Question about Philips 51PP9303H Rear Projection Television
Colors are fade - Philips 51PP9303H Rear Projection Television
  • Philips Master
  • 3,459 Answers
Please do us a favor and rate this by cliking the thumps up icon located here >>>>>>
Projection TV sets have two very common problems. One is convergence ( 3D/Warped video) the other is CRT fluid ( Dull Video). Below are more details for both items. Also, complete repair kits with instructions and repair support are avail from site such as www.TvRepairKits.com
Common Problem #1) Convergence has gone out
Projection TV sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the video to look normal. When its out of alignment the video will look 3D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the TV menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired.
This is a very common failure on these projection sets and a fairly simple DIY fix. All projection sets including Samsung, RCA, Sony, Philip Magnavox, Panasonic, Pioneer, Akai, GE, JVC, Toshiba, and others at some point will have the same problem.
Common Symptoms include....
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
  • TV shuts off after powering on. Power light will blink. TV may also make a chirping noise.
Here are some pics of convergence problems.
69189a5.pngSOLUTION #1
For more more examples and find a fix using this link on Fixya http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Common Problem #2) CRT Fluid is Cloudy
Projection TV tubes have a liquid coolant that is used to keep them from overheating. After many years the coolant in the blue and green tubes will become cloudy and cause the screen to look dull, red/orange, etc. You may even see halos around images.
Picture of a set that needs the fluid changed.
TV set after fluid change
69189a5.pngSOLUTION
You can see some more examples and find a fix using this link on Fixya http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Please do us a favor and rate this solution after reading
Posted on May 22, 2011
Do area rugs fade?
There are lots of factors which are responsible of fading of your area rugs mostly rugs fade on the areas in which they are continuously in exposure to sunlight, good quality rugs do not fade under normal conditions the rug company also provides some years of guarantee on color of rugs.
Oct 17, 2014 | Concord Formal Leopard Area Rugs Formal...
Hls6767w color fade off in 20min then turn itself off
the color wheel is faulty needs replacement the intermittent colors na fading is caused by the speed being not in sync with the dmd due to wear these and the fans are the only moving parts
Oct 23, 2012 | Samsung HL-S6767W DLP TV
Does an old PHD cause faded colors?
the PHD transfers the image to the printed page and when it starts to go bad the images can become dull or faded and even blurry or totally missing. Id recommend the PHD be replaced and it should resolve your issues.
Feb 24, 2012 | Dell 2135cn All-In-One Laser Printer
Color is offset and blurred. There is no problem printing in black. Printing test page shows the same symptoms.
Hello
The color of HP LJ 2600n fades due to following reasons
1. the color cartridge near to empty 2. due to dust on reflection mirrors inside the printer
if the color cartridges are OK, then you need help of HP technician support, because cleaning of mirrors is very technical in nature for 2600n.
Dusty Environments can lead to Laser Scanner Contamination. The dust layer on the mirrors prevents proper transmission of the laser output in the imaging system leading to faded colors on the printed page. The initial stages of this failure typically occur in the magenta or yellow color planes as faded or light color. Often the left side is more faded than the middle.
You may need to contact the nearest Authorized Service Tech and get teh Laser Scanner replaced with the new released service part that has a mirror in a location where the dust ideally cannot reach easily.
Also, please ensure that the printer is relocated from the current location to a more dust free zone.
Hope this helps, if so do rate the solution
Jan 08, 2011 | HP Color LaserJet 2600n Printer
Colors fading away. Replaced cartridges.
I contacted Konica M again. We ran some printing tests. It seems to be bad ink cartridges, in particular the Cyan.
Dec 21, 2009 | Konica Minolta magicolor 2480 MF...
The color has faded . I replaced the bulb the problem persists!
Light Engine is Bad, If you had said TV was making loud whistling sound then it would be Bad color Wheel
Sep 27, 2009 | Samsung HL-P5063W 50" Rear Projection HDTV
Color is faded on one side when scanned
Apparently you might need to because scanners are most times not reserviceablw when problems of faded output and discolouration is evident.
Properly clean the surface of the scanner and leave your scanning image application to default settings
May 28, 2009 | Office Equipment & Supplies
Windows Looks Faded
normally, this indicates that the color settings in Display properties are set to a lower than normal setting
It should be 32 bit true color
Jul 27, 2008 | Microsoft Computers & Internet
Color fading
Hi , the printer are dried up need head cleaning twice then test print , if color of test print are complete color no spaces ,it means head are clean .
Jan 18, 2008 | Canon PIXMA iP1500 InkJet Photo Printer
Televison & Video Logo
24 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
