Question about Car Audio & Video
1993 chev 1500 silerado pu radio come on no sound
  • 5,370 Answers
First check the common thing, is the radio sound turned to max.If yes then its internal problem.There is short in radio circuit or short in radio wires.The radio has to be removed out of the dash and its wires are to be checked.Most probably its loose wire or any wire is got pinched and cut.The wire which is for sound.---------- The loose or cut in wire can be checked by meter as well as visually.------- Just connect external wire to the wire which is got cut in between and check.At local car radio repair store they check radio wires with meter and continuity tester to locate the short in wire.-------- some times wiggling the radio wire harness wires solves the issue as the loose wires gets connected or comes in contact with its connecting wires.---- This should help.Thanks.Helpmech.
Posted on May 20, 2011
How to remove the wiper cowl unit from a 1998 chev pu 1500
On most, remove the screws at the forward edge (sometimes hidden by rubber cowl seal), remove wipper arms, lift cowl and slide towards the front to release the rear edge, done!
Feb 27, 2015 | Chevrolet 1500 Cars & Trucks
How do i shift my 1993 chev 1500 into 4-wheel?
There is an actuator on the front end for the 4x4. It sounds like that is the problem because you hear the transfer case is locking in.
Feb 09, 2015 | Cars & Trucks
Fuse box diagram for 2006 Chev PU Silverado
"service air bag" is lighted up at odometer location, how do you reset it? Airbag has not been in no way deployed.
Jun 21, 2010 | 2006 Chevrolet Silverado 1500 2WD
How do I replace the radio knob on a 2006 chev pu
Generally the knobs just pull off and then you can press new ones on.
Jun 10, 2010 | 2006 Chevrolet Colorado
Chevy silerado 1500 350 v-8 where do
On the low pressure side of your system. The high pressure is by the battery on the aluminum tube hooked up to the radiator. Not that one!! But the other aluminum tube hooked up to your firewall going into the cab. Both of em looks alike. Is a quick coupler fitting with a black cap on it.
May 06, 2010 | 1999 Chevrolet Silverado 1500
I have a 2002 Chev Silerado. I believe the Air
before condemning the compressor, check the belt tensioners closely, as they are known issues on these. remove the belts and check for play in the tensioner pulleys. also check all the other pulleys at the same time.
Dec 29, 2009 | 2002 Chevrolet Silverado
Removeal of a 1993 chev 1500 pu 4wheel drive transmission
never seen one here in spain ,but put your overhauls on and get the tools out ,its just donkey work no experiance necessary just a willingness to get your hands dirty.Well thats what i was told by a former employer who had been to public school and regarded anyone with dirty hands as uncooth and slobish.Anyone that was anyone wore a suit,had a chauffear and spoke like lord haw haw
Mar 20, 2009 | 1991 Chevrolet K1500
Location of pcv valve on chev 1500 pu
its either the left or right valve panel.
Aug 16, 2008 | 2002 Chevrolet Silverado 1500
Car Audio & Video Logo
16 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
