How do you clean inside where stuff gets trapped along the edges
    President:
  • 1,082 Answers
I use a tooth pick or match stick which I split or shaved to a point to clean in tight narrow edges. Never use any metal item.
Wood is best, be carefull, dont force it. Gently !!!
Posted on May 20, 2011
Is it true about mold in keurig coffee makers
Any place that heat and liquid can get trapped, mold can occur. This is why descaling is important for traditional coffee makers and even for tea pots. Basically, keep your stuff clean.
Biofilm Slime Bacteria inside the inner tubes of the Keurig Coffee maker
Sep 30, 2014 | Keurig B70 Coffee Maker
Please describe how to clean dirty edges on the paper from my KM2430DL printer.
Inside these machines is a rather large, black sheet that is known as the transfer belt. This belt acts to transfer the toner from the drum to the paper, Though if the outside edges of these sheet become worn or mucked up with excess toner, it will produce a copy with vertical bands of toner. In order to attempt to clean this belt, you must first shut the machine off, then open the from cover and locate the transfer belt (may need to remove the toner in order to make it visible,) then, with a damp cloth (water) gently wipe it along with the grain of the belt. Repeat this step until no residual toner appears on the transfer belt, then reconnect everything and print several test pages. If the problem does not reappear, then you are all set. However, if the dirty edges begin to come back, you will need to replace the transfer belt as the wear marks on it are trapping toner and not allowing it to be cleaned properly.
Please keep me informed on your progress and I will help the best I can.
David R.
Dec 11, 2010 | Konica Minolta magicolor 2430 DL Laser...
Washing machine is not completing spin cycle at high speeds. Only goes slow speed tumble for a few times and then stops.
Below is for Whirlpool/Kenmore, u might find it helpful. Some machines have a small trap door on left front bottom, coin trap.
The filter on your pump is probably clogged with lint and stuff. You have to remove the bottom front panel, 3 torx screws underneath. The panel will drop and come off. Drain off the excess water from the drain pipe you see. The white filter cover is right in front. Get yourself a good plastic bag to collect water. Unscrew the filter cover and twist the filter out. Clean out all the stuff and put it back in carefully. Check your pump too, comes after the filter.
On some models the filter is located ‘inside’ the big hose from the bottom of the tub. This takes more time to clean.
Jun 04, 2010 | Frigidaire ATF6000ES Front Load Washer
Inop.
Pl rate me nice for the free help, thnks
Jun 04, 2010 | Frigidaire GLTF2940ES Front Load Washer
Leak from dishwasher door
Usually this problem is an easy fix. Try this first.
1.) clean the rubber seal that goes around the door and the knife edge on the unit with a dish rag to remove any dirt. Also check for cracks and dents as you go. If you find a crack in the rubber ... replace .
If you find a crack in the plastic knife edge of the unit, you will have to epoxy it and sand smooth (carefully)
2.) OK, if that didn't help ...on mine, there is a steam release vent. On the outside of the door is a vent that releases steam from the hot water. On the inside of the door is a removable water trap that might be full of old gunky stuff. Clean that stuff out of there.
WHEN MY UNIT WAS LEAKING WATER IT WAS #2
Let me know if you need more help.
Best of Luck,
RSMITH972278
Oct 13, 2009 | Neff 24 in. S5456 Built-in Dishwasher
I want to remove the screen of my 42" Toshiba TheaterWide to clean the bulbs of dust and the inside. How do I remove the screen to get inside?
there are screws behind the speaker cover-remove them-take out screws along back edges-carefully remove screen(its plexiglass) clean all 3 tubes with a soft cloth -be carefull cleaning screen most liquids will stain it-also clean mirror-reassembly unit
Sep 03, 2009 | Toshiba 42H81 42" Rear Projection...
How can i clean the hose of my bissell spot bot? It looks like mold is beginning to grow in the hose.
Well... it's sub optimal but this is what I did, run hot water into the sink, add a few table spoons of bleach and run the hose along the edge of the water to slowly **** it into the hose (the tank fills very rapidly and the auto shut off will activate). You will want to run 4 or 5 tanks of waste to get the bulk of the gunk along the walls out and this will also get rid of the serratia growing (red stuff). If you dangle the hose in a u down the front of the sink and shut off the machine you can catch about a pint of water and bleach solution in the hose and roll it around inside the hose then let it sit for awhile and finish by sucking it into the waste tank, not perfect but my hose is much cleaner.
Jun 15, 2009 | Bissell SpotBot Hands-Free Compact Deep...
E20 message I get on my washer machine
Apr 15, 2009 | Frigidaire ATF6000ES Front Load Washer
Getting an error code E20.
The filter on your pump is probably clogged with lint and stuff. You have to remove the bottom front panel, 3 torx screws underneath. The panel will drop and come off. Drain off the excess water from the drain pipe you see. The white filter cover is right in front. Get yourself a good plastic bag to collect water. Unscrew the filter cover and twist the filter out. Clean out all the stuff and put it back in carefully. Check your pump too.
Apr 12, 2009 | Frigidaire ATF6000ES Front Load Washer
102 people viewed this question
 Grubhead
Grubhead
