Question about Sport & Outdoor - Others
A precor 5.21 elliptical exercise machine has died after a move. Display is dead and lift motor tries to go up past the breaking point. Disconnecting console stops lift motor execution. I need a wiring diagram so I can determine if the problem is in the wiring harness, or in the console module.
  • adam_fixya May 23, 2011
    I already have the ability to google for "precor 5.21" and know about that page detailing the repair of a broken gear in the lift motor and of precor's site.
    What I need are schematics; at the very least I need to know what voltages the console needs to function. I removed the lower cable and it has no damage. I've ohmed out the cables (top and bottom end to end) and they're fine.
    Looks like the problem is either the console or the lower power supply module.
    Guru:
  • 1,833 Answers
According to your requirement contact visit www.sportsmith.net/images/product_support/precor/Service%20Manuals/Consumer%20EFX/5.21i%20(serial%20code%20SS).pdf and download the manual, it will help you to repair the machine. You can also visit www.navisan.com/Articles/EFX521SRepair.aspx. Here the article may also help you. But first check the electric outlet and the electric input of the machine.
Posted on May 23, 2011
When we star the treadmill E02 is apper
Replacement Parts for Fitness Exercise Equipment at SPORTSMITH
Precor Error E2, Lift Error Probable Cause Error would occur if the incline is unable to move or if the incline position potentiometer is not functioning. When this error occurs, all lift motor and drive motor motion is ceased and the display will go blank except for the error displayed.
Corrective Action Troubleshoot as errors 40 and 42.
Precor Error Code E2
Oct 15, 2015 | Exercise & Fitness
My precor elliptical keeps giving me error44
Precor Error 44, Un-commanded Lift Motion Probable Cause 1. Intermittent or bad connection in the lift position sensor(potentiometer).
2. Lift position sensor (potentiometer) is bad.
3. Lower PCA is bad.
Corrective Action
  1. Bad or intermittent connection of the lift position sensor (potentiometer) is the most common cause of the error 44. Inspect all wiring and connections related to the lift position sensor (potentiometer). Repair or replace wiring connections as necessary.
  2. Monitor the lift position number displayed while operating the lift in diagnostics mode. If the reading makes large changes or is erratic, the lift position sensor (potentiometer) is likely bad. Replace the lift position sensor (potentiometer) or lift motor if the lift position sensor (potentiometer) is internal to the lift motor.
  3. If the lift moves without any command entered either manually or through a program, replace the lower PCA.
Precor Error Code 44
Jun 26, 2014 | Precor EFX 546i Elliptical Version 4
Precor efx 576i resets everytime user changes direction
Does the lift work? If not, the battery is dead. Replace it.
Feb 17, 2014 | Precor Efx 576i Experience Elliptical...
Precor 903 treadmill
You should start by inspecting the brushes inside the motor. If these are worn, which is common over time, then the motor would start to lose power. The following link will take you to a motor brush. Be sure and have your complete model and serial number available to confirm the brush is compatible.
Motor Brush Pac Sci YP00521 Each Precor PPP000000020002112 SPORTSMITH net
Dec 31, 2013 | Precor Exercise & Fitness
Our precor elipitical is stuck at the top Error 42
Precor Error Code 42 Error Code: 42 Manufacturer: Precor
Model: All Models
Error Description: Error 42, Lift Position Value Out of Range. Error 42 is displayed when the lift position reported by the lift position potentiometer is found to be outside its set limits.
If an Error 42 has occurred, it is important to know the physical position of the lift when the error occurred. It is possible the lift is physically out of range or jammed. In this case, the Error 42 is a secondary symptom and the issue should be approached as an Error 40. Possible Reason:
  1. Bad or intermittent connection in the lift motor controller.
  2. The lift motor requires calibration.
  3. The lift motor potentiometer is bad.
  4. The lower PCA to upper PCA cable is bad.
  5. The lower PCA is bad.
  6. The upper PCA is bad.
Recommended Action:
  1. Intermittent connections can be difficult to locate. If the Error 42 condition is intermittent, a connection issue is probably the cause. This is definitely true if the Error 42 occurred while the lift was within its normal physical range. Inspect the lift potentiometer connector and repair connection if necessary. If the intermittent connection cannot be found or corrected, replace the lift motor. A lift calibration number of 0 or 255 indicates an open or shorted potentiometer connection. This means the problem could be anywhere between the lift motor and the upper PCA. Typically it can be identified and tracked using an ohmmeter.
  2. Using the appropriate service manual for the unit being tested, refer to the lift calibration procedure. If the information in the service manual doesn't match the lift position/physical lift position of the unit, recalibrate the lift motor. [Something caused the lift motor to be out of calibration. Investigate for cause and correct. Simply recalibrating the lift motor will not solve the problem.]
  3. If the lift calibration number is not 0 or 255 and does not change when the lift motor turns, replace the lift motor.
  4. Check continuity of the interconnect cable or swap with a known good interconnect cable to verify if cable is bad.
  5. Swap the lower PCA with a known good lower PCA to verify if the lower PCA is bad.
  6. Swap the upper PCA with a know good upper PCA to verify if the upper PCA is bad.
Lift Position Value Out of Range Precor Error 42
Mar 01, 2013 | Precor Efx-5.21 Elliptical Machine...
Error 44 precor eliptical 546
Corrective Action
Nov 22, 2012 | Precor EFX 546i Elliptical Version 4
What is error 45 on the EFX 546??
Precor Error 45, Lift Moving in Wrong Direction Probable Cause 1. Lift motor hysteresis.
2. Lower PCA is bad.
Corrective Action 1. The error would usually occur when the lift was already in motion (usually downward) when a lift command in the opposite direction (upward) was made. Some lift motors used in production exhibited a very long turnaround time and the lift motor would still be moving in the original commanded direction while the control system was trying to move the lift in the opposite commanded direction. If the error continues to re-occur, replace the lift motor.
2. It is a rare condition, however if the lift moves in the opposite direction commanded, replace the lower PCA.
Precor Error Code 45
Nov 11, 2012 | Precor EFX 546i Elliptical Version 4
Whenever I use our eliptical precor efx, as soon as the elevation starts it says error 45
Aug 10, 2010 | Precor EFX 546i Elliptical Version 4
Error 45 on Precor EFX 546 Elliptical
Jul 19, 2009 | Precor EFX 546i Elliptical Version 4
Sport & Outdoor - Others Logo
105 people viewed this question
Top Sport & Outdoor - Others Experts
Are you a Sport and Outdoor - Other Expert? Answer questions, earn points and help others
