Question about EuroCave Comfort 170 1-Temp - Black Solid Door
I just bought a used EuroCave from the country club I work for. It has a solid black front door. I am looking to buy a replacement glass door for it. Do you know where I can buy one?
2 Suggested Answers
joboo1
  • 257 Answers
SOURCE: Door warped.......
Hi, These cabinets have 2 sheets of tempered glass with an airspace between and are fully reversible I would doubt they are warped. My best guess is that the cabinet is not square. If you have a level, check it across the top of the cabinet not the door. Also check it diagonally both directions. The cabinet has feet which are adjustable unless you have a low spot on the floor for which you may have to use a shim. Remember that it needs to lean slightly to the rear for the door to close on its own if partially open. Good Luck to you! Let me know how this works for you.
Posted on Feb 08, 2009
Why keyless entry system does not work?
Take it back to the garage where bought for them to fix!
Oct 08, 2015 | 2005 Dodge Dakota Club
How do you remove and replace Eurocave performance control board Eurocave 283
The control panel is held up by two hidden screws (that are not removed) that slide into slots of the top front of the panel and 2 removable Philips screws at the back of the control panel which hold up both the controls and circulation fan.
Unplug the unit. Open the door, remove both chrome screws in the ceiling behind the control panel and put them where you can reach them.
While holding up the fan assembly, slide the control panel forward. It may bind a bit so work it forward carefully to prevent scratching the black finish.
As you pull it forward the fan will want to drop down, so once the control panel has moved forward enough to clear the fan panel (about 1/2") you can insert the screws and finger tighten them to hold up the fan as you remove the panel.
Label the wires before unplugging as they are not all individually keyed and look very similar. Note any unused connectors. You need to unplug the large black power connector, black wire for fan connector, and a white temperature sensor wire(s) before removing the panel. You can leave connected the white wires for lights, display and local humidistat that are part of the panel until the panel is removed.
The power supply board and display board are mounted to the control panel assembly with screws and connected by a ribbon cable and wires. Label any remaining connectors and wires before removing the circuit cards. I think the ribbon cable is only removable on the display board and permanently attached to the power supply board. There are replacement parts available from WineEnthusiast.com as well as 3rd party Eurocave circuit card repair services you can find on the internet.
When reassembling follow the opposite order and note the fan panel mounts ABOVE the control panel on the ceiling of the unit. Gently slide the control panel into backwards into place lining up the slots onto the fixed 2 screws while holding up the fan panel and then install the 2 screws behind it to hold both in place.
Jul 05, 2014 | EuroCave Performance 283 Wine Cellar
1997 mercury grand Marquis driverside rear window motor works but window won't go up. Inner door panel off. Metal cable with a black foam cover and pink plastic clip off. Can't figure what it fits to.
usually this means you need a new window regulator.
Section 01-11: Glass, Frames and Mechanisms 1997 Crown Victoria, Grand Marquis Workshop Manual
REMOVAL AND INSTALLATION Window Regulator, Power Front Door
Removal
  1. If front door window glass (21410) is in the down position and is inoperable, the following steps must be taken; if front door window glass is operational, go to Step 2.
    1. Remove front door trim panel (23942) and front door trim shield (237A04). Refer to Section 01-05 .
    2. Disconnect battery ground cable (14301). Refer to Section 14-01 .
    3. Disconnect window regulator electric drive harness connector.
    4. sva~us~en~file=ani_caut.gif~gen~ref.gif CAUTION: Be careful not to strike or scratch front door window glass because it can break.
      Remove window regulator electric drive retaining screws through holes.
    5. Remove window regulator electric drive (23394) from front door power window regulator.
    6. Raise front door window glass to full up position by hand and secure with tape.
    7. Go to Step 5.
  2. Remove front door trim panel and front door trim shield. Refer to Section 01-05 .
  3. Remove front door window glass as described.
  4. Disconnect window regulator electric drive harness connector.
  5. NOTE: Use care not to enlarge sheet metal holes in the door inner panel.
    Remove two 1/4-inch rivets retaining lower bracket of front door power window regulator to inner panel. Use drift punch to knock out center pins for each rivet. Using a 1/4-inch diameter drill, drill out remainder of rivet.
  6. Remove three window regulator electric drive retaining screws from inside door to remove window regulator electric drive from front door power window regulator.
  7. Remove two window regulator retaining nuts.
  8. Remove front door power window regulator from front door (20124).
Installation
  1. Lubricate regulator mechanism with Teflon® Lubricant E7FZ-19590-A or equivalent meeting Ford specification ESB-M1C111-A.
  1. Install front door power window regulator minus motor (23208) into access hole in inner panel.
  1. Position front door power window regulator using upper studs and tabs on window regulator electric drive mounting bracket.
  1. Install rivets retaining front door power window regulator to door inner panel (1/4-20 x 1/2 inch screw and 1/4-20 nut and washer assemblies or equivalent metric fasteners may be used).
  1. Install two upper front door power window regulator retaining nuts.
  1. Install window regulator electric drive with three screws. Do not overtighten screws.
  1. Connect the window regulator electric drive harness connector.
  1. Install front door window glass.
  1. Adjust front door window glass as described.
  1. Install front door trim shield and front door trim panel. Refer to Section 01-05 snorkelbobby_38.gif
Feb 14, 2011 | 1997 Mercury Grand Marquis
Eurocave comfort 264: Problem, ice formation inside the unite , half the way the middle section of the unit ( Racks 8-10)
It's likely that you need to change the filter. Have a look at this post: http://blog.wineenthusiast.com/2009/04/20/caring-for-your-eurocave-3-simple-steps-towards-long-lasting-wine-protection/
Sep 30, 2010 | EuroCave Comfort 260 Collector's Package...
Problem with compressor
it is entailed process and you would need axcess to torch oxy-acc w #2 tip and silver solder, a evac pump, deep vac pump and container to capture the old freon usually compressors come with a new filter and the electrical parts per normal without sweep charge this process can take up to 4hrs to perform not for the unskilled if you do not remove the moistier from the system the new will fail shortly.....sorry for the news its be done by a professional...
Aug 19, 2009 | EuroCave Comfort 260 - Black Solid Door
Door warped.......
Feb 08, 2009 | EuroCave Comfort 260 Collector's Package...
Eurocave digital thermometer
The digital temperature display on the EuroCave has a small lithium battery that can be replaced by removing the bezel around the display. This was all that was needed to solve the problem.
Jan 22, 2009 | EuroCave Comfort 260 Collector's Package...
Is the glass surface on my GE Spectra solid surface glued to the heat element frame ?
The exterior panel (stainless in my case) is "glued" by adhesive to a lower metal piece which attaches to the door. I know this because my front panel came unglued and there is no other means of support. I am buying a very expensive new front panel.
Oct 19, 2008 | GE Spectra JBP78 Electric Kitchen Range
Top indicator light is on (orange)
Get info here:
http://www.eurocave.com/wine-cellar/wine-cellar-cooling.htm
Jan 03, 2008 | EuroCave Comfort 260 - Black Solid Door
EuroCave Comfort 170 1-Temp - Black Solid Door Logo
Top EuroCave Refrigerators Experts
Jim London
Jim London
Tom Chichester
Are you an EuroCave Refrigerator Expert? Answer questions, earn points and help others
