Question about Panasonic Lumix DMC-FX3 Digital Camera
It shows "This memory card
  • 313 Answers
What you have to do is to gently remove the memory card from your camera. Take a look at it because SD cards have a switch located on the left which you can use to lock/unlock your data. I hope it helps!
Posted on May 20, 2011
"Memory Card is write protected" so I can't take pictures.
remove memory card ... left or right side of memory you will see one little button slide the button down or up... this button is protected your memory..
May 28, 2013 | Nikon COOLPIX S6000 Digital Camera
Question for SanDisk SD card 2 GB - Camera is Canon PowerShot SD870 IS Digital Elph Question: When memory card is inserted in my camera the message "memory card error - card locked" shows when...
There is a small switch in the card that is currently in the locked position. you need to move it over to the other position to unlock it.
Aug 06, 2008 | Cameras
Memory card is write protected
SD and SDHC cards have a slide switch along one edge. The position farthest from the metal contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card.
Sep 17, 2012 | Nikon COOLPIX S6300 16MP 10x Opt Zoom 2.7...
SD Card Problems with Vivitar Vivicam 5118!
What size is the memory card. If it's larger than 4GB then it won't work in the 5118.
Try using another card. Don't format it in your computer but do format it in the camera before trying to take pictures.
May 05, 2012 | Vivitar ViviCam Cameras
A message always shows "MEMORY CARD IS WRITE
If you take out the memory card and look at it... it has a little button on the side... slide it over.... and then slap it back in the camera and that should take care of the problem.
You can also get the memory card locked/protected message if you are trying to use a SDHC card in a camera that does not support High Capacity (HC). High Capacity is any SD card with over 2GB of memory space.
Hope this helps.
Apr 26, 2011 | Nikon COOLPIX L4 Digital Camera
I inserted kinston 4gb card in my digital camera , while in the unlocked position of switch.But camera shows "memory card error" "card locked"
  • There is a write-protection tab on the mini sd card HOLDER. Every time you insert this into your PC or card holder, this tab slides to the write protect position. Either keep resetting, inserting & reinserting until it doesn't slide or tape it down.
  • There is nothing wrong with the mini sd card. Simply locate the write protection key and push it.
  • The mini sd card has some error: Go for a low level formatting.
  • The card has virus: Remove the virus. The link for the steps is present in the related link at the bottom of the article.
  • Read more: http://wiki.answers.com/Q/How_do_you_remove_write_protection_from_a_mini_SD_card#ixzz1Fvsnj1XE
    Mar 07, 2011 | Kingston 4GB Secure Digital High Capacity...
    Hi Team,, I have Nikon s4000 camera. I have an issue in cam, when i inserted a memory card, its showing "MEMORY CARD IS WRITE PROTECTED",, Please do needful.
    Take the memory card out of your camera and look at it. SD and SDHC cards have a slide switch along one edge. The position farthest from the contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card. If the switch is already in the proper position, slide it fully the other way and then back again.
    Feb 05, 2011 | Nikon Coolpix S4000 Digital Camera
    How do I remove the "write Protect " from my Olympus camera? I must have pushed some buttons incorrectly and suddenly it shows that "write Protect " sign. I already tried removing...
    Find the flash memory card that plugs into your camera and stores the pictures. It's usually behind a door or flap on the side or bottom. Remove the card, usually accomplished by pushing it in and then it should spring outward slightly -- at least enough for you to pull it out the rest of the way. Check the card for a tiny sliding tab on the side and move it to the opposite end of its travel. See this wikipedia article for pictures and more info about write-protection.
    Dec 17, 2010 | Olympus Cameras
    Camera shows a "Write Protect"
    SD cards have a slide switch along one edge. The position farthest from the contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card. If the switch is already in the proper position, slide it fully the other way and then back again.
    Nov 14, 2010 | Olympus EVOLT E-410 Digital Camera
    Memory Card
    They tricked you. The picture in the guide is of an SD card, but the card that came with the G9 is an MMC card. On both, there is a row of brass-colored contacts along one edge. This is what looks like ribbing in the guide. These contacts should go into the camera first. The memory cards will only seat if they are inserted correctly, so if it goes in far enough to close the cover, you have it in right.
    Jun 15, 2008 | Canon PowerShot G9 Digital Camera
    Panasonic Lumix  DMC-FX3 Digital Camera Logo
    91 people viewed this question
    Top Panasonic Cameras Experts
    Computer Links
    Are you a Panasonic Camera Expert? Answer questions, earn points and help others
