Question about Air Tools & Compressors
Where's the ac relay located at in my 1999
    Problem Solver:
  • 20 Answers
The a/c relay is in the under hood battery junction box ( relay # 2 ) there is also a a/c clutch fuse in the same box ( mini fuse # 1 ) if your a/c does't work you may want to check the freon charge first--- the a/c clutch usually falls apart on fords & they **** on marking the fuse covers !!!!!!!
Posted on Jun 07, 2011
Need aux relay Box location in 2001 Ford Explorer Sport Trac for the door lock relay I think its called # 3 aux or # 4 Aux anyone know where it is located?
I could only find auxiliary relay box 2 and had to guess whether your Explorer is early or late production and has keyless entry or power door locks. If you have the central junction box located, trace the BLU/WHT wire to the rear until you find the other end connected to the relay box.
Apr 14, 2017 | Ford Cars & Trucks
Names & locations of the relays in the auxiliary relay box 1 on a 2003 ford explorer sport trac
There are two relay's for the fog lamps in that relay box . fog lamp isolation an fog lamp relay . You can find a diagram here http://www.bbbind.com/free_tsb.html Enter your vehicle info. year , make , model , engine size . Under system click on electrical distribution , then under sub system click on relay . Hit the search button , then click on the link . Good luck !
Mar 21, 2017 | 2003 Ford Explorer Sport Trac
2003 ford explorer sport blinker dont blink on the dashboard... How do I fix it??
if the bulbs on outside are ok, and it will not flash on dash and stays completely lite up. replace the turn signal flasher. Look under the steering column and locate the fuse box. The fuse box is under the plastic kick panel. Under the panel is a yellow case that holds the turn signal relay. Test that this is the relay by turning it on and placing a finger on the relay. You should be able to feel the relay clicking. Pull the relay from the socket and plug a new one back in. Reattach the kick panel and start the Explorer. good-day !
Jan 20, 2012 | 2003 Ford Explorer Sport
What is the fuel pump relay number in the fuse box of a 2001 explorer sport? is there another relay in there i can switch to see if the pump relay is bad?
you can find the location of this relay from the owners manual, if you don't have one you can download one from fleet.ford.com, or try your local library. The A/C relay, horn, and Fuel pump relays are all the same. Hope this helps, let me know
Nov 19, 2009 | 2003 Ford Explorer Sport
Where is the fuel pump relay in a 2001 explorer sport
The fuel pump relay is in the fuse box under the hood on the left side (drivers side). The cover of the fuse box has a diagram of location of each fuse/relay.
Where is the fuel pump relay located in a 2003 ford explorer
in the underhood fuse box just beside the master cylinder the fuel pump relay location number is 50B, in the same box also check fuse # 23
A 20 Amp Mini fuse for fuel pump power
Oct 28, 2009 | 2003 Ford Explorer Sport
Where, exactly, is the orifice tube located on my truck?
the orfice tube is locate in the line between condenser and evaporator. near the spring lock coupling. you must unbolt the cruise servo and overflow bottle, reposition them out of way and you will see the line connection..the orfice is inside line near that uniion. the ac system must be evacuated prior to removal, and recharged afterwards..
Jun 03, 2009 | 2003 Ford Explorer Sport Trac
Fuse diagram for the 2001 jeep cherokee sport 4.0L needed
Believe the AC compressor Relay is located on the left side of the Fuse block inside the passenger kick panel. Exact location is in your owners manual.
Fuel pump relay is inside of the Engine Fuse block under the hood on the passenger side. Locations are written inside of the lid.
May 30, 2009 | 2001 Jeep Cherokee
Location of fuses and relays for the rear window defroster
two locations, one under dash and one under hood. without your manual, thats about all I can help you with
Dec 18, 2008 | 1999 Ford Explorer
Air Tools & Compressors Logo
140 people viewed this question
Top Air Tools & Compressors Experts
John Trevino
Joe Garcia
Joe Garcia
Are you an Air Tool and Compressor Expert? Answer questions, earn points and help others
