Question about Haier HTE21WAAWW Top Freezer Refrigerator
Cold Freezer Hot refrigerator
I've had to defrost my refigerator twice because the ice builds up which prevents my refrigerator from being cold. The first time I defrosted it everything worked just fine but the second time it no longer showed any result. I don't want to get a new refrigerator if I can afford to fix it. How do I know if its the nipple, the fan or what!? PLEASE Help me fix it
  • 1 more comment
  • Anonymous Oct 31, 2008
    I have the same problem! Clearly this issue is with all of these units and should be recalled. I defrosted the freezer and started over and had a cold frig for a day or two, but now it's back to warm frig, super cold freezer!
    I have the same problem! This unit should be recalled!
  • orion-2222 May 11, 2010
    Having an identical problem and tried all the same stuff you tried, so far to no avail.  Tried compressed air (in a can) from the top down, no water came out the bottom, also tried a long straw -- nothing.  Also tried blowing up from the bottom with some tubing taped to the tube.  Water gurgled in the freezer but still did not drain.  Hate to plug it all back in and refreeze everything to try it again; lose a day each time I try this and fail..... did you find any other solutions on how to unclog the drain tubing??
I'm having the same problem with a Haier Model HTE18WAAWW.
Water is dripping into refrigerator section from the freezer section. Eventually, refrigerator section was not cooling adequately. Freezer was freezing, but there was eventually ice crystals inside similar to hoarfrost. (See Google images for hoarfrost if you're not sure what hoarfrost is.)
I turned off and unplugged unit for several hours while I removed the floor pan and internal back panel in the freezer. There was ice built up in the evaporator drain pan that was blocking the air flow of cold air from the evaporator into the refrigerator. I melted the ice with a hair drier plugged into a GFI outlet for safety.
I dried everything off. I could not find evidence of water going down the condensate drain tube below the evaporator to the condensate drain sitting on top of the compressor. I tried running a coat hanger down the drain line to no avail. I poured hot water down the condensate drain line to no avail. I put everything back together. Works fine as far as cooling and freezing, but water is still dripping into the refrigerator.
I think the defrosters are okay unless the heater strip below the evaporator is burned out. I base this on the fact that there is no condensate around the door gaskets even though the temperature in the house is hot and humid. I may have to Ohm that heater out. I'm thinking the drain line is clogged for the condensate drain. It may need longer defrosting.
If longer defrosting don't work, I'm thinking I need to rethink how to clean out the condensate drain line. Maybe low pressure compressed air???
Posted on Aug 16, 2008
I just spent three hours on the same model refrigerator trying to fix, symptom for symptom, the exact problem mentioned here, including frost in the vents to the refrigerator, water dripping into the refrigerator from the freezer, and plugged condensate tube, etc.
I took a hair dryer to melt most of the ice, after removing the back panel in the freezer to get at the fan, and the coil. I noticed that the condensate drain was clogged, so what I did was to take a ziploc bag, and cut one of the bottom corners off to make a hole just large enough so that a straw will fit through tighly. I cut it slightly smaller than the straw and pushed it through, so that the plastic was pulled tight around the straw to form a seal. Essentially, you are moving the hole in the bag with the straw. Think as if you were putting one of those little red plastic extenders on a can of WD40 to be able to aim the spray better, it's the same concept. Then, I filled the bag with hot water from the tap and sealed it, keeping the end of the straw inside the bag and the other plugged to try to keep it from leaking as much as possible (a little is expected). Then I put the straw down the drain tube and flooded it with the hot water. The straw aims it down the tube so that it melts the ice much faster that pouring water over the freezer, because the force of the water circulates the heat much better with a straw. Anyway, the ice melted and made a nice puddle on the kitchen floor, but hey, it's unclogged! I would suggest putting something under the other end of the drain tube first if you tried this.
Also, I raised the front of the fridge with the adjustable feet (by unscrewing the rubber thingies to extend them). This, I hope, will help the condensate drain to the back of the freezer and out the bottom. I don't know for sure if this thorough defrost fixed it, but I hope it did! I'll post again if I have any more info... Nice that this one model of fridge has so many problems, isn't it?
Posted on Aug 29, 2009
I have a Frigidaire Gallery refrigerator. The freezer is not cooling enough to keep frozen. It is blowing cold air and the refrigerator part seems to be working.
If your freezer is cold then you may have a defrost cycle issue. There are typically three components for the defrost cycle. Heater bar, thermostat and timer. If the defrost system fails ice starts to build up in the back of the freezer until it prevents cold air from getting into the fridge. When I took off the back panel inside my freezer it was a block of ice. You can melt the ice with a hair dryer and order new parts.
Mar 13, 2014 | Refrigerators
Freezer is freezing fridge is warmer than usual does the dial indicating coldness from 1 to 2 apply to the freezer, refrigerator or both? have cleaned condenser on back of refrigerator - it was not really...
