Question about Dell Photo 964 All-In-One InkJet Printer
I have a dell 964 all in one printer. It was working great then, it just went blank, power disappeared, I will not power up. I check the connections, the wall outlet. I would like to fix it, I can't imagine it not being fixable.
  • 33 Answers
Try a known good power cord and wall outlet and see if the printer would power on.If there were any power outages before the printer stopped working, most likely it got damaged by an electrical surge. If the printer powers on after replacing the power cable, check the operator panel display for any error message. Check page 89 of the printer manual for an explanation. The manual can downloaded from the link below:
http://support.dell.com/support/edocs/Systems/PRN964/en/om/om_en.pdf
Posted on May 20, 2011
I lost the installation cd to my dell All in One photo 964. Is there anyway I can get anotherone mailed to me, or can I download it online?
No, Dell will not send out printer disks. The drivers can be downloaded at...
Dell 964 Photo All-In-One Printer owners thread (W7) Since you have no printer disk, you'll need an OCR Program so youm can scan documents. Simple OCR should work nicely with this printer.
Rick
Jan 10, 2011 | Dell Photo 964 All-In-One InkJet Printer
How and where does the power cord plug into the computer
964 all in one printer does not switch on eventhough it is plugged in and a green light shines on power cord box. on off switch does not work
Nov 11, 2010 | Dell Photo 964 All-In-One InkJet Printer
How do I install a dell 964 printer without the cd
Windows XP Driver : ftp://ftp.us.dell.com/printer/R113115.EXE
Widows Vista Driver : ftp://ftp.us.dell.com/printer/R146717.exe
Select the one approriate for your Operating System. Download and run the Setup file with the Printer connected and powered on.
BD
Sep 06, 2010 | Dell Photo 964 All-In-One InkJet Printer
964 Dell printer will not connect to wireless network
As for the 964 printer, ues you can make it wireless by using a Dell Wireless Printer Adapter 3300 or some type of wireless print server. To install the drivers for the 964 printer, you will need to post in the Dell Printers Forum, as the printer drivers on a Vista machine are a little tricky to install but I have my 964 printer working with a 3300 , (thanks for Rick dell forum)
Jan 10, 2010 | Dell Photo 964 All-In-One InkJet Printer
Is there a fix for the compatiblity issue of the Dell AIO 964 and Dell Studio (64 bit) laptop?
From the manufacturer's web-site:
http://support.dell.com/support/downloads/driverslist.aspx?c=us&cs=2684&l=en&s=pub&os=WW1&osl=en&catid=&impid=&SystemID=PRN_ALL_A960
(for the 'AIO 960', not your 'AIO 964' model), there currently is no "64-bit" drivers. Will the 32-bit driver work?????
I could not find ANY information about the '964' printer.
Jan 02, 2010 | Dell Photo 964 All-In-One InkJet Printer
I have a dell Photo 964. I shut off the printer to clear a paper jam and it went dead. The on/off button light does not even light up.
lift the printer and shake to check if it sounds like a piece broken inside.. turn the printer off take the power brick out from the back.. manually pull the cartridge to extreme right then center.. check if cartridge is aligned correctly.. if nothing of this works.. contact dell for replacement under warranty.. if out of warranty.. inkjet printers cannot be repaired if broken.. u can buy a dell v313 of same quality for $119 with warranty..
Dec 23, 2009 | Dell 962 Photo All-In-One InkJet Printer
Dell 964 printer will not power up/turn on.
Check you fuse near the power supply, see if it is busted
Nov 05, 2009 | Dell Photo 964 All-In-One InkJet Printer
I had a paper jam this morning, cleared the paper jam, and now the printer will not power up. I tried to remove the usb cable, and the power cable, reboot the computer, and replug in the usb and power...
First, Make sure that the printer is properly plugged in to a working electrical outlet and that it is hooked up to the computer as indicated. There should be two separate cables running out of your Dell 924, a power cord and a USB cable that communicates with the computer. If both of these aren't plugged in, then the machine will not function properly.
If the lights on your printer aren't working then it means one of two different things:
  • Printer has an internal electrical problem and needs repair or
  • Printer isn't receiving power from the outlet or power cord
Check whether, are you getting power from the socket by connecting some other component..If it works check whether the Power cord is propwerly connected, try pressing the power cord once..
If not the circuit may be damaged, Which cant be repaired inhome, you have to return to DELL service center and make it repaired
Please leave me comment, if you need further assistance
RNJ VINODKUMAR
Oct 09, 2009 | Dell Photo 964 All-In-One InkJet Printer
Just beeps at me not hooked up to usb port but is.I cant find the disc that came with printer. downloaded some drvers from dell, but they tell power must be on and connected with usb port.Printer is on and...
unhook the printer from the computer. install the drivers and then hook up the printer. They should self install.
Does the computer tell you it found new hardware?
Jul 07, 2009 | Dell Photo 964 All-In-One InkJet Printer
I can't print in color on dell photo 964
try to uninstall ur driver and install it again
Jun 07, 2009 | Dell Photo 964 All-In-One InkJet Printer
Dell Photo 964 All-In-One InkJet Printer Logo
Top Dell Office Equipment & Supplies Experts
jasbo
jasbo
Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
