I have a audiobox LCD TV Model # FPE3205 THE PROBLEM IS THE SCREEM IS SMALL BLINKING OR FLASHING AND SOME TIMES SHUTDOW WHAT CAN VE THE PROBLEM?
  • 2 more comments
  • Sorry about that.
    I have a audiobox LCD TV Model # FPE3205 THE PROBLEM IS THE SCREEM IS doing SMALL BLINKING OR FLASHING AND SOME TIMES SHUTDOW WHAT CAN BE THE PROBLEM?
  • YES THAT WHAT I MEAN WHAT DO YOU THINK IS THE PROBLEM
  • I have a audiobox LCD TV Model # FPE3205 THE PROBLEM IS:
    SMALL BLINKING OR FLASHING screen AND SOME TIMES the tv SHUTDOW.
  • Thank You!
  • 6,993 Answers
The issue you describe is consistent with a power supply board issue. This is the board where the AC goes to. This problem may have occurred as a result of irregular power supply, or excess power supply or power surge.
But more often bad capacitors causes problem on the power supply board. I do not think the power board needs replacement, rather those defective capacitors is causing this issue. Open unit up and take a look at the power supply board.You will probably see one or more electrolytic filter capacitors that are bulged up in the top-not perfectly flat like the others.
The value of these capacitors will be different, most likely they will be somewhere around-820 to 2200uF/25 V( or /10V sometimes)
You can replace them with same values but I would recommend the voltage rating to be higher(like 35V for an original 25V) for reliability purposes.
What happens is,these bulged top capacitors will cause a low and unfiltered DC voltage=main board will malfunction(the relay will keep clicking until the caps are holding enough charge to bring the voltage up over a threshold point).
You can buy these capacitors at any Fry's or Radioshack store or you can order them online at vendors like "mcmelectronics.com"(look for electrolytic capacitors). After replacing these capacitor(capacitors) most likely the normal operation will be restored. Or you can by a refurbished complete power board to save you some stress.
Note: There may be also some other causes for this symptom ,like a defective T con board ,or main board,but the bulged top capacitors are the most common cause for this issue.
If you don't know about TV repairers, take the TV to the nearest repairman to fix the fault for you. Also, note that TV stores a lot of current, so wait a while before opening the TV back cover.
I hope this helps.
Regards.
Posted on May 20, 2011
  • 4,889 Answers
What exactly do you mean by screen small? Image with huge black scope. Can you take a picture of the screen and upload it to imageshack.us and get me the link to to the image, so that I can have a look?
  • 1 more comment
  • eagle338
    eagle338 May 20, 2011
    I am not sure I got it this time either. By small blinking do you mean that the screen is flickering?
  • eagle338
    Ok got it. It looks like you have an issue with the backlight inverter or the power supply board. There is a 12V line that goes to the inverter circuit and we are to identify whether thats the source of the problem. DO you have a multimeter and know how to use it?
  • eagle338
    Whats the deal? No body can tell you what the problem is without some testing it. There is no instant solution and anyone who gives you one is taking a shot in the dark. Good luck is all I can say now!
Sony TV model KDL-46Z4100, standby light flashes 14 times, no picture, no sound
14 blinks to Sony Brand LCDs indicates a 'Backend error'. It means that, the main board to this TV should be checked for fault. In most cases the main board might need replacement, and a software update too. If you wish to know more details about this blinking code, check this link. It has details of blinking codes to several brands of TVs including Sony. Actually the work is a skilled one, need experience.
Jan 20, 2013 | Sony BRAVIA KDL-40S2010 40 in. LCD...
I have an Audiovox FPE3205 that the picture doesn't hold the clarity and gets blurry and grainy. Support said that it needed to be reset, but I've done that and still the same issue
I do not want to type the answer to this problem because I do not like to be the bearer of possible bad news. This television having been manufactured around 2006 may have reached the end of its life. As years go by, the picture quality on all LCD televisions diminishes.
Ok, ok, I got that out of the way first. Now forget that I just said all of that for a moment. This television will display a 720p resolution from its component input (green, blue, red, white, red). Make sure that whatever is connected to that input is only set to display images at a 1080i or 720p resolution. A wii or a regular dvd player not a bluray should look ok on the composite/RCA input. I'm not recommending the S-Video input for anything, and of course a computer can be connected to the VGA input still.
If the television looks bad even when displaying content on that 720p input then service can be considered and boards changed if you want to put money into this television rather than purchasing another one.
Oct 08, 2012 | Audiovox FPE3205 32 in. HD-Ready LCD...
