for me to look up the correct refrigerator. Possible the defrost timer or defrost board. Could also be the defrost element or other problem. Will try to help you if you can find the model number, Let me know, Thanks Sea Breeze
Mar 21, 2009 | GE Freezers
FREEZER FAN HOWELS AND STARTS AND STOP STARTS AND
Your freezer fan will need to be replaced to keep it from stopping. Try to find the complete model number so I can help you fix and or replace the fan. Let me know, Thanks, Sea Breeze
Where is the serial number on Frigidaire FVE1415
on most frigidaire freezers the model and serial tag is on the inside left hand wall. if it is not there it mya be on the back of the unit. the serial number generally starts with 2 letters and is 7-9 characters long hope that helps thanks Peyton
Mar 03, 2009 | Frigidaire Freezers
GE FUF17SVRWW Upright Freezer Logo
123 people viewed this question
Top GE Freezers Experts
Charles T Nevin
Charles T Nevin
christian nielsen
Victor Nwachukwu
Victor Nwachukwu
Are you a GE Freezer Expert? Answer questions, earn points and help others