Usually, the freezer knob just adjusts the airflow from the freezer to the freshfood section. The refigerator control turns the unit on and controls temperature. When unit is running, do you hear the fan running in the freezer? The fan forces air to the refigerator section. If not, probably bad fan motor. If it is, do you see frost build up on the back wall of freezer section? If so this would indicate a defrost problem, ice build up on evaperator blocking airflow to refrigerator section. You cleaned the condenser, Was the condenser fan running? Defrost causes. Defrost thermostat, heater,defrost timer. Good luck.
Mar 31, 2011 | Whirlpool Refrigerators
I have a fisher & paykel n325t fridge. can not get the correct temperature. not cold enough.what should te dial be set at?
if your refrigerator had 7 postions you would set it to 4 check this for me though remove the rear panel in your freezer and assure that you dont have a ice build up on the inside this happens when you start getting a defrost problem also assure when you remove that rear panel that the fan is working the fan blows the cold air into the refigerator side also if youor refrigerator had 4 postions you would set it on 2 send me your model number and check out to see if your starting to get a defrost problem and well go from there thanks again
Rick
if you have an ice build up use a hair dryer to melt the ice this is a temporary fix until we can solve if it does have have a defrost problem or not
Dec 15, 2010 | Refrigerators
Refrigerator not cold freezer working properly turned food section to max, cleaned coils
loook for ice build up in back of freezer . and if found you have a failed defrost system .. the coil is blocked with ice and this prevents the cold air form getting to the fresh food side . look at the heater in the back of freezer ... mm . if heater is ok then replace the adative defrost control . / a very common part failure .. mm
Sep 30, 2010 | Maytag 25.6 Cu. Ft. Side-by-Side...
Freezer is building up ice refigerator is not cold
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
Check out these tips...they can help you figure out whats going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
heatman101
Aug 31, 2010 | Frigidaire FRS26R4A Side by Side...
Not getting cold on both side refigerator .and the ice maker is not working.
Good day,
The ice maker locks out if the machine is not at normal temperature.
So the cooling system has to be repaired first.
Here is a list of items on a standard refrigerator that would prevent it from cooling.
1. Defective thermostat
2. Defective freezer fan motor
3. Defective defrost timer
4. Defective defrost thermostat
5. Defective defrost main heater.
6. Defective condenser fan motor
6. Defective compressor overload protector
7. Defective compressor start relay
8. Defective compressor start/run capacitor (some models only)
9. Defective compressor
10. Restriction in refrigeration sealed system
11. Loss of refrigerant (leak)
12. Excessively dirty condenser
13. Broken wires, bad wire harness connectors, ect.
14. Defective fan motor switch (some models only)
So you need to give us some idea how it is acting.
Is it running ??
Are there any unusual noises and coming from which part of the machine ??
Was the failure instant or over an extended period ??
Is there frost or ice building up in the freezer compartment ??
Please be detailed as possible.
The list above is what a trained service tech would use if he made a service call to the house.
A refrigerator is not a simple device.
Mar 25, 2010 | KitchenAid Architect ® Series II KSRX25FT
The refigerator does not get cold. Long term ice forms in Freezer blocking through holes. When first pugged in seems to circulate air to refrigerator
The drain at the bottom of the freezer under the coils is clogged. Remove Icemaker if you have one, remove bottom floor of freezer, remove back panel of freezer. Use hairdryer to melt ice. ALL ICE MUST BE REMOVED. Use hot water and a turkey baster to get ice out of drain hole located about middle under coils. Be patient, do not chip ice with sharp tool. After ice is removed pour hot water down drain hole. Water must come out in drain pan under refrigerator(you may have to take front grille off to get to pan)
If Ice returns after a few weeks, you need to look at defrost thermostat which is usually clipped on cold coil at back of freezer. This part or the defrost timer could be defective.
Sep 14, 2009 | Refrigerators
Amana SCD25tw side by side. Ice cream very soft, freezer blows semi cold air NOT ice cold. refigerator side seemes ok. I checked coil and it is NOT icy.
If the coil is not iced up then it is not a defrost problem but rather if the coils are not completely cold all over then the compressor is failing or the refrigerant has leaked out.
Sep 05, 2009 | GE GTS22KBP Top Freezer Refrigerator
Refigerator will not saty cold but freezer works
if the compressor is running your ref. should be getting cold. Their is a defrost timer but when it is in defrost the compressor shuts off. I think you do have a leak.
thanks,
Jun 28, 2009 | Maytag 25.6 cu. ft. Wide-By-Side...
Solution for ''my side by side msd2556aew matag refigerator is not keeping the refrigerator cool It has ice build up by the fan in the freezer
your not going through defrost cycle. remove rear panel in freezer and defrost ice. need to verify defrost timer, defrost heater and defrost thermostat. these are the only parts that deal with defrost cycle.
Jun 22, 2009 | Refrigerators
Haier HTE21WAAWW Top Freezer Refrigerator Logo
872 people viewed this question
Top Haier Refrigerators Experts
John Tripp
John Tripp
doggzzz
Level 1 Expert
Vernon Taylor
Are you a Haier Refrigerator Expert? Answer questions, earn points and help others
