Question about Garden
What kind of oil do I use in the lower unit or crank case for my 5 hp troy built rotortiller?
    Sergeant:
    Champion:
  • 202 Answers
30 weight. if its past break in I would use synthetic because it holds up better to heat etc. But conventional will do.
Posted on May 20, 2011
How do I drain the oil from my Troy bilt 2100 squall snow blower so I can change the oil?
You need to remove the lower panel to access the engine. In the engine blow-out, the oil drain plug is numbered 77 (bottom of the crank case).
25256884-5livr0uqynklw3svefpqfefw-2-0.png 25256884-5livr0uqynklw3svefpqfefw-2-2.png
Oct 26, 2014 | Troy-Bilt Squall 2100 208 cc 21-in...
Why is my 8.5 hp troy built snow blower leaking oil while under strain
Make sure the crank case is not over full when not running and make sure the crank case breather is clear.
Dec 15, 2013 | Troy Bilt 5.5hp Self Propelled Mower
Troy built squall 210. Starts and runs for a few seconds. Decided to check the oil and gas poured out of the crank case. Im not talking a little. Im talking atleast a pint or two. Can some body explain...
You have a Troy Bilt motorcycle?
Crank case filled with gasolene indicates a carb problem ... typically, the float has a hole in it causing it to sink ... when this happens, the bloat valve can not turn off the flow of fuel and it runs into the combustion chamber, own past the rings into the crank case.
Many original Troy Bilt machines came with tank shut off valves, it is a good practice to turn this valve off when the equipment is not in use.
Thanks for your interest in FixYa.com
Mar 03, 2013 | Motorcycles
Oil level
The lower plugs would be your drain plugs. You would fill the gear box with oil up to the highest hole.
Jan 11, 2013 | Troy-Bilt Garden
What type of oil do I add to the tb146 ec crank case, troy built cultivator, how do I know if there is enough?
oil is of a preference, I would use that same that you use in you car, fill it to the top of the bottom of the oil plug. Hope this helped Tim
May 22, 2011 | Garden
What kind of oil is used in crank case for a troy built 5 hp rotortiller?
If the engine is a Briggs and Stratton use SAE 30 only. If you run synthetic, (which I recommend) then you can use a multi-viscosity oil like 10W-30 or 10W-40, but only if using synthetic.
May 20, 2011 | Garden
What kind/type engine oil for the 17.5 H.P. Troy-Built Pony garden tractor?
sae 30 weight is used for most garden tractor engines. This is straight 30 weight oil not a multigrade. Most big box stores that carry this kind of gear have it.
Feb 16, 2011 | Briggs & Stratton Briggs Stratton Intek V...
Motor seems to be seized
ensure that the motor oil in it was not presivation oil. some machines have a thick oil put in it to stop the engine rusting if stored for a long time this needs to be replaced before starting the engine. if the engine oil is dark and very thick this may be the case and the engine will need to be stripped to dislodge the piston. but that usually happens in a longer time than 10 seconds.
if not then suspect the motor has had some major mechanical failure such as a crank shaft break. remove the injectors or plugs to see if the motor will crank round without compression.
Jan 01, 2010 | Troy Bilt Pony 6.5 Hp Rear Tine Tiller
Oil for a troy bilt 2550 psi pressure washer pump
What fluid and how much is required in the Troy-Bilt 2550 power washer pump?
May 17, 2009 | Briggs & Stratton Garden
After changing oil in troy built riding mower the oil light is still on and wont crank
That is a safety feature with a lot of engines, there is a reset somewhere, call your Troy built dealer and ask him, I'm sure he will help. I will be a simple fix.
May 16, 2009 | Troy Bilt 5.5hp Self Propelled Mower
Garden Logo
13 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
