Question about Dishwashers
Dishlex 500E dishwasher won't drain. keeps washing. New motor and membrane.
  • ryanterry Aug 15, 2008
    If left overnight, will drain when next turned on, so is capable of draining. Just that when washing, it will not go to next part of cycle, that is "draining", and water keeps sloshing around the machine for ages. Thanks for any help.
  • ryanterry Sep 12, 2008
    Problem solved! Dishwasher was actually stuck on drain cycle and was just sloshing water around the machine. I was able to get it to drain by lowering water level by emptying most of water with a cup. I then disconnected drain hose under sink and blew through it - much gurgling etc of water in dishwasher, but after reconnecting the hose I pushed start button and machine drained straight away. Then called serviceman from phone book and he disconnected drain hose, made sure it wasn't blocked then reinstalled it WITHOUT the loop in the hose that was up and down the side of the machine. in other words the drain hose now goes straight out the back of the machine from the pump, direct to the kitchen sink drain. Guess what, it now works. Apparently the new pump didn't like the routing of the old hose. i also installed new pressure switch and had circuit board reconditioned, so everything is working well.
    Problem Solver:
  • 6 Answers
Keeps washing ????? is it stuck on the wash cycle? is this what you meant?? any way simple things first. suction blocked....Discharge blocked? sometimes hoses keep junk in them that blocks the goesinta and the goesouta.
if stuck in the wash mode unplug the thing for 3 minutes or more to reset...try again.... reset again....
bad new parts----- that always sucks!!!!!
Posted on Aug 15, 2008
Motor keeps running. Water heats fine. Help
One of the reasons for motor not draining during normal cycle is the check valve is stuck. It is meant to return to normal during drain cycle but close during wash. I think the cancel is resetting it and letting water out.
See this discussion.
http://www.repairclinic.com/RepairHelp/How-To-Fix-A-Dishwasher/26-129-977852-/Bosch-Dishwasher-won-t-drain-SHE43RF2UC64
Apr 02, 2014 | Bosch 24-in Built-In Dishwasher Color:...
Dishlex dishwasher won't complete a cycle. Number 60 shows up and a small flashing line. ??????
Drain pump is blocked. .If you are good with tools you can clean it yourself. Let me know
Mar 28, 2013 | Dishwashers
My dishlex global300 seems to fill and drain but dosnt pray to wash the dishes.... help, what can i do?
Does it leave water in the bottom after going through the wash cycle?
Jan 28, 2013 | Dishwashers
The control panel has a large crack on it & needs to be replaced. Does the replacement part come with all the electrics & connections, please? Item description: Vulcan Dishlex 500E Electronic...
Hi just read your posting,I know these machines well.When you purchase the new panel you get the membrane or touch buttons and the rest of the components eg---control board,door handle--etc--- you must take off your old panel and refit them to the new panel.Before you attempt this job unplug the power point first.If you require additional help please reply and I can guide you throe the refitting of the panel.Looking forward to your reply.
Aug 29, 2010 | Dishwashers
Replace Control panel cover on dishlex dishwasher 500E
If your 500E is the same as my 500E then the controls are electronic touch buttons. The are part of a self adhesive strip and stuck to the front of the door. No screws involved. Only the LED lights are mounted on a circuit board with screws on the back of the plastic front panel. ?????
May 09, 2009 | Dishwashers
Looking for manual for Vulcan Dishlex 500e dishwasher
Probably fatigued wiring from the chassis to the door where it bends every time you open and close the door. On my 500E, I took the sheet metal door skin off and found a couple of burned spots on the wires inside a clear plastic strain relief.
Apr 11, 2009 | Dishwashers
Dishlex global 500 rinse and wash problem
This was due to a faulty pump motor which I have now replaced.
Jan 10, 2009 | Dishwashers
Dishwashers Logo
448 people viewed this question
Top Dishwashers Experts
