Question about Behringer Xenyx 1832fx Mixer 18 Input 32 Bus with Efx USB
Need Behringer XENYX X2222USB schematic Need signal flow to design a system.
4 Suggested Answers
  • 5603 Answers
SOURCE: LEVEL POT ON A BEHRINGER EURORACK MX 602A-BAD
It appears that both these use a 50K pot in the identical circuit and it is UNLIKELY they re-engineered very much so it is likely they use the same pot.
Behringer parts service should be able to tell you.
Posted on Apr 28, 2010
  • 5603 Answers
SOURCE: type pf op amp in a Behringer XENYX 1204USB Mixer
Behringer uses 4580's in appropriate packaging everywhere. There are 339 comparators for the level indicator area.
The Mackies uses both NJM2068 and NJM4560M
The 2068' are used in most of the low noise areas and the 4560 is used in the 75Hz high pass filter for example.
Posted on Jul 23, 2010
SOURCE: Please, I need a Behringer xenyx 1202fx list of
Go to the Behringer website and then the product page for the mixer. On that page are links to the manual, spec sheet and something called view sheet. The "view sheet" has a wiring diagram and a list of the effects.
Posted on Aug 21, 2011
Behringer XENYX 2442 FX: Turntable into CD/tape IN. CD/tape OUT connected to USB device IN. Why is there no signal from mixer to the computer?
If I read correctly, you have outputs on the Behringer (CD/Tape Out) connected to inputs on the Behringer (USB Device In). Is that correct? If so, try going from CD/Tape Out directly to the computer. If not, please explain what the "USB Device In" is.
Thanks,
Rich
Apr 30, 2012 | Music
How would i connect a Behringer 1002B Xenyx to a hercules mk4 mixer
The main output jacks of the 1002 are PSUEDO balanced so you can use TS to RCA connections from the 1002 to the MK4. It is not hte best design, but it will work... with two cables go from the 1002 main outs to the stereo ins of the MK4.
Sep 19, 2011 | Behringer XENYX 1002B Mixer
BEHRINGER XENYX 2222FX POWER SUPPLY REPAIRED BUT NO AUDIO AND MAIN AUDIO OUTPUT LEVEL LED NOT RESPONDING
I suspect that there is a problem on the effects board. Most of the signals go through this board. I would check the seating of connectors associated with the board.
Aug 22, 2011 | Behringer XENYX 2222FX MIXER
Right channel gone down. xenyx 2442
Here is a schematic than is for a less number of channels (they just repeat) than yours, but is enough to fix it:
http://elektrotanya.com/behringer_xenyx_1622fx.pdf/download.html
Scroll down to the little link "Get Manual" and download it.
Mar 30, 2011 | Behringer XENYX 2442FX Mixer
Hi all i own a behringer XENYX 802 audio mixer. this device is powered by a power supply that as input to the mixer gives 18,5 x2 Ac, 150ma. i would like to know in which point of the circuit i can...
You would need TWO DC supplies as they use AC so they can create both a plus and minus 15 volt power source to run the internal op amps.
Here is a schematic for the 1202 which has same power supply configuration as the 802.
http://elektrotanya.com/behringer_xenyx_1202.pdf/download.html
Scroll down to the little link "Get Manual" and download the service manual and schematic. You will find the power input in the upper left corner of page 5.
Mar 29, 2011 | Behringer Xenyx 802 8-input 2-bus Mixer W/...
How much output power supply behringer xenyx 1832fx?
The supply will be similar to that in the 1222. Download a schematic here. Look at the SPUS2 portion of the compressed file.
http://elektrotanya.com/behringer_xenyx-1222fx_v1000_dpm5m_ub-spsu2_sch.zip/download.html
There are several voltages present.
Jan 20, 2011 | Behringer Xenyx 1832fx Mixer 18 Input 32...
Where can i get a schematic for the xenyx 1002 mixer
Try this:
This is for slightly different model, however Behringer uses same circuits in most of this series... AND they don't give out schematics.
Dec 21, 2010 | Behringer Xenyx 1002fx Mixer 10 Input 2...
How do i hook up a powered moniter to the behringer xenyx 2442fx mixer?
hook it up to one of the aux output sends (1 or 2), and use the corresponding aux send knob per channel to put each channel necesarry into the monitor signal.
Nov 20, 2010 | Behringer XENYX 2442FX Mixer
Behringer Xenyx 1832fx Mixer 18 Input 32 Bus with Efx  USB Logo
429 people viewed this question
Top Behringer Music Experts
Vito Vacirca Jr.
Matthew Spark
Matthew Spark
Ben Armstrong
Are you a Behringer Music Expert? Answer questions, earn points and help others
