Question about Dell E152FPc 15" TFT LCD Flat Panel Monitor
Does not power on. Is there an internal fuse?
  • 11,361 Answers
Yes, there is a main AC in the bottom center of the board as shwon here:
http://s807.photobucket.com/albums/yy352/budm/DELL/Dell%20E152FPC/?action=view&current=e152fpc.jpg
Look for bad caps with domed tops as shown also.
If you are going to DIY and already try the monitor with another PC, and have proper tools and know safety precaution then please read on:
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply (they should be replaced in a set), blown fuses; poor solder joints, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed DELL monitors to get some ideas what to look for: http://s807.photobucket.com/albums/yy352/budm/
Post back what you see inside so we can guide you further and it will help out other people in the future also.
Basic LCD monitor and TV troubleshooting guide:
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://www.fixya.com/support/r7406380-tv_training_manuals
Failed TV and Monitors pictures: http://s807.photobucket.com/albums/yy352/budm/
Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague
Capacitors kit: http://lcdalternatives.auctivacommerce.com/ he can make you a set of caps for you.
Or www.digikey.com just make sure to use caps with low ESR, 105c, high ripple current, long life rating such as PANASONIC FM or FC series.
Replacement board: http://www.lcdrepair.us
Posted on May 21, 2011
Cannon ip4200 no power nothing is there fuse internally ?
there should be a fuse in the power board . but with another shape. maybe is a small black cilynder.
Apr 19, 2016 | Cannon Office Equipment & Supplies
Panasonic Microwave NN-CT552W has no power - plug fuse ok - Has it got a thermal cut out or internal fuse? - Unit was ok after cooking some jacket potatoes
All microwaves has both internal thermal cut out and internal fuse, Yours problem sounds like an open 9 volts transformer that power up the front panel
Nov 07, 2014 | Microwave Ovens
Model Yamaha ME-50 no power
John
With AC power off.
Use a meter (on Ohms scale) to check internal fuse for blown (open) fuse.
If you feel qualified & safe with AC Power On.
Check input to internal power supply on AC Scale (Caution when AC is on) for volts in.
Use meter on internal Power Supply for "probably" DC volts leaving internal Power Supply electronics to power the rest of the electronic circuits.
Switch mode power supplies can break down. They stop doing their high frequency switching so they don't convert AC to DC.
If this P/Sup is a separate box or circuit board, inside the unit, then it can have a part number & be replaced.
Good Luck
Jul 14, 2014 | Yamaha Music
Where are internal fuses as have no power when plugged in?
There are several types of internal fuses. sounds like the ones you are looking for are related to providing power to your unit. IF you open up the chassis and follow where the power cord attaches - it will lead you to the power supply board where there are often removable fuses that protect the internals for power surges. Some components actually have these fuses accessible from the outside either integral to where the removable chassis power cord connects or in a fuse holder that unscrews.
Make sure you replace with the same type of fuse!
May 11, 2014 | Yamaha RX-V430 Receiver
DEAD, NO TURN ON, CHECKED INTERNAL FUSE OK
If the internal fuse is okay, then what you got here is a bad power supply. Many power supply's do die with the internal fuse intact what happends is the High voltage tranformer or relay goes out on you causing this to happed, Best thing to do is replace the unit becuase a new power supply would cost you more then the unit new. Let me know if you have any question.
please do not forget to rate.
Aug 10, 2010 | Toshiba RD-XS32 DVD Recorder
Epson dx6000 no power is there an internal fuse?
epson dx 6000, lost power checked mains fuse ok, is there an internal fuse?
Sep 22, 2009 | Office Equipment & Supplies
What is the power rating of the internal fuse of Philips 28PW9527
it is marked on the fuse---amps and voltage--some of the fuses these sets use are special---don't buy it at radio shack---also the values for the fuse are usually printed on the circuit board under it.
Aug 06, 2009 | Televison & Video
Technika LCD19id - No power to internal fuseMy LCD 19id-107 tv turned itself off and will not come back on. I have power to the 3 pin power connector at the rear of the tv. However i have no power to the...
I have a Technika 22 inc hd flatscreen that will not power up. you can here the dvd running if you load a dvd but the television side wont power up.I have tried to find the internal fuse but have had no luck.Anyone help?
Nov 15, 2008 | Televison & Video
Power
Check the internal fuse.
Oct 21, 2007 | Aiwa XC-RW700 2-Disc CD Recorder
Dell E152FPc 15" TFT LCD Flat Panel Monitor Logo
65 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
