Question about Car Audio & Video
Learjet stereo model# 6863 car audio graphic equalizer amplifier need wire diagram and fure amp size. Wires are as follows 2 black, 2 red, 2 orangr 1 is dark orange, 2 yallow 1 is dark yellow, 1 blue, 1 green next set of wires are as follows 1 green, 1 gray, 1 white, 1 blue, 2 RCA L low in and R low in. please help I have been trying to get wire diagram for about 5 years now and can`t find any thing. They allways give me wire diagram for a lear jet ( JET ) plain.
  • 3,740 Answers
Email these folks and see if they can not help you. Mind you I am sure that they will want a fee for the diagram.
bcelectron@aol.com
I checked Sams Photofact and they have nothing for any Learjet models. You might want to contact Sams also:
https://www.samswebsite.com/en/aboutus/contactus
No worries if you seek other advice.
Kelly
Posted on May 20, 2011
Radio wiring hook up
1996 Dodge Avenger Car Radio Stereo Audio Wiring Diagram
Car Radio Battery Constant 12v+ Wire: Pink/White
Car Radio Accessory Switched 12v+ Wire: Red/White
Car Radio Ground Wire: Black
Car Radio Illumination Wire: Orange/Brown
Car Stereo Dimmer Wire: Black/Green
Car Stereo Antenna Trigger: N/A
Car Stereo Amp Trigger Wire: N/A
Car Stereo Amplifier Location: N/A
Car Audio Front Speakers Size: N/A
Car Audio Front Speakers Location: N/A
Left Front Speaker Positive Wire (+): Green
Left Front Speaker Negative Wire (-): Brown/Red
Right Front Speaker Positive Wire (+): Violet
Right Front Speaker Negative Wire (-): Blue/Red
Car Audio Rear Speakers Size: N/A
Car Audio Rear Speakers Location: N/A
Left Rear Speaker Positive Wire (+): Brown/Yellow
Left Rear Speaker Negative Wire (-): Brown/Blue
Right Rear Speaker Positive Wire (+): Blue/White
Right Rear Speaker Negative Wire (-): Blue/Orange
1996 Dodge Avenger with Infinity Audio Car Radio Stereo Wiring Diagram
Car Radio Battery Constant 12v+ Wire: Red
Car Radio Accessory Switched 12v+ Wire: Blue
Car Radio Ground Wire: Chassis
Car Radio Illumination Wire: Green/Orange
Car Stereo Dimmer Wire: Green/Yellow
Car Stereo Amp Trigger Wire: White/Black
Car Stereo Amplifier Location: Mounted under the rear deck. Some models have a black plastic trim covering the factory amplifier.
Left Front Speaker Positive Wire (+): White/Blue
Left Front Speaker Negative Wire (-): Black/Blue
Right Front Speaker Positive Wire (+): White/Red
Right Front Speaker Negative Wire (-): Black/Red
Left Rear Speaker Positive Wire (+): Yellow/Blue
Left Rear Speaker Negative Wire (-): Gray/Blue
Right Rear Speaker Positive Wire (+): Yellow/Red
Right Rear Speaker Negative Wire (-): Gray/Red
pls rate
google_protectAndRun("ads_core.google_render_ad", google_handleError, google_render_ad);
Aug 15, 2010 | 1996 Dodge Avenger
I need diagram of the stereo wires to put in an aftermarket stereo
1996 Honda Accord Car Stereo Wiring Diagram
Car Radio Battery Constant 12v+ Wire: Yellow/White
Car Radio Accessory Switched 12v+ Wire: White/Red
Car Radio Illumination Wire: Red/Black
Car Stereo Dimmer Wire: N/A
Car Stereo Antenna Trigger Wire: Yellow/White
Car Audio Front Speakers Size: 5 1/4′
Car Audio Front Speakers Location: Doors
Left Front Speaker Positive Wire (+): Blue/Green
Left Front Speaker Negative Wire (-): Gray/Black
Right Front Speaker Positive Wire (+): Red/Green
Right Front Speaker Negative Wire (-): Brown/Black
Car Audio Rear Speakers Size: 6 1/2′
Car Audio Rear Speakers Location: Rear Deck
Left Rear Speaker Positive Wire (+): Blue/Yellow
Left Rear Speaker Negative Wire (-): Gray/White
Right Rear Speaker Positive Wire (+): Red/Yellow
Right Rear Speaker Negative Wire (-): Brown/White
Nov 24, 2009 | 1996 Honda Accord
I need the wiring diagram for a 96 Geo Tracker
1996 Geo Tracker Car Radio Wiring Diagram
Car Radio Battery Constant 12v+ Wire: White
Car Radio Accessory Switched 12v+ Wire: White/Black
Car Radio Illumination Wire: Red/Yellow
Car Stereo Dimmer Wire: Red/Green
Car Stereo Antenna Trigger Wire: N/A
Right Front Speaker Positive Wire (+): Blue
Right Front Speaker Negative Wire (-): White/Red
Left Rear Speaker Positive Wire (+): Light Green
Left Rear Speaker Negative Wire (-): Light Green/Black
Right Rear Speaker Positive Wire (+): Gray
Right Rear Speaker Negative Wire (-): Gray/Black
Nov 22, 2009 | 1996 Geo Tracker 2 Door
Need to know the wires to install a deck for 97
Red is power to from ignition to cd deck
Yellow is direct power from battery to cd deck to hold the memory.
Black is ground
Blue is only needed if you are hooking up an amplifier.
I always suggest buying a wire harness quick connect system for $5, then you won't have to cut origional car wiring. If by chance you are taking the original wire route, then go to installer.com to find which wires on the car are for what.
