Question about Feber Roadster Waverazor Battery Powered Childrens Car
I need to buy a new motor part no E 410886 for my son eletric car ,or replace ment to fit cogs and housing could you adivse, thanks
    Brigadier General:
  • 3,301 Answers
Call these people for parts Toll Free: 1-888-886-6245
Posted on May 20, 2011
Any ideas where to buy a Boss Therm BZV22 or the equivalent Siemens RMH? Many thanks
This is a two port zone valve used in plumbing. Why is it posted in Cars and Trucks? I did find it available online at Havelock Controls.
Nov 24, 2014 | Cars & Trucks
Hi my fisherprice amazing animals train is making a horrible noise when it moves. like cogs are slipping??
we had the same thing, son had been pushing / sitting onthe train while it was moving. there is a blue motor assembly with several cogs inside - the cog attached to the belt driven wheel needed to be pushed inwards so that it lined up properly. needed a bit of pressure but it wasnt too fiddly.
Feb 23, 2011 | Fisher Price Amazing Animals Press and Go...
In the first cycle just before the water gets pumped out it stops and doesn't continue.So I found out as I pushed on the lid switch a few times that the machines cycle dial would start and would finish all...
My next step would be to open the unit up and be able to observe (safely) the timer/switch. There is a motor turning a cog wheel, that pushes and releases the electrical switches.
You want to witness the turn rate of this drum, or be able to see the motor output gears......then run the machine to the problem position and observe....
If the motor is NOT runing and the cog wheel is NOT turning, something is interrupting, perhaps a safety switch like the lid switch....
If the motor is running and the cog wheel is turning, you need more patience... Some designs reverse the motor and there is quite a number of degrees of that cog wheel that in needs to trun through, or they run the risk of damaging the motor, so a pause cycle...
Be sure that BOTH hot and cold water hoses are hooked up, on and flowing. Some machines stop waiting for cold water.
(This happens when hoses are reversed going into the machine, Dad gets large hot water bill, has fit, goes and turns off the hot water (which was hooked up to the cold water tap...) and a machine will need filling and wait forever with no water flowing into machine. Often you get a buzz of the water valve, while the machine waits.)
Dec 24, 2010 | Westinghouse WWS833ES Super Capacity Top...
Hello, Im looking for a part number, I was
The parts department at any VW dealer would be happy to show you an illustrated parts breakdown on the car. That way with just a little time and effort effort you would know the name of it, the part number, the cost at a dealer, and the amount of time required to install it. Most likely you are going to have to buy the entire wiper motor assembly, you will not be able to get internal parts, and they could give you the price on that as well.
Oct 28, 2010 | 2001 Volkswagen Golf
Plastic cogs have worn in motor can i get a replacement part or will i have to buy a new motor for my childs rodeo 4x4
i have got a kids 12 volt ride on hummer. i need a cog for it. can you help me
Feb 20, 2010 | Toys
Blender base cog is stripped. Can it be replaced
yes you can get a new base. your best bet is to google the brand name and buy the part from the manufacturer
Aug 12, 2009 | Blenders
Ssangyong rexton engine problems
was told from the dealer that it would take around 8 to 12 weeks as there was a back log of parts coming from korea,So went to mercedes to order the part and they said that they were nothing to do with ssyangyong. so went to my local breakers yard and got a starter ring gear from a old mercedes 2.0ltr petrol auto engine and with a small amount of modifacation and three clamps and a eletric drill gun, lay the sourced ring gear on top of your old ring gear match up the large blank spaces,just make sure you sit the ring gear the right way round i.e the way it came off the car as you will see the mating hole dont totaly line up and one is out using your starter ring gear as a template drill out the hole that is out refit the replace ment ring gear to your car rebuild the box.
have done this three times to diffrent rexons now,and to date the cars have had no problems and run great . Ok not the shortes posts but it did not take 8 to 12 weeks to read or write.
part from the breakers yard £15, to drill the part 10 mins , to strip and rebuild the car including going to the yard one 10hrs total cost well thats up to who does the job for you but it not that hard a job to do.
Jul 26, 2009 | Mercedes-Benz CLS55 Cars & Trucks
My blower motor will only blow on level 4 and 5. 1,2 and three
Inside the blower housing under the dash by the floor is a resistor that fits inside the housing. It gets damp and burns open. Cheap to buy part, takes a contortionist to replace. I managed, and I'm old. It has two wires going to it.
Jun 15, 2009 | 2003 Pontiac Grand Am
Craftsman air compressor bearing flywheel
Your local hardware store should have one. The model number will probably not help; you will need to measure the keyway width and height to buy key stock of those dimensions then cut off the length you need.
Hope this helps.
May 21, 2009 | Craftsman Air Tools & Compressors
F1245w
I have always fitted the the motor cog first then start by placing belt on half of the drum cog as much as you can, then by hand turn the drum and the belt should slip on.
lee
Jun 11, 2008 | Zanussi F1245W Front Load Washer
Feber Roadster Waverazor Battery Powered Childrens Car Logo
297 people viewed this question
Top Feber Toys Experts
Adam Fjeld
Adam Fjeld
Andrew Taylor
Andrew Taylor
Are you a Feber Toy Expert? Answer questions, earn points and help others
