Question about Watches
I own a nelsonic watch. A - It has onl ONE knob (at 3 o'clock. B - I am almost positive that it does NOT have a battery but DOES have a CAPACITOR! which stores the solar power fgenerated when the watch is held facing a source of light,(preferably bright sunlight.) IF I am correct, what is the correct capacitor and specifically, how is the capacitor changed, OR can the capacitor , (which is the original one, as of about 7 - 10 years ago,) be replaced with a battery, with which local watch repair people are are significantly more familiar? Slso is this conversion even miore involved and difficult than finding and replacin g the capacitor???
SOURCE: Watch is blank/not charging
I have the same problem. I am not sure, but I think that, over time, the battery gets weak and dosen't hold its charge without exposing it to sunlight for an extended period of time. I think it may be time to change the battery.
Posted on Mar 08, 2009
  • 64 Answers
SOURCE: i would like to ask whats wrong with my solar watch...
The watch needs a new battery.
Posted on May 13, 2009
  • 23 Answers
SOURCE: what is the proper battery placement or orientation for eco-drive
The Citizen Eco Drive watches use special recharchable batteries.
I started collecting a couple of watches and I noticed sometimes a jeweler replaces them with an ordinary battery. The watch will work and at the same time it will try to recharge this one until it explodes! In newer models they made it harder to use the non-rechargable ones by adding a special connector or clip to the rechargable battery types. If you look into the place where the battery goes, you will see a shiny spot where the metal clip needs to touch. If not sure, find the link to tech docs below.
Okay, if you say your battery goes bad, did you store your watch in a drawer as many people do? It may have lost the charge over time. First thing to try is to leave it on the window sill so the dial is in the sun. It will start ticking, but please leave it out there for 3 days to a week. The seconds hand will tick irregularly in steps of one and two seconds, to show you it wants you to readjust the time, as it knows it has lost time. Adjust the time and it should run smoothly.
The seconds hand should run in single second steps, if it takes steps regularly, but every 3 seconds or so, it tries to tell you that its power level is going down. It will be able to continue for one or two days, but you should get it into the sun more often.
Charging the battery under a lamp is possible, however this heats up the watch and this may reduce battery life.
If you need to know more about the Eco Drive, look for detail tech manuals for all types here: http://www.citizenwatch.com/downloads/tech/tech.htm
Those are great watches as long as you remember it needs light to charge.
Posted on Jun 25, 2009
  • 10 Answers
SOURCE: need to replace casio atomic solar watch 2608 gw-300
Check out this YouTube video which walks you through the battery change process:
http://www.youtube.com/watch?v=ogCz2vjUKVg
Posted on Jul 14, 2010
  • 6771 Answers
SOURCE: My Casio Gw-300 G- Shock
From your description the solar cell charges the battery and keeps it topped up. I think the rechargeable battery is the problem because when the screen goes blank the battery level drops to low and the LCD blanks out which would explain the intermittent operation of the watch. I think it is worth getting it checked out with an estimate.
Posted on Jan 11, 2011
I have a marykate and Ashley ladies quartz watch model number MKA0132PC21 and i cannot get the backing off to replace the battery. Nelsonic is listed as the manufacturer and i would like to know if you can...
It should spin off counter clock wise, usually need a special watch tool ? Not always tho, and most jewelry departments in Myers, Walmart, etc... will open for free if your buying a new battery, really hope this helps ?
Feb 23, 2015 | Watches
Set the time
U mean how to set a time? Watches or clocks have knobs by the side you can adjust to set times and dates. The knobs are by the side for watches and at the back for clocks. I hope it helps...
Mar 28, 2013 | Watches
Hello. I own a 40 to 50 year old "Timex Electronic" watch. There is a number date at the 3 o'clock position. I see no other identifying info on the outside. I don't have a battery for it. How
What is the exact model of the watch. I have several Timex Electronic watches that might fit your description. If you pop the caseback do you see the old battery inside? Most batteries would have a reference like: CR2016.
