I have a horizontal white line has been appearing recently on the bottom of my lap top's screen, i have not installed any new software and it hasn't fell down like ever ... what's the solution ??
    Sergeant:
  • 228 Answers
Just boot to BIOS (either by pressing Del, F2, F10 (depends on the laptop brand).. upon turning on the unit). If the white lines appear, your problem is with the LCD screen.
If no white line in BIOS, install an updated driver of your video card. However, if installing the driver doesn't help, your video card is faulty.
Hope this helps,
Posted on May 20, 2011
Faulty screen, horizontal lines
Battery is stuffed, replace it. White lines is the early signs or the LCD is damaged and needs to be replaced.
Jan 15, 2013 | Tomtom ONE 3rd Edition GPS
Wavy horizontal lines across the screen
It sounds that the main power supply section to your TV has the fault. The horizontal thik lines that appears crawling down across the screen should be of video 'HUM'. Have you replaced the main filter capacitor at the power supply section? If not, replace it along with the main rectifier. The AC power is rectifed by a bridge and applied ot this main filter capcitor. It will have a capacitance value between 120 to 350MFD 450VDC. Check this section. Measure the rectifed DC voltage acorss this main filter capacitor. It should be around 350VDC, if your home power supply line is 220VAC. If it is 110AC, this DC voltage will be around 165VDC; and it should be. If rectified DC voltage found lower than the input AC voltage, replace the rectifier bridge. In some sets, this bridge section have four diodes. Some other circuits, a bridge rectifier stalk may be used.
May 20, 2012 | JVC AV-27050 TV
White-line on my lap's lcd
It does sound like a problem with your screen. If you want to get it fixed, a good company called revivemylaptop have an offer on at the moment. (www.revivemylaptop.com)
Jun 08, 2010 | Acer Aspire 4720 Notebook
Laptop Screen White horizontal lines
Try reseating the LCD cable to the video card. If no change, then you will most likely need a replacement LCD (Roughly $150 on EBay)
Oct 01, 2009 | Dell Inspiron 9100 Notebook
I have a TOSHIBA lap top, recently there are
Does the laptop have integrated or dedicated graphics?
This could be a problem with the graphics drivers. Go to the Toshiba website, and get the latest drivers for you PC, this should solve the problem. If this doesn't solve it, than it looks like the screen / graphics controller / GPU is failing.
Jun 23, 2009 | Compaq Presario M2000 Notebook
Horizontal lines across the top 3 inches of picture
Hi
what line started? from Left to right? or from top to bottom?
Thanks!
Nov 28, 2008 | Philips 32PT6441/37 32" TV
Horizontal ines---original post got wiped. Sorry.
leaky cap(s) in vertical circuit. shouldn't be more than $125 (plus taxes) parts and labour
May 14, 2008 | JVC AV-27230 27" TV
HP L1706 monitor with thin white/blue horizontral line
It is the problem of monitor pcb in vertical section.check vertical ic for dry soldring. Resolder the ic if problem still on then change ic or check components related ith it. check continuity of vertical deflection coil.
Hope this be of initial help/idea. Pls post back as requested, how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FIXYA.
Mar 13, 2008 | HP L1706 17" LCD Monitor
White horizontal, zig-zagging lines
Sounds like the flyback transformer is bad. couple of 100 dollars if it is that
Dec 03, 2007 | Televison & Video
Computers & Internet Logo
199 people viewed this question
David Payne
David Payne
