Question about Mantis 2-Cycle Tiller
Will not run continuous at full power. cuts off after several minutes. Starts fine.
    Problem Solver:
  • 17 Answers
If you have not already performed routine maintenance this year replace the spark plug, fuel and air filter. Make sure you are using a fresh and proper fuel/oil mix. Check that there are no leaks from the primer bulb or fuel lines and that the carb is not loose (allowing it to pull in to much air). Failing that start it and let it warm up a minute or so. Then use something to support the tines off the ground and hold the throttle wide open (protect yourself and others from the rotating tines). Adjust the fuel mixture screws on the carb as per your owner's manual or until you find the 'sweet spot' and know the engine is running at full rpm (you will be able to tell by the sound). If these steps do not solve your problem then a carb repair kit would be the next step. Good luck.
Posted on May 25, 2011
02 suburbsn wont crank, full battery power
I had a similar problem with a 1999 Chevy Astro. All fuses checked out good. Several posts advised cleaning the battery terminals, checking out the ECU to cutting the yellow wire from the ignition switch, check to see if it'll crank on Neutral, and also checking/replacing the brake switch. I simply removed several keys from the key ring, then shot several bursts of air from an air can (some keys are keyed to the ECU to turn off the Security System when attempting to start the engine), then waited several minutes for any condensation to dissipate, then was able to crank the engine to life.
Nov 18, 2013 | 2002 Chevrolet Suburban
Partial loss of power
It could be a short in the magnito a dirty carb prob. Or foul plug also use fresh gas to narrow the broblem. I almost forgot check the compression.
Jun 21, 2013 | Craftsman Kohler Courage 26 hp 54" Garden...
Volvo 850 intermittant starting after sitting several days
The power stage module,can do this on you vehicle after a hot restart
Mar 06, 2012 | Cars & Trucks
RE McCulloch (gas 2 cycle) chain saw. No prior problems. Despite model year, I have not used it all that much, but over past 3 days, was running fine, but then started to run oddly: When running for a few...
It could be a few things, initially it sounds like simple fuel starvation, remove the fuel filter in the tank and replace, check the fuel hoses, and the primer hoses if fitted for cracks or leakage.
May 12, 2011 | Garden
Kohler small engine problem
1989 Kohler 20 backfires through the exhaust. What are the possible causes?
Jun 02, 2009 | Kohler CH25 PA-CH730-0040 Command Gasoline...
Mantis 2-Cycle Tiller Logo
181 people viewed this question
Top Mantis Garden Experts
Mike Squire
Matt Olenzek
Matt Olenzek
ray gallant
Are you a Mantis Garden Expert? Answer questions, earn points and help others