Jan 06, 2013 | Timex Watches
I have a quartz president wall clock, I changed the battery and set the time OK but the chime needs setting and I have no instructions as it is a very old clock
These are general quartz wall clock instructions as I dont know enough about what type/style of clock you have.
  • Open the access door to the dial and hands of the clock if required. Some battery-operated clock movements are sealed inside the clock case with a back panel that is screwed in place. To gain access to the hand set knob, remove the back panel screws using the appropriate tipped screwdriver.
  • Turn the minute hand (or turn the hand set knob at the rear of the movement if access is available) carefully counterclockwise or clockwise until the correct time is reached. Keep in mind that using the hand set from the rear would require turning the knob in a clockwise direction in order for the hands to turn counterclockwise.
  • Move the hour hand carefully with your fingers near the center of the hand to the hour that the clock is striking if the striking chime is not counting the correct hour. The hour hand is a friction fit hand and will move without engaging the minute hand.
  • Replace the back panel and tighten the screws with the screwdriver if removal of the back panel was necessary to access the hand set knob.
  • Close the front access door if required.
  • Aug 15, 2010 | Watches
    How do you set the day of the week?
    Since you didnt tell me what KIND of watch it is I am giving you a general instructions.
  • Wait until the second hand is at zero (the top of the dial). Then pull the crown knob out as far as it will go to set the time on your watch. Turn the knob in either direction and look at the three additional hands on the time dials of your watch: the minute hand, the hour hand and the 24-hour hand.
  • Step 2 Stop turning the knob when all minute and hour hands are pointing to the correct time. Pay special attention to the 24-hour hand so that you have a.m. or p.m. correct.
  • Step 3 Push the knob back in exactly when a new minute is starting so that your second hand will be correct. Use another clock you know to be accurate as a reference, such as the government clock available online.
  • Step 4 Pull the knob out halfway so you can set the date. Turn it counterclockwise until you notice the date on the watch changing. Stop it and push the knob back in to its starting position once you reach the correct one. Try to set the date before 9 p.m. If you set it after that time, it may not register with your watch that it should switch the date at midnight. If this happens with your watch, just fix it the next day.
  • Step 5 Set the chronograph, or big dial, on your watch. It works like a stopwatch to let you time activities for up to one hour. Push the top button on the side of your watch to start it. Push it again to stop it. Push the bottom button on the side of your watch to reset it.
  • It would certainly help if next time you let us know what kind of watch it is you have, Best of luck.
    Aug 11, 2010 | Watches
    I have a watch which I use sparingly for less than two years. The watch stopped working even with a new battery.
    mcdevito75 here, Sometimes not useing a watch is just as bad as over use. Try to set the time and move the hands around a bit, the mechanism is most likely a little stiff, you can also try to tap the watch with something that won"t hurt the finish, (Handle of a Steak knife) at the 2--and 4 O"clock position on the watch and at the 9 O"clock position on the watch caseing not the crystal (glass)
    Jul 03, 2010 | Watches
    I cannot get the first and second hands to reset
    Click on my profile (escapement), then click on Tips and Tricks. There you will find link to all CITIZEN watch manuals.Watch for INTERACTIVE SETTINGS there. Rate me, please
    Mar 14, 2010 | Citizen Blue Angels Skyhawk Watch
    Reset timer after battery change in seiko sna285
    If the stop watch hands are not in the "0" (12 o clock) Position, follow the prodedure below to set them to the 12 o Clock position
    1, Pull the crown to secound position
    2, Press Button "A" for 2 seconds.
    3, Press Button "B" to Adjust the minute Hand to "0" Position
    4, Press Button "A" for 2 secounds then press Button "B" to adjust secound hand to "0" Position
    5, Press crown into normal position
    AmFix Jewelry & Watch Repair
    203 N. LaSalle Street,
    Chicago, IL 60601
    Ph: 312 641 7000
    Email: info@goamfix.com
    Web: www.goamfix.com
    Aug 28, 2009 | Watches
    Watches Logo
    51 people viewed this question
    Top Watches Experts
    Ansel Alberto
    Ansel Alberto
    Are you a Watch Expert? Answer questions, earn points and help others
