Question about Rowenta DX6700 Iron
My rowenta iron is turning my white clothes brown
satscoop
  • 59 Answers
SOURCE: Brown spots coming from steam iron
you can mix 50% water with 50% vinager let it set in the iron overnight then turn it on and let the steam run out.What happens is the inside of the iron where the water is had corroded or rusted or has lime deposits.the vinager will break this loose overnight.also after you let the iron steam out all the mixture,flush the iron 4 to 5 times and start using fresh water from a store bought gallon.your tap water is probably full of iron.
Posted on Nov 15, 2007
SOURCE: BRown water and stuff coming out of iron
To clean the sole plate, Rowenta has a sole plate cleaning kit for $9.99, however, Dritz sewing notions makes one too and it is much cheaper. You take an old CLEAN dishcloth and squeeze about an inch of the cleaner on the towel. Using a hot, dry iron move it back and forth over the cleaner until the sole plate is smooth and clean. I then use a q-tip to clean any residue from the sole plate. Keep turning the towel until all the cleaner is removed from the iron. Any time my iron becomes sticky I use this method and it works great.
Posted on May 06, 2008
  • 304 Answers
SOURCE: Rowenta Iron
TO CLEAN THE BOTTOM OF THE IRON, MY NAN USED TO ALWAYS IRON BROWN PAPER, IF THIS DOES NOT WORK, USE A RAG DIPPED IN THINNERS, OR LIGHTER PETROL AND RUB GENTLY.
NORMALLY THE SELF CLEAN SYSTEM IS JUST A BUTTON NEAR OR ON THE TANK THAT YOU PRESS WHILE THE IRON IS ON AND HAS WATER IN, PRESSING THE BUTTON WILL FORCE WATER THROUGH THE STEAM JETS (SO KEEP IRON FACING DOWN) ALSO EMPTY THE IRON AFTER EVERY USE
Posted on Jul 01, 2008
geokohler
  • 304 Answers
Fill with 50/50 water vinegar solution. Get it good and hot and let it sit for two hours. Rinse and repeat if necessary. Buy a gallon of water from the market and use that from now on. This will fix your problem. The Iron is concentrating the iron in you water and this is what is causing the brown spots. Hope you find this helpful. If you do please take the time to rate it fixya and maybe I will keep helping people for free.
George
Posted on Jul 24, 2008
  • 2976 Answers
SOURCE: Iron spits out rusty water. The iron is a Rowenta
Fill it with a mix of 50% white vinegar and 50% water. Let it set for 30 minutes and steam it out for about 2 minutes. Unplug it and dump it. After it cools colpletely, fill it with water and steam it out. The rust is coming from your water supply, not the iron.
Posted on Oct 06, 2009
Rust colored steam that stains clothing ironed
Hi, Brown water and whitescale are often the result of the water you use in the iron... If you have scale, white vinegar will clean that... For brown water, empty the iron, rinse out the insides with bottled water, and then use the bottled water instead...
Also check out this tip...
Cleaninga Steam Iron White Scale and Brown Water
heatman101
Mar 22, 2011 | Rowenta DZ1700 Iron
My Rowenta Expert steam generation iron (seperate tank for the water type) is starting to spit ever so often brown water out. I only use filtered water. How can I clean the actual Iron, the water tank is...
heatman101
Mar 16, 2011 | Rowenta DG-980 Iron
I use distilled water in my Roweta. When ironing a white shirt this morning, brown water came out and stained the shirt. What could have caused this and what can I do in the future to avoid this?
Brown water and white scale are often the result of the water you use in the iron...
Cleaning a Steam Iron White Scale and Brown Water
heatman101
Jan 22, 2011 | Rowenta DX6700 Iron
My Rowenta iron seems to be scortching my white clothes, the plate is stainless steel but seems to look iridescent
if its a light brown appering on the whites, its just to hot, lower setting. also make sure the plate is clean. the stainless changes colour from heat after a while, this is normal
Aug 08, 2009 | Rowenta Professional DM890 Iron with Auto...
Brown water staining clothes when ironing
either the water has sat in the iron too long between uses
or its the iron in the water you use.
you will have to flush out the old water.
try distilled water
Jun 27, 2009 | Rowenta DX6700 Iron
Hi, two problems:
DIA' s problem - the brown water is due to poor water quality and debris in the boiler and iron sytem. Rowenta is clear that they do not want anyone to cleaning solutions - only clear filtered drinking water to rinse out the boiler (via the water inlet screw hole) and I have found running the system dry, letting it cool, rinsing and draining the boiler several times before putting unit away works fine.
Guest' problem with brown/black tar substance is likely caused by too hot and iron setting (steam setting may also be too high) for ironing man-made synthetics (like Nylon, Rayon, Polyester or blends are basically petroleum based fabrics) that breakdown or melt, leaving deposits on the iron's stainless steel soleplate. A secondary cause could be bad water or debris in the boiler/iron in which the solution for DIA's problem might provide relief. Cleaning the soleplate is tricky, I use nothing stronger than an old fashioned wooden orange stick to gently scrap of all traces of the "stuff" and dry "Dutch" cleanser w/ a terry cloth or old cotton sock to polish without scratching the soft stainless soleplate...
Apr 01, 2008 | Rowenta DG-980 Iron
Brown gunge and white deposits keep coming out of the steam holes on the sole plate. We have tried de-scaling but it has had no effect. This iron has had very little use since we bought it about 18 months...
Try filling full-strength white vinegar instead of water. Then allow to steam out on scrap cloth. The white deposits are likely to be calcium. The brown gunge may be rust. When the deposits are minimized, use only distilled or bottled water from then on.
Mar 15, 2008 | Rowenta Perfect Iron
Rowenta DX6700 Iron Logo
23 people viewed this question
Top Rowenta Irons Experts
Henry  Thomas
Henry Thomas
Shehu Pro
Shehu Pro
Are you a Rowenta Iron Expert? Answer questions, earn points and help others