Sony won't turn on
Please let me know the exact model no. of your TV to accurately diagnose where the fault came from. Also, please check what is the status of the LED at the front panel, does it has a steady, blinking light, if blinking, please count how many times it will flash. Some of the blinking LED denoting an error code.
Jdvillanueva
Dec 15, 2011 | Sharp LC-32SB21U 32 in. LCD TV
My kids went to change inputs and the screem went dark and the power light is flashing four times.
The first and easiest thing to check is your lamp. lamps on these TV's go bad and they are easy to replace.
Jun 13, 2011 | Hitachi 50V500 50 in. HD-Ready LCD...
I have a 42 inch t.v. that I mounted on the wall, after 6 months the picture started flashing/blinking. When I removed the t.v. from the wall it stop briefly. I have to turn the t.v. off and on numerous...
Tv is new only 6 months old?Yes take ur warranty repair service.The tv have 2 long LCD inverter boards problems,to causes the LCD screen panel to flashing/blinking or it is the causing by a bad power supply board,that the board where the a/c power cord plug into it.
Apr 21, 2011 | Digital Lifestyle FA1B32Z 32 in. LCD...
Hello,I have a AUDIOVOX-FPE3205. Red light on front panel flashing didn't count,sisling noise from back. can this be fixed?
It sounds like you may ahve bad power supply, that will be the first thing to look at.
If you are going to DIY and have proper tools, electronics knowledge, and know safety precaution then please read on:
Please see my basic troubleshooting guide here:
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
Failed TV and Monitors: http://s807.photobucket.com/home/budm/allalbums
http://en.wikipedia.org/wiki/Capacitor_plague
Parts: www.shopjimmy.com
Capacitors kit: http://lcdalternatives.auctivacommerce.com/Default.aspx he can make you a set of caps.
Sep 07, 2010 | Audiovox FPE3205 32 in. HD-Ready LCD...
How to mount samsung t26hd or remove the existing stand?
SAMSUNG T26HD by bsblevy - 10/10/11 11:02 AM HI I HAVE A LCD MODEL SAMSUNG T26HD HE DOESN'T TURN ON, I TRY TO TURN ON WITH THE CONTROL REMOTE ,THE LIGH LED FLASH 4 TIMES AND AFTER I LISTEN A BEEPPPP...BUT THE TV STILL OFF, BLACK SCREEM, IF YOU CAN HELP ME WITH YOUR ANSWER I WILL BE GRATEFULL, THANKS
Aug 28, 2010 | Samsung SyncMaster T240HD 24" TFT LCD...
TV Picture does not come on
Symptoms of a Defective or dying Power supplies on LCD TVs.
1. Light(s) on the front panel are behaving not normal example, blinking, amber color or
not steady, fainting, etc.
2. TV not turning ON properly.
3. TV turns OFF by itself.
4. Needs to be unplug to many times to make it work.
5. Humming or high pitch noise heard through speakers or at the back of the TV.
Dec 15, 2008 | Audiovox FPE3205 32 in. HD-Ready LCD...
Dell flat screen lcd
Sound like an electronics failure in the LCD monitor. Since that is a 5 year old 15" LCD it is cheaper to replace it than to repair it. You can take it to a TV repair shop for an estimate if ya want, they'll tell ya the same thing though.
Sep 06, 2008 | Dell Latitude D600 Notebook
Regarding problem in sony tv model no. kdf-e60a20
it works!! First i took off the front panel. Just check your manual for instructions, very easy to do. If you do not have a manual just down load one from google.. The instruction are easy to follow. The screw they have you loosen with a alan wrench is attached to the plastic, so you do not have to worry about dropping it inside the tv. Removing the lamp was simple. once out you will notice on either side are two small mesh screens. One of mine was 80% blocked with dust, the other side was only 30-40% covered. I used a vacuum to remove the blockage, i did not want the dust and dirt to go inside the bulb. i then cleaned all around the lamp. Reinstalled, and we are go to go. The kids are happy and i am happier since my wife not be buying a new TV.
total cost of repair $.00
time required to fix, less than 15 minutes.
Also when my TV was loosing sound and picture and then return. I did turn off my TV, then turned on. I nothiced a red blinking light. Mine flashed 5 times. After some reserch, 5 times is video related, bulb or video board. google red flashing light with the model you have and you will find what all the codes mean.
So if yours is flashing 5 times try the above, it might work for you and it is well worth the time before you call a tech and drops hundreds of dollars.
hope this helps.
Oct 06, 2007 | Sony KDF-E55A20 55 in. LCD Television
Televison & Video Logo
57 people viewed this question
Top Televison & Video Experts
