Question about Briggs & Stratton Ignition Kit 2-8 HP Engines with Breaker Point Ignition #5012D
I have a 1973 8hp briggs and stratton sears model rototiller.My dad and I had trouble getting it going last year,and when we did it back fired like crazy.My dad just passed away not to long ago and I would like to rototill my moms garden for her.tThis year the tiller will not turn over.I changed spark plug ,air filter is clean, I put carburater cleaner in it, changed the oil,still nothing.What do you suggest?
co7196
  • 3433 Answers
SOURCE: 8hp briggs and stratton in a go cart. is feeling
Make sure the governor baffle is working freely. and the carb has no crud in it. Chk out this site:
bsppwebtools.com/data/manuals/1678_0esfw.pdf
Posted on Oct 31, 2009
honeymokey
  • 3113 Answers
SOURCE: carb is getting clogged and spark plugs fouling
Carburetor cleaner will ruin the rings and do that.
Posted on Apr 13, 2010
  • 44 Answers
SOURCE: i have a 8hp briggs and stratton motor on my ride ...
yes u need a starter and battery
Posted on Sep 09, 2010
  • 6468 Answers
SOURCE: Wizard rototiller model 5hp. Briggs. Not getting
is it a bowl style carb and you cleaned it is it a diaphram style and you replaced the diaphram ?the older 5hp briggs engines would run fine if you started it with carb cleaner some leaked head gaskets and could create enough vac to draw in the fuel
Posted on Mar 29, 2012
  • 18 Answers
SOURCE: Petrol is spewing up from air filter on briggs and stratton 90208 ride on mower
lol too much oil bud take a little out
Posted on Nov 21, 2012
Briggs and stratton quantam 6.5 hp fires but will not run
Check for a clogged air filter.Try starting it without the air filter installed. Check for loose wires to the spark plug and ground. I am assuming there is gas in the tank, but does it get to the carb? Check the gas line, is it blocked? Is the carb leaking?
Oct 08, 2014 | Earthquake Rear Tine Rototiller SRT with...
6.5 briggs and stratton leaking motor oil through the filter area
How does it run? Is it back firing through the air filter box area? And although your stating it is oil is it actually oil or gasoline that is black due to getting dirty? Don't shoot me! I'm going on what information I'm reading what you submitted. If oil is it enough to show up quickly on the dipstick/engine oil level ? Get back to us and we can go further.
Nov 23, 2013 | Briggs & Stratton 491056 492932 Briggs ...
Magnetron replacement
Go to a mower dealer and tell him what motor you have and he will have a listing for the B&s motor spark plug.
Oct 06, 2013 | Briggs & Stratton Measuring Tools &...
Lawnmore pull cord replacement
Sears technicians can repair Briggs and Stratton cords fairly easily and it won't cost you much either. I had mine serviced last year and it took about 3 weeks and they just sent it off to the technicians and I just had to pay around $50 total.
Jul 07, 2012 | Briggs & Stratton Garden
Wizard rototiller model 5hp. Briggs. Not getting fuel somehow. Fixed carberator. Spark plugs cleaned everything out... what could be the issue
Mar 28, 2012 | Briggs & Stratton Garden
Wondered what year Sears made this tractor?
If the tractor has a Briggs engine, the code on the engine will give you the manufacturer date of the motor, most likely correlating with the model year of the tractor. Here is how you read the Briggs and Stratton engine code.
http://www.scribd.com/doc/25153865/Briggs-Stratton-Small-Gas-Engine-Service-Maintenance
May 14, 2011 | Garden
I need a carburetor diagram for a craftsman rototiller 5 hp.
YOU SHOULD BE ABLE TO GO ONLINE TO SEARS PARTS DIRECT AND ENTER THE MODEL AND SERIAL NUMBER AND LOOK UNDER PARTS DIAGRAMS , I CAN'T REMEMBER IF SEARS HAS CARB PARTS BUT IF YOU LOOK ON THE ENGINE IT WAS MADE BY EITHER BRIGGS AND STRATTON OR TECHCUMSHA YOU CAN GET A PARTS BREAK DOWN FROM THEM ALSO IF YOU HAVE TROUBLE WITH THESE GIVE ME A SHOUT WITH THE MODEL AND SERIAL AND I'LL FIND THEM FOR YOU
May 13, 2011 | Craftsman Garden
This is a Briggs and Stratton Rototiller, Model 130292-1636-02. I think my Armature might be bad. This is a Briggs and Stratton part # 397358 with electronic trigger (starter). After cleaning my fly-wheel...
the fly wheel is touche you need no more than 5 thousands clearance between the
fly wheel and the coil for the best spark
now on the other hand if you have points on this unit its best to put in new points
and condenser and set the points the same settings as the coil
this will get spark for you
hope this helps you
good luck
bob
May 08, 2011 | Ford Mustang Cars & Trucks
7 hp oh valve sears frame
Remove the cover for the valves by the spark plug and adjust both valves at .008 gap
That will end the back firing. They have locking nuts (double nuts) at each valve to adjust
Jun 10, 2010 | Briggs & Stratton Briggs Stratton Intek V...
Briggs & Stratton Ignition Kit 2-8 HP Engines with Breaker Point Ignition #5012D Logo
221 people viewed this question
Top Briggs & Stratton Hammering Experts
Dan Webster
Dan Webster
John Trevino
JOHN LAPIER
Are you a Briggs & Stratton Hammering Expert? Answer questions, earn points and help others