Sep 02, 2009 | 1995 Toyota Celica
Need wiring diagram for Sony XM-E70 Equalizer/Amp
You need 1 thick ground cable ( usually brown)
you need 1 thick power cable ( same thickness and wire as ground usually red )
you should have 1 rem wire ( thin blue )
RCAs, 2 for sub, extra 2 for 2 speakers.
The rest I have no idea what they are.
You need speaker cables to sub or amp.
Some products use different colouring. Maybe the 9 pin connector is for head deck to speakers.
Jun 30, 2009 | Sony XM-SD61X Car Audio Amplifier
Can,t figure out how to wire it up to my 1995 jeep and would like to find out how to wire it up?
Dont know what model you have so here u go!
1995 Jeep Wrangler Car Stereo Radio Wiring Diagram.
Car Radio Constant 12V+ Wire: Red/White
Car Radio Switched 12V+ Wire: Purple/White
Car Radio Illumination Wire: Blue/Red
Car Radio Dimmer Wire: Red/Black
Car Radio Antenna Trigger Wire: N/A
Car Radio Amp Trigger Wire: N/A
Front Speakers Size: 4′ x 6′
Front Speakers Location: Dash
Left Front Speaker Wire (+): Gray
Left Front Speaker Wire (-): Yellow
Right Front Speaker Wire (+): White/Red
Right Front Speaker Wire (-): Brown/Red
Rear Speakers Size: 4′
Rear Speakers Location: Rear Roof
Left Rear Speaker Wire (+): Gray/White
Left Rear Speaker Wire (-): Brown/White
Right Rear Speaker Wire (+): White/Black
Right Rear Speaker Wire (-): Brown
1995 Jeep Cherokee Car Radio Stereo Audio Wiring Diagram
Car Radio Constant 12v+ Wire: Pink
Car Radio Switched 12v+ Wire: Violet/White
Car Radio Illumination Wire: Light Blue/Red
Car Stereo Dimmer Wire: Orange
Left Front Speaker Positive Wire (+): Dark Green
Right Front Speaker Negative Wire (-): Dark Blue/Red
Left Rear Speaker Negative Wire (-): Brown/Light Blue
Right Rear Speaker Positive Wire (+): Dark Blue/White
Right Rear Speaker Negative Wire (-): Dark Blue/Orange
1995 Jeep Grand Cherokee Car Stereo Radio Wiring Diagram
Radio Switched 12V+ Wire: Red/Gray
Radio Dimmer Wire: Orange
Radio Power Antenna Trigger Wire: Green/Red
Radio Amplifier Turn On Trigger Wire: N/A
Front Speakers Size: 6 1/2′
Left Front Speaker Wire (+): Green
Left Front Speaker Wire (-): Brown/Red
Right Front Speaker Wire (+): Purple/Yellow
Right Front Speaker Wire (-): Blue
Rear Speakers Location: Rear Doors
Left Rear Speaker Wire (+): Brown/Yellow
Left Rear Speaker Wire (-): Brown/Light Blue
Right Rear Speaker Wire (+): Blue/White
Right Rear Speaker Wire (-): Blue/Pink
window.google_render_ad();
Jun 03, 2009 | Pioneer DEH-P2000 CD Player
BUTCHERED WIRING.
Dont know what year you have but one of these will work. Ground is usually separate in Dodges:
1990 Dodge Caravan Car Stereo Wiring Diagram
Car Radio Illumination Wire: N/A
Car Stereo Dimmer Wire: Orange/White
Car Audio Front Speakers Location: Dash
Left Front Speaker Negative Wire (-): Green/Yellow
Right Front Speaker Positive Wire (+): Purple
Right Front Speaker Negative Wire (-): Purple/Yellow
Car Audio Rear Speakers Size: 6′ x 9′
Car Audio Rear Speakers Location: Tail Gate
Left Rear Speaker Negative Wire (-): Brown/Yellow
Right Rear Speaker Positive Wire (+): Blue/Red
Right Rear Speaker Negative Wire (-): Blue/White
1997 Dodge Caravan Car Radio Stereo Audio Wiring Diagram
Car Radio Switched 12v+ Wire: Red/White
Car Radio Illumination Wire: Black/Yellow
Right Rear Speaker Positive Wire (+): Blue/Orange
2003 Dodge Caravan Car Radio Stereo Audio Wiring Diagram
Car Radio Constant 12v+ Wire: Gray/Red
Car Radio Switched 12v+ Wire: Black/Pink
Car Radio Ground Wire: Chassis Or Metal Strap
Car Radio Illumination Wire: Orange/Tan
Car Stereo Amp Trigger Wire: Gray/Green
Left Front Speaker Negative Wire (-): Green/Black
Right Front Speaker Positive Wire (+): Gray
Right Front Speaker Negative Wire (-): Gray/Black
Left Rear Speaker Positive Wire (+): Green/Black
Left Rear Speaker Negative Wire (-): Green/Orange
Right Rear Speaker Positive Wire (+): Gray/Black
Right Rear Speaker Negative Wire (-): Gray/Pink
Jun 02, 2009 | Car Audio & Video
What is the radio wiring diagram for 1992 eagle talon
1992 Eagle Talon Car Audio Wiring Diagram
Car Radio Battery Constant 12v+ Wire: Red/Black
Car Radio Illumination Wire: Green/White
Car Stereo Dimmer Wire: Black/Yellow
Car Stereo Antenna Trigger Wire: White/Black
Car Audio Front Speakers Size: 4′
Car Audio Rear Speakers Location: Side Panels
Mar 29, 2009 | 1992 Eagle Talon
Radio wiring
1996 Mitsubishi Montero Car Audio Wiring Diagram
Aug 29, 2008 | 1996 Mitsubishi Montero
Car Audio & Video Logo
118 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
