Hi ther I have a LG plasma TV model # RU-42PZ61 this one have two vertical lines one blue and one red. what's the problem on this Item please help?
  • 3 more comments
  • THEY ARE LIKE ONE INCH THICK UP AND DOW
    I CAN'T SEE TRUE THE LINES
  • http://imageshack.us/photo/my-images/577... http://imageshack.us/photo/my-images/62/... http://imageshack.us/photo/my-images/535...
  • yes sr I will replace the board my self I just need the name of the part or a link where can I buy it.
    you are a good profecional man thankyou very much......
  • Thank You!
  • hi remenber mi heare are some more info the screen blinks and turn ligth blue or green but you syil can see pictures some times blinks like a bad video card like pictures on negatives
  • 4,889 Answers
Are these lines thick and opaque or are you able to see the picture through them? If you can just get me a picture of the screen that would be great. You can upload it to imageshack.us and get me the link
Posted on May 20, 2011
  • 1 more comment
  • eagle338
    eagle338 May 20, 2011
    That sounds very much like a buffer boards issue. But I cannot be 100% sure until I get the image . So please take your time and upload the image when you can. I will confirm if that's the problem and get you the links to order replacement parts.
  • eagle338
    eagle338 May 21, 2011
    Yes it is definitely due to the buffer boards . So would you like to replace the boards yourself?
  • eagle338
    Ok Here's the plan. We cannot know which board is faulty with out testing the buffer AKA driver boards with special equipment(oscilloscope) . So we are gonna have to replace all 4 of them . They cost about 125-150$ together. All you gotta do is to get me the part numbers of the three slender boards that look like this
    http://assets.shopjimmy.com/media/catalo...
    The Y-drive looks a little different like the below image.If you zoom the image below you will find the part number printed on a white sticker in the top left corner. Starting with 6871.xxxxxxx.And the Y-drv board that looks like this
    Get me the part numbers of all 4 parts and I will get you the links to the replacements
  • 2,098 Answers
This symptoms indicated of malfunction on the logic board, sustain boards, and/or power supply board. This is responsible for processing the image in your unit. Your unit is prone to bad connections in the said board. You must take it apart and check the cable connectors from loose connections. Pull-out all the cables from the main board, logic board, sustain boards, power supply board and then re-insert securely.
If the symptom still persist, first to check is the output of the power supply board feeding these boards. Once missing voltage from the power supply it will disable the other board and produced same symptoms. If you confirmed that the power supply is not the issue, then the fault now is quite technical and you need a copy of the service manual if you are going to DIY. This will guide you to the test point on that board.
If you don't have necessary tools and test instrument and can't troubleshoot the symptoms yourself, I would advice you to look for a qualified LG tv technician to isolate the symptoms.
Also check if your unit is still under warranty/extended warranty period, avail it because the manufacturer will fix it for free. Don't open the back cover because it will void the warranty.
Hope I helped you.
Have a nice day!
Thanks for using Fixya.
Posted on May 21, 2011
  • Jdvillanueva
    Jdvillanueva May 21, 2011
    I think you have a new comment but I can't see it...
LG vertical green line
LG plasma vertical line repair - YouTube
? 2:33
https://www.youtube.com/watch?v=24FkcQoeGPg
Feb 10, 2013 - Uploaded by Matt Mayer
I have an LG plasma, my vertical line is in the middle, as if one would have ... Panasonic Plasma TV TC-P50X5 Vertical GreenBar Line Fix ...
EASY HOW TO FIX LG plasma TV - color bars - YouTube
? 4:45
https://www.youtube.com/watch?v=QyaBiSkc1l8
Dec 16, 2010 - Uploaded by Tampatec
diy HDTV Plasma tv repair tv reparar the red green blue color stripe line vertical bars T- control t-con ..
Jan 16, 2016 | LG Televison & Video
42inch LG plasma TV
well if you could please give out the model nuumber thank you
Sep 10, 2008 | LG RU-42PZ61 42 in. HD-Ready Plasma...
I have a blue line on the right and a red line on the left. What board do I need to replace and what is the part number?
Hello:
Try replacing the T_Con board first. if this does not solve check the capacitors on the power supply for puffy tops, if you find some replace them with same voltage rating and Capacitance.
Dec 23, 2010 | LG RU-42PZ61 42 in. HD-Ready Plasma...
LG RU-42PX11 42 plasma TV has black bar
The screen does not work properly .Ribbon wire fails.
Mar 31, 2009 | LG 42PX5D 42 in. Plasma HDTV
Half my screen works
I had this, and it was just a small connection that was loose.
Dec 22, 2008 | LG RU-42PZ61 42 in. HD-Ready Plasma...
LG Plasma TV RU-42PZ61 vertical bars of all colors
sounds like your deflection circuit is weak..seems a power supply issue is at hand..what documentation do you have in your possession?
Mar 29, 2008 | LG RU-42PZ61 42 in. HD-Ready Plasma...
Same problem with my RX-42PX11 , sound and full screen of multicoloured vertical lines,disconnected all, but still same problem,any help would be welcome.
I have the same issue with my RU42PZ61, and I think it's the power supply board, but I'll take it to my repair man. He diagnoses it for $25.00, and tells me what part I need.
Oct 28, 2007 | LG RU-42PZ61 42 in. HD-Ready Plasma...
Red Vertical Line and Black Screen, Sound OK
Check this out
http://forum.eserviceinfo.com/viewtopic.php?t=30810
have a nice day
Oct 08, 2007 | LG RU-42PZ61 42 in. HD-Ready Plasma...
Televison & Video Logo
93 people viewed this question
Top Televison & Video Experts
Electro Med Services...
