Question about Intermec EasyCoder PC4 Label Printer
Intermec PC4 label printer
The labels seem to be printing out half way on a label that is 1 and a half inches in height and width
  • cbcalimero Apr 29, 2009
    After the selftest I press for 3 sec the feed button, and then the light get red. What can I do???
    Problem Solver:
  • 6 Answers
Your printer is not sensing the gap between two labels.Please try calibrating the printer for the gap.
Switch ON the printer while holding FEED key down, on printer start feeding label realese the FEED Key.
Printer will stop feeding paper after printing SELF TEST, Once again press FEED key for 3 seconds. Printer will enter into normal Mode.
Check now.
Posted on Aug 15, 2008
SOURCE:
Wont print label correctly
Go into your printer preferences and check your default label size.
It must match the label size you are printing to. This must be done for each user of the computer.
Mar 02, 2014 | Intermec EasyCoder PC4 Label Printer
How to adjust intermec to print thicker labels
Only user Intermec Labels or they will probably not work.
Feb 20, 2012 | Intermec EasyCoder PC4 Label Printer
Label height is not managed correctly on the intermec easycoder PC4 that I got second hand... How to deal with this issue???
Go to printer properties and put in the custom label size. You will need to do this for each user of the computer.
Jun 28, 2011 | Intermec EasyCoder PC4 Label Printer
Intermec PC4 is skipping over blank labels when it prints. It prints one label then skips over 3 or 4 labels before it prints the next one
Make sure that the label is not larger than the printable area, carriage returns and spaces count as part of the label too. Also make sure that in the printer properties you didn't set the page width wider or higher than the actual label. Especially using MS Word, you may have to adjust the label slightly smaller to compensate for margin, header, and footer settings. Also be careful of mail merges which merge data larger than the viewable area on the label.
Oct 02, 2009 | Intermec Office Equipment & Supplies
PC4 doesnt appear to recognize ANY IPL coding
1. Add Generic Printer to printer list.
2. Select Generic printer as Default printer
3. open the document and print.
Jul 14, 2008 | Intermec EasyCoder PC4 Label Printer
Failed to print using Intermec Easycoder pc4 label printer
If you have another USB port asidefrom the oneyou are using now try to transfer your printer cable. Make sure your USB port is firmly connected to the motherboard. Follow the USB connectors and check if these are well fitted and not loose.Apply pressureon the endsto set the connectors.
May 12, 2008 | Intermec EasyCoder PC4 Label Printer
Will not print labels
you have connected two printers on a data switch.right.
1. Print test page through Printer driver.
2. If you are using command for printing on Intermec printer, you should not use generic printer.
3. Interchange the cable connected to printers
May 01, 2008 | Intermec EasyCoder PC4 Label Printer
Intermec EasyCoder  PC4 Label Printer Logo
1,036 people viewed this question
Top Intermec Office Equipment & Supplies Experts
Paul Bade
Wbix
Jay Plesset
Are you an Intermec Office Equipment and Supply Expert? Answer questions, earn points and help others
