Question about Endless Summer 200209 Open Flame Patio Heater
My pilot light wont light and my heater will not stay on.The ignitor is cliking as if it works but will not ignite and if I manually light it the lighter will not stay on.
  • 5,568 Answers
Essentially all gas devices regardless of which gas used, are equipped with a thermocouple that monitors the pilot light's condition and if it fails, it will not permit the main flame to light or the pilot light to stay lit. In your case, it may be that the TC failure also prevents the lighting of the pilot light.
Posted on May 20, 2011
Cannon k38 gas heater: mistakenly turned pilot light on gas heater off. I can't find instruction manuals or any help online. Can you re-ignite the pilot light manually or do I call a service agent?
Anon, To relight pilot check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
How to Light Your Pilot Light Gas Fireplace
Fireplace Pilot Light Tutorial
How To Light The Pilot Light On Gas Heater
Jul 02, 2016 | Water Heaters
If the egnitor won't work will the pilot light with a match or lighter on a pro-com 300H P A
If you in fact have button to push and hold, that indicates the system has a standing pilot with a thermocouple. Usually a standing pilot does not have an ignitor. I say USUALLY because I do not know all systems by heart. At any rate, I have to assume your system has a manual igniter like a barbeque pit and you push and hold the button while pushing the ignitor manually then release the button after 30 seconds or so of burning.......
IF THIS IS THE CASE, you more than likely have a bad thermocouple. The thermocouple when heated generates electricity that holds the safety coil in that is held in when you depress the button. If it fails to hold in by the thermocouple, the likely culprit is the aforementioned thermocouple HOWEVER, there is a slight possibility that the coil internal of the gas valve is defective if it does it AGAIN with a new thermocouple installed.
Dec 24, 2014 | Heating & Cooling
I have a Vanguard wall heater model VN18TB that will not stay lit and the electric igniter won't work
The ignitor is battery operated. Remove the button and replace the AAA battery wit the (+) going INTO the body (-) against the button.
The heater has a pilot with an Oxygen Depletion Sensing (ODS) safety shutoff system. The ODS/pilot is a required feature for vent-free room heaters. The ODS/pilot shuts off the heater if there is not enough fresh air. If the heater will not stay lit with plenty of fresh air available - this may be faulting. Likewise, a mispositioned thermocouple will not sense a flame and fail, too.
A link to the heater manual is below:
https://www.allpartsinc.com/mmALLPARTS/Others/VN18B.PDF
Feb 13, 2014 | Vanguard Heating & Cooling
Have winrich perfecta ventfree lp model 6380. Very hard to start. Ignition switch never worked correctly. Pilot and ods showing corrosion. Doesn't stay lit very long. Can I replace the pilot/ods a
First clean out pilot light with can of air , or blow down it with a tude.
Then brush electrode clean with a clean paint brush ,chech to see if electrode is in the right postion to light the gas not too far away and the spark is strong , Clean thermopile head if fitted, then check thermocuople /thermopile connections are tight . see if this helps .
Oct 28, 2012 | Heating & Cooling
We have a fairly new heater. went to turn on the pilot light and it won't ignite. what do you think is wrong? gas has been turned on before igniting
Sometimes it takes a few seconds for gas to reach the pilot. When you place the thermostat knob/gas control in the pilot position you must then depress it (push it down and hold it down). Wait a few seconds while holding it down, then press the ignitor button with your other hand while continuing to keep the thermostat knob depressed. You may have to hold the knob down and press the ignitor several times. You should see a spark at the pilot if the ignitor is working properly. Continue to hold the knob down for 30 seconds after the pilot lights, then release the knob, it will pop up & you can then rotate it to lo/med/hi and the heater will come on.,
Dec 02, 2010 | Procom (177653) Utility Heater
Can we relight the pilot manually or do we need an electronic lighter? Ours appears to have gone out. Also please verify that what we're looking at IS the pilot light! Thank you!
if it is a permant pilot then you can light it manually , if is a hot surface ignitor then you will have to replace it , some electronic ignition has to be replaced , as it self lights .
Hope this helps you
Nov 30, 2010 | Coleman Propane Forced Air Heater...
The fan will blow but not in heat mode. The gas heater sounds like it wants to work but there is no heat.
Hello my name is Heath it will be my pleasure to assist you. The problem is probably with the ignition. Check the pilot if its a standing pilot or the hot surface ignitor if it has a HSI ignition If you ohm the hotsurface ignitor and it doesn't show resistance the HSI is shot. If its a standing pilot try lighting the pilot if it lites and doesn't stay lit then the thermocouple could be bad its the rod that sits in the pilot flame easily replaced with a universal replacement that can be found at most hardware stores.
Apr 25, 2010 | Honeywell Programmable Thermostat Heater
New gas water heater pilot light will not ignite
Hi .. if this is a brand new heater, then you probably need to have the gas line bled. This means getting all the air out of the gas line feeding the burner. This can be done by constantly trying to light the burner or poilot . or it can be bled down by a HVAC tech.
Apr 09, 2010 | Rheem 40 GAL ELEC TALL Water Heater 6YR SC...
Water heater won't stay lit
Sounds like the thermocouple is bad , if , your holding the ignitor pressed long enough . Rating of 1 - 10 , this would be a 4-5 . Don't replace the pilot assembly , just the thermocouple .
Aug 27, 2009 | Dryers
I can't get the pilot to light gas is present can I light it
hayward millivolt htrs are very difficult to light manually.i'm assuming your piezo ignitor is mal-functioning.use a grill lighter withn a goose neck and follow aluminu pilot tube to pilot hood
Jun 06, 2009 | Hayward H Series Pool & Spa Heater 200k...
Endless Summer 200209 Open Flame Patio Heater Logo
582 people viewed this question
Top Endless Summer Heating & Cooling Experts
paulcarew
Tim Whalen
Are you an Endless Summer Heating and Cooling Expert? Answer questions, earn points and help others
