Question about Poseidon Xstream Deep MK3 Regulator
My poseidon xstream purge button has torn half-way.. can i get a replacement or maybe a super glue to fix it? still, i would like to know has anybody ever tried to dismantle the purge button area?
Plastic shutter button broke. Can release shutter by pushing in the middle but button is gone includeing screw int piece for shutter release. Is this an easy fix?
The only easy fix is to glue with a super glue with the broken part or parts. If this is lost then you need to fabricate a similar type knob to be glued into the slot making sure that glue does no overflow and get the whole shaft stuck.
other wise the original can be sourced or replaced from a worn out/discarded camera or consult the Pentax service for estimation.. to restore it originally.
Jan 25, 2011 | Pentax ME Super 35mm SLR Camera
Instruction manual for poseidon jet stream regulator
Manual:
http://www.frogkick.dk/manuals/poseidon/1999/
Service manual for all poseidon regulators (trained scuba technicians only):
http://www.frogkick.dk/manuals/poseidon/2003/manual.pdf
May 31, 2010 | Poseidon Odin/Jetstream Regulator
Whirlpool Front Loading Door leaking water
The most common cause for a front loading washer to leak from the front door is a torn or detached gasket where that gasket attached to the machine.
Open the door and begin to pull the gasket away from the opening. Look for any problems. If you find a place where the gasket is not firmly secured to the opening, you can list that area up and glue (even with super glue) the gasket back down to the metal opening.
If you find gasket damage, it will need to be replaced.
Jan 03, 2010 | Whirlpool Duet Sport HT WFW8400TE Washer
A toothpick is stuck in the ignition switch. how do I remove it?
This can be tricky, but do it carefully and you can be driving in just a few minutes. If the toothpick isn't wedged super tightly in there, you can take another toothpick, break it in half, and put some wood glue or super glue on the broken end. Hold it against the stuck one until it's bonded, and gently pull it out. Super glue will work best, but you'll have to be really careful not to glue it to the ignition itself. If this doesn't work, you'll have to remove the ignition switch to get it out. Good luck.
Dec 06, 2009 | 1995 Toyota Tercel
Dryer stops after a few minutes Siemens WTXL2101 EU/07
Maybe a sensor at the back sensed overheating. You might be able to remove the backplate and search for a little button, which acts as some sort of reset button. (I do have a different tumble dryer, but it's the same brand and had similar problems). Maybe more ventilation is needed to prevent this from happening again.
Mar 28, 2009 | Siemens WT79020EU Electric Dryer
Torn door seal on front loading washer
My husband used super glue on the tear and for now the washer is not leaking.
Mar 25, 2009 | Kenmore HE2 Plus Front Load Washer
Smeg Dishwasher button broken
I am trying to fix the same problem. There is a clear plastic frame around the controller that has small plastic arms that the button pushes against. You will find that it has broken off and fallen inside the door. I managed a temporary fix by unscrewing the door panels finding the buts. Remove the clear frame it clips to the controller once you unscrew it from inside the door. I then used super glue to glue it back together. Fix is temporary only lasted 3 weeks and broke again. What you need to do is find a replacement clear frame.
Apr 20, 2008 | Dishwashers
Broken power switch/ring
yes, it probably won't work, buy a broken camera off ebay for $5 and replace the whole button, it's very easy, also coolpix 2100 will be cheaper and it uses the same part
Aug 20, 2007 | Nikon COOLPIX Cameras
Poseidon Xstream Deep MK3 Regulator Logo
96 people viewed this question
Top Poseidon Scuba Diving & Snorkeling Experts
David Bugden
David Bugden
Bill Boyd
ray gallant
Are you a Poseidon Scuba Diving and Snorkeling Expert? Answer questions, earn points and help others
